[fdo-internals] fgf 2d - 3d
Traian Stanev traian.stanev at autodesk.com
Thu Mar 22 17:45:01 EDT 2007
Not sure if you need WKB or FGF output (not the same), but in either
case, you may be able to reuse OgrFdoUtil::Fgf2Wkb() from the OGR
provider. This function does use the 2.5D WKB extension for output, but
you can probably comment that out to output 2D WKB directly. It's not
perfect but could be easily reusable.
Traian
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Haris
Kurtagic
Sent: Thursday, March 22, 2007 5:37 PM
To: FDO Internals Mail List
Subject: [fdo-internals] fgf 2d - 3d
Is there in FDO libraries a function for converting 3d fgf to 2d fgf (
wkb ) ?
Autodesk Map is setting 3d geometry into spatial filter, I need to
change that to 2d wkb.
Thank you,
Haris
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20070322/b63de955/attachment.html
More information about the fdo-internals mailing list
