[fdo-internals] FDO 3.2.x or 3.2.0
Greg Boone greg.boone at autodesk.com
Wed Mar 14 13:52:17 EDT 2007
For the official releases of AutoCAD Map 2008 and Autodesk MapGuide
Enterprise 2008 due later this year, I recommend linking your provider
against the 3.2.2 version of FDO located in
https://svn.osgeo.org/fdocore/branches/3.2.x.
FDO 3.2.0 is not binary compatible with Map 2008 or MapGuide Enterprise
2008.
Greg
-----Original Message-----
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Mateusz
Loskot
Sent: Wednesday, March 14, 2007 1:12 PM
To: fdo-internals
Subject: [fdo-internals] FDO 3.2.x or 3.2.0
Could anyone give me some details about core differences between
FDO 3.2.0 release [1] and FDO 3.2.x branch [2] regarding using these
versions for development of provider that will be used with:
- AutoCAD Map 3D 2008
- MapGuide OS 1.1.0 (also with Autodesk MapGuide Studio 2007) ?
I did some small tests of my fdopostgis using these versions of FDO
and it seems the Map 3D does support both of them.
With MapGuide and the Studio, I had no luck and I'm still getting errors
with loading my provider. An exception is thrown about it,
and CreateConnection of my provider is not hooked,
because I'd get a log file otherwise.
So, I wonder if I should keep going with FDO 3.2.x or may be get
back to FDO 3.2.0.
Any suggestions and explanations are appreciated
BTW, I use FDO 3.2.x without latest Romica's changes introduced here:
http://trac.osgeo.org/fdo/changeset/679
[1] FDO 3.2.0
http://198.202.74.219/download/fdo/3.2.0/fdo-3.2.0.tar.gz
[2] FDO 3.2.x
http://svn.osgeo.org/fdocore/branches/3.2.x/
Cheers
Mateusz Loskot
http://mateusz.loskot.net
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
