[fdo-internals] Code Submission Notification: Fix Linux build for FdoGeometry
Gavin Cramer gavin.cramer at autodesk.com
Mon Feb 19 17:35:19 EST 2007
The following change has been dropped into the 3.2.x branch and the
trunk...
Summary:
Fix Linux build for Geometry
Reviewed by:
Romica Dascalescu
Description:
This  fixes problems with the FdoGeometry when compiled with GNU 3.4.x
or newer.
Revision: 2557
Author: gavincramer
Date: 6:27:38 PM, Monday, February 19, 2007
Message:
Modified : /trunk/Fdo/Unmanaged/Src/Geometry/Fgf/GeometryImpl.h
Modified : /trunk/Fdo/Unmanaged/Src/Geometry/Fgf/Pool.h
Modified : /trunk/Fdo/Unmanaged/Src/Geometry/Fgf/Util.cpp
Modified : /trunk/Fdo/Unmanaged/Src/Geometry/Fgf/Util.h
Revision: 785
Author: gavincramer
Date: 6:29:33 PM, Monday, February 19, 2007
Message:
Modified : /branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/GeometryImpl.h
Modified : /branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/Pool.h
Modified : /branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/Util.cpp
Modified : /branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/Util.h
Gavin Cramer
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20070219/fa29118a/attachment.html
More information about the fdo-internals mailing list
