[fdo-internals] fgf 2d - 3d
Haris Kurtagic haris at sl-king.com
Thu Mar 22 18:45:14 EDT 2007
Yes, that would be fine. I suspect Autodesk has it on the list so.. ?
BTW:
I have developed a new open source FDO provider for MS Sql Server.
It is based on open source project MsSQLSpatial
http://www.codeplex.com/MsSqlSpatial
First impression is that it is working nicely.
I need this because I am running it also in Autodesk MAP and MAP is
setting 3d geometry in spatial filter.
That is not supported by NTS.
 I will release a first version tomorrow and publish it on users lists.
Haris
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: 22. marec 2007 23:16
To: FDO Internals Mail List
Subject: RE: [fdo-internals] fgf 2d - 3d
If such functionality is being used by multiple providers, why not
create an FDO RFC to move the required methods up into the FdoSpatial
API?
Greg
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Haris
Kurtagic
Sent: Thursday, March 22, 2007 6:21 PM
And I have a first very minimal version of it and it was best starting
point for me.
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Traian
Stanev
Sent: 22. marec 2007 23:00
Just like everything else in that provider - in as few characters as
possible!
Kurtagic
Sent: Thursday, March 22, 2007 6:15 PM
But I will take it from svn. I am curious how you implemented inserts :)
Thanks,
Haris
Stanev
Sent: 22. marec 2007 22:55
Yes, I only implemented it when I added support for insert and update.
It doesn't do arcs, so don't bother looking if you need those.
Traian
Kurtagic
Sent: Thursday, March 22, 2007 6:10 PM
I need to convert 2d wkb (but ig get 2d fgf i can convert to 2d wkb
trough existing functions)
In version of ogr provider I have ( i believe it is very old) , it is
not implemented  (OgrConnection::Fgf2Wkb ).
I supose I need to get latest ogr provider from svn?
Haris
Stanev
Sent: 22. marec 2007 22:45
Not sure if you need WKB or FGF output (not the same), but in either
case, you may be able to reuse OgrFdoUtil::Fgf2Wkb() from the OGR
provider. This function does use the 2.5D WKB extension for output, but
you can probably comment that out to output 2D WKB directly. It's not
perfect but could be easily reusable.
Traian
Kurtagic
Sent: Thursday, March 22, 2007 5:37 PM
Subject: [fdo-internals] fgf 2d - 3d
Is there in FDO libraries a function for converting 3d fgf to 2d fgf (
wkb ) ?
Autodesk Map is setting 3d geometry into spatial filter, I need to
change that to 2d wkb.
Thank you,
Haris
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20070322/cc3875ca/attachment-0001.html
More information about the fdo-internals mailing list
