[fdo-internals] Code Submission Notification: Ticket #39 - Add Python Wrappers for FDO API (Windows Only)
Greg Boone greg.boone at autodesk.com
Tue Mar 13 22:43:20 EDT 2007
This submission adds Python scripting support to the FDO API. The FDO
build process now allows for the generation of a set of Python wrapper
scripts for the FDO API using SWIG.
Python support is currently supported on Windows only. Support on Linux
will be implemented in a separate submission.
In order to build the Python wrappers, users will have to install Python
and SWIG.
To install SWIG, refer to: http://www.swig.org/
To install Python, refer to: http://www.python.org/
The FDO python scripts have been tested using SWIG 1.3.31 and Python
2.4.4.
NOTE: Python 2.5 is not currently supported.
Once SWIG and Python have been installed, set the PYTHON_HOME and
SWIG_HOME environment variables to point to the Python and SWIG
installation locations. These variables are contained in the
.\setenvironment.bat script with the default installation directories
of:
PYTHON - C:\Program Files\Python24
SWIG - C:\Program Files\swigwin-1.3.31
Building the python scripts is an option in the FDO scripts and must be
explicitly invoked. To build the Python scripts, follow the following
steps:
call setenvironment.bat
call build -p=build OR call build -p=build -w=fdo
To run the python unit tests,
            cd Fdo\Python\UnitTest
            call UnitTests.cmd
Submission details:
Author: gregboone
Reviewed By: romicadascalescu
Date: 2007-03-13 19:42:45 -0400 (Tue, 13 Mar 2007)
New Revisions: 2682-2685
Added:
   trunk/Fdo/Python/
   trunk/Fdo/Python/FdoWrapper.vcproj
   trunk/Fdo/Python/Fdo_Inc/
   trunk/Fdo/Python/Fdo_Inc/Common/
   trunk/Fdo/Python/Fdo_Inc/Common/StringCollection.h
   trunk/Fdo/Python/Fdo_Inc/Common/Vector.h
   trunk/Fdo/Python/Fdo_Inc/Fdo/
   trunk/Fdo/Python/Fdo_Inc/Fdo/Commands/
   trunk/Fdo/Python/Fdo_Inc/Fdo/Commands/LongTransaction/
trunk/Fdo/Python/Fdo_Inc/Fdo/Commands/LongTransaction/LongTransactionCon
stants.h
   trunk/Fdo/Python/Fdo_Inc/Fdo/Xml/
   trunk/Fdo/Python/Fdo_Inc/Fdo/Xml/ClassMapping.h
   trunk/Fdo/Python/Fdo_Inc/Fdo/Xml/ElementMapping.h
   trunk/Fdo/Python/Fdo_Inc/Fdo/Xml/FeatureFlags.h
   trunk/Fdo/Python/Fdo_Inc/Fdo/Xml/Flags.h
   trunk/Fdo/Python/Fdo_Inc/Fdo/Xml/SpatialContextFlags.h
   trunk/Fdo/Python/Inc/
   trunk/Fdo/Python/Inc/Common/
   trunk/Fdo/Python/Inc/Common/FdoProxyConnectionManager.h
   trunk/Fdo/Python/Inc/Common/FdowStd.h
   trunk/Fdo/Python/Inc/Common/StringBuffer.h
   trunk/Fdo/Python/Inc/Common/utils.h
   trunk/Fdo/Python/Inc/Fdo/
   trunk/Fdo/Python/Inc/Fdo/PhysicalSchemaMappingCasts.h
   trunk/Fdo/Python/Inc/stdafx.h
   trunk/Fdo/Python/PythonWrappers.sln
   trunk/Fdo/Python/README.txt
   trunk/Fdo/Python/Resource/
   trunk/Fdo/Python/Resource/FdoWrapper.rc
   trunk/Fdo/Python/Resource/FdoWrapperResource.h
   trunk/Fdo/Python/Src/
   trunk/Fdo/Python/Src/Common/
   trunk/Fdo/Python/Src/Common/FdoProxyConnectionManager.cpp
   trunk/Fdo/Python/Src/Common/StringBuffer.cpp
   trunk/Fdo/Python/Src/Common/stdafx.cpp
   trunk/Fdo/Python/Src/Common/utils.cpp
   trunk/Fdo/Python/Src/Fdo/
   trunk/Fdo/Python/Src/Fdo/PhysicalSchemaMappingCasts.cpp
   trunk/Fdo/Python/Swig/
   trunk/Fdo/Python/Swig/Common/
   trunk/Fdo/Python/Swig/Common/CommonExceptions.i
   trunk/Fdo/Python/Swig/Common/CommonInit.i
   trunk/Fdo/Python/Swig/Common/CommonTypemaps.i
   trunk/Fdo/Python/Swig/Fdo/
   trunk/Fdo/Python/Swig/Fdo/CommonIncludes.i
   trunk/Fdo/Python/Swig/Fdo/FdoIncludes.i
   trunk/Fdo/Python/Swig/Fdo/FdoPointercasts.i
   trunk/Fdo/Python/Swig/Fdo/FdoTypemaps.i
   trunk/Fdo/Python/Swig/Fdo/GeometryIncludes.i
   trunk/Fdo/Python/Swig/Fdo/Main.i
   trunk/Fdo/Python/UnitTest/
   trunk/Fdo/Python/UnitTest/Input/
   trunk/Fdo/Python/UnitTest/Input/UnitTestConfig.ini
   trunk/Fdo/Python/UnitTest/Input/clock.avi
   trunk/Fdo/Python/UnitTest/Lib/
   trunk/Fdo/Python/UnitTest/Lib/SdfConnectionFactory.py
   trunk/Fdo/Python/UnitTest/Lib/SdfFileCreationParams.py
   trunk/Fdo/Python/UnitTest/Lib/SdfFileFactory.py
   trunk/Fdo/Python/UnitTest/SetEnvironment.bat
   trunk/Fdo/Python/UnitTest/Src/
   trunk/Fdo/Python/UnitTest/Src/ApplySchemaTest.py
   trunk/Fdo/Python/UnitTest/Src/CapabilitiesTest.py
   trunk/Fdo/Python/UnitTest/Src/ClientServicesTest.py
   trunk/Fdo/Python/UnitTest/Src/CommandTest.py
   trunk/Fdo/Python/UnitTest/Src/LOBTest.py
   trunk/Fdo/Python/UnitTest/Src/StringBufferTest.py
   trunk/Fdo/Python/UnitTest/Src/TypeMapTest.py
   trunk/Fdo/Python/UnitTest/Src/main.py
   trunk/Fdo/Python/UnitTest/UnitTests.cmd
   trunk/Fdo/Python/UnitTest/providers.xml
   trunk/Fdo/Python/build.cmd
   trunk/Thirdparty/gsar/
   trunk/Thirdparty/gsar/bin/
   trunk/Thirdparty/gsar/bin/gsar.exe
   trunk/Thirdparty/gsar/contrib/
   trunk/Thirdparty/gsar/contrib/gsar/
   trunk/Thirdparty/gsar/contrib/gsar/1.12/
   trunk/Thirdparty/gsar/contrib/gsar/1.12/depends-GnuWin32.lst
   trunk/Thirdparty/gsar/contrib/gsar/1.12/gsar-1.12-GnuWin32.README
   trunk/Thirdparty/gsar/contrib/gsar/1.12/gsar-1.12/
   trunk/Thirdparty/gsar/contrib/gsar/1.12/gsar-1.12/copying
   trunk/Thirdparty/gsar/man/
   trunk/Thirdparty/gsar/man/cat1/
   trunk/Thirdparty/gsar/man/cat1/gsar.1.txt
   trunk/Thirdparty/gsar/manifest/
   trunk/Thirdparty/gsar/manifest/gsar-1.12-bin.mft
   trunk/Thirdparty/gsar/manifest/gsar-1.12-bin.ver
   trunk/Fdo/build.bat
   trunk/License_README.txt
   trunk/OpenSourceBuild__README.txt
   trunk/build.bat
   trunk/setenvironment.bat
   trunk/www/docs/OpenSourceBuild__README.html
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20070313/24c64823/attachment-0001.html
More information about the fdo-internals mailing list
