[fdo-internals] [Select] Empty reader or NULL?
Traian Stanev traian.stanev at autodesk.com
Mon Mar 19 22:16:36 EDT 2007
I verified SdfSelect and it throws a class-not-found exception if the class is not in the schema. So yes, an exception seems like the consistent thing to do.
Traian
	-----Original Message-----
	From: fdo-internals-bounces at lists.osgeo.org on behalf of Greg Boone
	Sent: Mon 3/19/2007 10:07 PM
	To: FDO Internals Mail List
	Cc:
	Subject: RE: [fdo-internals] [Select] Empty reader or NULL?
	In this specific case, I would image that an exception would be thrown
	stating that 'class non-existing-feature-class-name does not exist'.
	In other cases, where no valid data is available for return, but an
	exception is not warranted, I would recommend not returning NULL. I
	recommend returning an instantiated Reader. When the user calls
	ReadNext(), it will return false.
	Greg
	[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Mateusz
	Loskot
	Sent: Monday, March 19, 2007 8:43 PM
	To: fdo-internals
	Subject: [fdo-internals] [Select] Empty reader or NULL?
	I'd like to ask about semantic details of FdoISelect::Execute()
	operation, especially in DBMS provider.
	For instance, if a feature class is directly mapped to table in a
	database.
	Let's imagine the code below is called by a client:
	// Connection is Open
	FdoPtr<FdoIConnection> conn;
	FdoPtr<FdoISelect> cmd;
	cmd = static_cast<FdoISelect*>(
	    conn->CreateCommand(FdoCommandType_Select));
	assert(0 != cmd);
	// NOTE: Querying non-existing class
	cmd->SetFeatureClassName(L"non-existing-feature-class-name");
	// XXX - What Execute() is supposed to return here?
	FdoPtr<FdoIFeatureReader> reader = cmd->Execute();
	My question is as in line marked with XXX:
	If a client queries for a feature class that does not
	exist (a non-existing table), what the Execute() operation is supposed
	to return?
	Is it safe to return NULL pointer to a reader?
	Or it should return a kind of empty (terminating) reader, however here I
	have no idea how to achieve this kind of feature.
	Or an exception is thrown from Execute()?
	Cheers
	Mateusz Loskot
	http://mateusz.loskot.net <http://mateusz.loskot.net/>
	fdo-internals mailing list
	fdo-internals at lists.osgeo.org
	http://lists.osgeo.org/mailman/listinfo/fdo-internals
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20070319/74ecc770/attachment.html
More information about the fdo-internals mailing list
