[fdo-internals] Code Submission Notification: fixed protected version defect in ArcSDE Provider
Pierre Dalcourt pierre.dalcourt at autodesk.com
Mon Jan 29 16:30:23 EST 2007
Fixed protected version defect in ArcSDE Provider.
The ArcSDE Provider was being too strict in preventing users from
accessing non-public
versions that they do not own.  ArcSDE supports "protected" versions
that
are writable by the owner and at least read-only by others.  I have
verified this
in ArcMap.  Removed an explicit check that prevents users from accessing
protected
versions they do not own.  Also removed a check when deleting versions
if the
state fails to be deleted; this is because states can be shared among
many
versions and thus the provider could succeed in deleting a version but
fail to
delete the corresponding state if it's in use by other versions.
FILES MODIFIED IN BRANCHES\3.2.x and trunk :
Src/Provider/ArcSDEConnection.cpp
Src/Provider/ArcSDELongTransactionUtility.cpp
Src/UnitTest/LongTransactionTests.cpp
Src/UnitTest/LongTransactionTests.h
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20070129/0309b402/attachment-0001.html
More information about the fdo-internals mailing list
