[fdo-internals] Getting PostGIS provider to load properly in MapGuide/Linux
Mateusz Loskot mateusz at loskot.net
Wed Nov 14 17:06:24 EST 2007
Jason Birch wrote:
> Any ideas?
> Currently it's in the list of providers but I'm not getting connection
> properties or error messages.
> I've installed libpq-dev and postgres-server-dev-8.2 to try to get it to
> work but these were post-compile.
Jason,
Could you check if the .log file is generated?
> Do I have to add something to LD_LIBRARY_PATH before starting MapGuide,
> or maybe recompile with the new packages?
The libpq.so files should be available for ld loader.
So, you can add libpq location to LD_LIBRARY_PATH or as entry
in /etc/ld.so.conf file and run sudo ldconfig.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
More information about the fdo-internals mailing list
