[fdo-internals] SVN Repository Merge Issues
Greg Boone greg.boone at autodesk.com
Fri Jan 26 16:43:35 EST 2007
Hi all,
At this point, we have identified the following code submissions that
were made in the trunk and not in 3.2.x
            603
            628
            652
Details...
r603 | brentrobinson | 2006-12-18 10:09:39 -0500 (Mon, 18 Dec 2006) | 1
line
Changed paths:
   M /trunk/Fdo/Unmanaged/Common.vcproj
   M /trunk/Fdo/Unmanaged/Fdo.vcproj
   A /trunk/Fdo/Unmanaged/Inc/Common/Compare.h
   M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/ByteValue.h
   M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/DataValue.h
   M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/DateTimeValue.h
   M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/DecimalValue.h
   M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/DoubleValue.h
   M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/Int16Value.h
   M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/Int32Value.h
   M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/Int64Value.h
   M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/SingleValue.h
   M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/StringValue.h
   M /trunk/Fdo/Unmanaged/Inc/Fdo/Schema/MergeContext.h
   M /trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraint.h
   M /trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraintList.h
   M /trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraintRange.h
   M /trunk/Fdo/Unmanaged/Inc/FdoCommon.h
   M /trunk/Fdo/Unmanaged/Inc/Makefile.am
   M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/ByteValue.cpp
   M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/DataValue.cpp
   M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/DateTimeValue.cpp
   M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/DecimalValue.cpp
   M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/DoubleValue.cpp
   A /trunk/Fdo/Unmanaged/Src/Fdo/Expression/ExpressionInternal.cpp
   A /trunk/Fdo/Unmanaged/Src/Fdo/Expression/ExpressionInternal.h
   M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/Int16Value.cpp
   M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/Int32Value.cpp
   M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/Int64Value.cpp
   M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/SingleValue.cpp
   M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/StringValue.cpp
   M /trunk/Fdo/Unmanaged/Src/Fdo/Makefile.am
   M /trunk/Fdo/Unmanaged/Src/Fdo/Schema/DataPropertyDefinition.cpp
   M /trunk/Fdo/Unmanaged/Src/Fdo/Schema/MergeContext.cpp
   M /trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp
   M
/trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintRange.cpp
   M /trunk/Fdo/Unmanaged/Src/Message/FDOMessage.mc
FDO342: Support SDF constraint update.
r628 | brentrobinson | 2007-01-12 17:38:53 -0500 (Fri, 12 Jan 2007) | 1
line
Changed paths:
Removed circular friend reference
r652 | brentrobinson | 2007-01-23 16:21:24 -0500 (Tue, 23 Jan 2007) | 1
line
Changed paths:
   M /trunk/Fdo/Unmanaged/Inc/Fdo/Raster/DataValueCollection.h
   M /trunk/Fdo/Unmanaged/Inc/Fdo/Raster/IRasterPropertyDictionary.h
   M /trunk/Fdo/Unmanaged/Inc/Fdo.h
Deprecated redundant Inc/Fdo/Raster/DataValueCollection.h.
-----Original Message-----
Sent: Friday, January 26, 2007 10:15 AM
To: 'FDO Internals Mail List'
Cc: Shawn Barnes
Subject: RE: [fdo-internals] SVN Repository Merge Issues
In response to your question, "At this point in time, how different is
trunk and 3.2.x", the branch and trunk are mostly identical but not
totally identical. Our decision with branching 3.2.x was that all
changes submitted into the 3.2.x branch should also be submitted into
the trunk. I will have to verify that this is the case. I will look into
this and get back to you.
I know of a couple of submissions that went into the trunk that did not
go into the 3.2.x branch. There were several by Brent R. that come
immediately to mind (See attached) One significant difference is that
Brent dropped a change in the trunk of FDO that changed binary
compatibility between the branch and trunk.
Greg
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Robert Bray
Sent: Friday, January 26, 2007 1:06 AM
To: FDO Internals Mail List
Cc: Shawn Barnes
Subject: Re: [fdo-internals] SVN Repository Merge Issues
Hmm,
No responses. So everyone is ok with this, everyone is dumbfounded and
shocked into silence, or?
Any better ideas for how to deal with this merge? We need to make a
decision and move forward.
At this point in time, how different is trunk and 3.2.x?
Bob
Robert Bray wrote:
> All,
> Shawn has been tinkering with this and has been able to successfully
> merge trunk. However it looks like we will not be able to merge the
> branches. You can see a preview of the merged repository here:
> http://test.osgeo.net/trac/fdo-merged/browser/.
> Merging in SVN alters the revision numbers, which is why the branch
> merges do not work. Here is the summary from Shawn: "I've searched and
> spoken with a few people on subversion merges and consensus is,
> branches and tags are broken on projects that are being merged into
> another project, due to the fact that the tag/branch repository
> specific and don't translate to a new repository structure."
> So it looks like we may need to have an OLD COLLECTION OF REPOSITORIES
> (3.2.x) and a NEW REPOSITORY (3.3.x and beyond). This is not ideal but
> I do not know what else to do at this point.
> Thoughts and ideas welcome?
> Bob
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
