[fdo-internals] OGR ProjConverter.h/.cpp
Greg Boone greg.boone at autodesk.com
Fri Oct 19 15:55:51 EDT 2007
Ok, the questions keep coming...
The release build expects to find
proj.lib
geos.lib
geos_c.obj
libpq.lib
oci.lib
So, if we want to incorporate the OGR provider into the top level Open
Source build process, do we expect that proj, geos, postgresql and
oracle client be installed and a version of GDAL be available that uses
them ?
Greg
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Traian
Stanev
Sent: Friday, October 19, 2007 3:43 PM
To: FDO Internals Mail List
Subject: RE: [fdo-internals] OGR ProjConverter.h/.cpp
I do not do debug builds, so only the Release build is up to date. The
settings for Debug are wrong. This is mostly because with GDAL one can
only have a single build when using its regular build tools. If you try
to do a debug provider build that links to release OGR libraries, there
are lots of problems (link and/or runtime), so I did not pursue that
path.
Traian
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: Friday, October 19, 2007 3:39 PM
For the OGR provider, the linker settings are different between the
Debug and Release configurations:
Additional dependencies
Release:
fdo.lib fdocommon.lib fdogeometry.lib ogr.lib cpl.lib ogrsf_frmts.lib
ogrsf_frmts_sup.lib proj.lib geos.lib libpq.lib wsock32.lib oci.lib
geos_c.obj xerces-c_2.lib
Debug:
ogrsf_frmts_sup.lib
Delay-Load DLLs
                Release:
                                oci.dll;fdo.dll;fdogeometry.dll
                Debug
Can I get a clarification on the expected settings?
Greg
Stanev
Sent: Friday, October 19, 2007 3:14 PM
I think that one is supposed to be optional, for specifying any
overridden coordinate systems. I don't have this file on my drive.
Sent: Friday, October 19, 2007 3:12 PM
Is there also supposed to be a file:  projections.txt?
Stanev
Sent: Friday, October 19, 2007 2:51 PM
That's mostly because I'm an idiot who can't use SVN. They should be
there now.
Traian
Sent: Friday, October 19, 2007 2:49 PM
Subject: [fdo-internals] OGR ProjConverter.h/.cpp
Hi All,
I am trying to build the OGR provider. The Windows solution requires
ProjConverter.h and ProjConverter.cpp. What are the source of these
files? They do not seem to be in the SVN.
Greg
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20071019/bde4d470/attachment-0001.html
More information about the fdo-internals mailing list
