[fdo-internals] Constraints fixes
Brent Robinson brent.robinson at autodesk.com
Fri Jan 19 13:17:09 EST 2007
Some code changes were submitted to fix a couple of constraints defects
in RDBMS providers:
DescribeSchema now returns unique constraints that reference base
properties
Check constraints on multiple columns are now skipped when
reverse-engineering from physical to FDO schemas. Previously, an
exception was raised, which stopped the reverse-engineering process.
Files affected:
Revision: 653
Author: brentrobinson
Date: 1:54:03 PM, Friday, January 19, 2007
Message:
Handle unique constraints referencing base properties.
Modified :
/branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchem
aTest.cpp
Modified :
/branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalBende
r.xslt
Modified :
/branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalForma
tter.xslt
Modified :
/branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalSorte
r.xslt
Modified :
/branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign
1_master.txt
Modified :
2_master.txt
Modified :
_out1_master.txt
Modified :
_out2_master.txt
Modified :
/branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrid
es1_master.txt
Modified :
es2_master.txt
Modified :
es3_master.txt
Modified :
es_def1_master.txt
Added :
es_err1_master.txt
Modified :
es_out2_master.txt
Revision: 638
Date: 1:51:20 PM, Friday, January 19, 2007
Message:
Modified :
/branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Lp/ClassDefinition.h
Modified :
/branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Lp/UniqueConstraint.h
Modified : /branches/3.2.x/Utilities/SchemaMgr/Nls/SmMessage.mc
Modified :
/branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/ClassDefinition.cpp
Modified :
/branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/SchemaCollection.cpp
Modified :
/branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/UniqueConstraint.cpp
Modified :
/branches/3.2.x/Utilities/TestCommon/Inc/TestCommonConstraints.h
Modified :
/branches/3.2.x/Utilities/TestCommon/Src/TestCommonConstraints.cpp
Revision: 654
Date: 1:55:55 PM, Friday, January 19, 2007
Message:
Filter out check constraints on multiple columns (not supported by FDO)
Modified :
/branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTest
s.cpp
Revision: 639
Date: 1:55:21 PM, Friday, January 19, 2007
Message:
Modified : /branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Table.cpp
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20070119/933bc7df/attachment.html
More information about the fdo-internals mailing list
