[fdo-internals] [Fwd: Re: [SAC] Subversion vhost migration underway]
Robert Bray rbray at robertbray.net
Sat Mar 3 12:09:10 EST 2007
FYI - See below. This affects all OSGEO SVN repositories.
-------- Original Message --------
Subject: Re: [SAC] Subversion vhost migration underway
Date: Sat, 3 Mar 2007 08:36:41 -0600
Reply-To: System Administration Committee Discussion/OSGeo
<sac at lists.osgeo.org>
To: System Administration Committee Discussion/OSGeo <sac at lists.osgeo.org>
References: <523155B1-BBA9-425C-BDDD-B7E0FA6D654E at hobu.net>
<8E468917B01800408B91984428BE03DD05C56840 at starfish.nanaimo.ca>
I have turned it on long enough for users to do a svn switch.  I
propose that we switch it off Monday at 5 pm CST.  I think it would
be pretty important that they don't *commit* anything to the old URL,
and only commit to the new URL after they issue the switch.  The svn
switch --relocate command below should work fine with the appropriate
substitutions for their URLs.
Howard
On Mar 3, 2007, at 1:49 AM, Jason Birch wrote:
> Howard,
> Several users were/are taking advantage of the wildcard DNS to
> reference the repositories with paths like:
> https://osgeo.org/svn/fdo <https://osgeo.org/svn/fdo>
> Is there any way to re-enable that path on the www vhost until
> these users get switched over?  I misunderstood the impact of the
> changes and indicated in my note that these aliases would continue
> to work until the wildcard DNS was pulled.
> Jason
> ________________________________
> From: sac-bounces at lists.osgeo.org on behalf of Howard Butler
> Sent: Fri 2007-03-02 8:20 PM
> Subject: [SAC] Subversion vhost migration underway
> Folks,
> I have flipped the switch on the DNS, and the subversion virtual host
> migration is underway.  The TTL was set to 6 hours a couple of days
> ago (after being turned down to 1 day more than a week ago), so the
> new DNS should propagate fairly quickly.  After some time for DNS to
> propagate, we'll flip the switch back on for the repositories.
> Note that it is expected that both http://svn.osgeo.org/gdal and
> http://svn.osgeo.org/svn/gdal will continue to work as repository
> URLs, but the shorter one is the preferred one.  At some indefinite
> point in the future, we will quit answering to /svn/gdal.
> After the repositories are back up, at your leisure you may do:
> svn switch --relocate http://svn.osgeo.org/svn/gdal http:// <http:///>
> svn.osgeo.org/gdal
> and all should be well.
> Howard
> Sac mailing list
> Sac at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/sac
> <winmail.dat>
> Sac mailing list
Sac mailing list
More information about the fdo-internals mailing list
