[fdo-internals] Free memory in the parser
Jack Lee jack.lee at autodesk.com
Tue Feb 20 16:16:21 EST 2007
This code drops fix a problem where the expression. filter, geometry and
constraint parsers has a memory leak in Linux
The fixes have been dropped in the 3.2.x branch and the trunk.
r786 | jacklee | 2007-02-20 16:53:58 -0500 (Tue, 20 Feb 2007) | 1 line
Changed paths:
   M /branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Parse/Parse.cpp
   M /branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Parse/ParseFgft.cpp
Free memory leak in the expression, filter and geometry parser
r787 | jacklee | 2007-02-20 16:55:24 -0500 (Tue, 20 Feb 2007) | 1 line
Changed paths:
   M /branches/3.2.x/Utilities/Common/Src/Parse/Parse.cpp
Free memory leak in the constraint geometry parser
r2566 | jacklee | 2007-02-20 17:02:00 -0500 (Tue, 20 Feb 2007) | 1 line
Changed paths:
   M /trunk/Fdo/Unmanaged/Src/Fdo/Parse/Parse.cpp
r2568 | jacklee | 2007-02-20 17:04:39 -0500 (Tue, 20 Feb 2007) | 1 line
Changed paths:
   M /trunk/Utilities/Common/Src/Parse/Parse.cpp
Free memory leak in the constraint parser
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20070220/ca3ccd66/attachment.html
More information about the fdo-internals mailing list
