[fdo-internals] S013-GB3: Build: Add PostGIS tobuild process(LINUX)
Traian Stanev traian.stanev at autodesk.com
Thu Oct 25 13:37:53 EDT 2007
Yes, I just wasn't sure if that would be automatically called by some
code in OGR or the provider has to call it, my memory of the OGR API is
failing. It's not the end user who would call that.
Traian
> -----Original Message-----
> From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-
> bounces at lists.osgeo.org] On Behalf Of Mateusz Loskot
> Sent: Thursday, October 25, 2007 12:50 PM
> To: FDO Internals Mail List
> Subject: Re: [fdo-internals] S013-GB3: Build: Add PostGIS tobuild
> process(LINUX)
> Traian,
> If the OGR provider is not supposed to call OGRRegisterAll() then who
> is? The OG provider end user? Honestly, it would seem strange to me,
> as GDAL/OGR details are encapsulated by the provider and the
> OGRRegisterAll() is required to be called to set up drivers registry.
> -- Mat
> Traian Stanev wrote:
> > Not sure about this one... Which version of GDAL are you using?
Also,
> I
> > don't know if the call to OGRRegisterAll is necessary to do from the
> > provider - it seems that call is causing your troubles.
> > Traian
> > [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg
> Boone
> > Sent: Thursday, October 25, 2007 11:25 AM
> > Subject: FW: [fdo-internals] S013-GB3: Build: Add PostGIS to build
> > process(LINUX)
> > Hi All,
> > Can I get some guidance on how to configure the GDAL build so that
> OGR
> > support is fully enabled?
> > Here are the settings I used.
> > ./configure --with-gif=internal --with-jpeg=internal --with-
> png=internal
> > --with-libtiff=internal --with-geotiff=internal --with-pg=no
> > --with-python=no --with-libz=internal
> > However, I still am getting the following missing symbols in the OGR
> > .so:
> > undefined symbol: _ZN13OGRDataSource17DestroyDataSourceEPS_
> > (./libOGRProvider.so)
> > undefined symbol: _ZN20OGRSFDriverRegistrar4OpenEPKciPP11OGRSFDriver
> > undefined symbol: OGRRegisterAll        (./libOGRProvider.so)
> > From: Jack Lee
> > Sent: Thursday, October 25, 2007 9:45 AM
> > To: Greg Boone
> > Subject: RE: [fdo-internals] S013-GB3: Build: Add PostGIS to
> > buildprocess(LINUX)
> > Hi Greg,
> > Did you tried the following
> > ldd -r libOGRProvider.so
> > I getting the following missing symbols:
> > From: Greg Boone
> > Sent: Thursday, October 25, 2007 9:29 AM
> > To: Jack Lee
> > buildprocess(LINUX)
> > Yes. I forgot that one. I will drop it.
> > From: Jack Lee
> > Sent: Thursday, October 25, 2007 9:01 AM
> > To: Greg Boone
> > buildprocess(LINUX)
> > Hi Greg,
> > Building OGR seems to be ok.
> > I having problems building PostGIS:
> > configure.in:66: required file `Doc/Makefile.in' not found
> > Do you forget to drop Makefile.am for the Doc directory?
> > From: Jack Lee
> > Sent: Wednesday, October 24, 2007 4:22 PM
> > To: Greg Boone
> > buildprocess(LINUX)
> > Hi Greg,
> > I will be doing a full build tonight. I will post to the mailing
list
> if
> > I still have a problem.
> > From: Greg Boone
> > Sent: Wednesday, October 24, 2007 4:18 PM
> > To: Jack Lee
> > buildprocess(LINUX)
> > Can you post to 'fdo-internals' and have others test?
> > From: Jack Lee
> > Sent: Wednesday, October 24, 2007 3:42 PM
> > To: Greg Boone
> > buildprocess(LINUX)
> > Importance: High
> > Hi Greg,
> > I am having problems building ogr.
> > ./build_linux.sh  --w ogr
> > Eventually, I get the following:
> > g++ -DPACKAGE_NAME=\"FDOOGR\" -DPACKAGE_TARNAME=\"fdoogr\"
> > -DPACKAGE_VERSION=\"3.3.0\" "-DPACKAGE_STRING=\"FDOOGR 3.3.0\""
> > -DPACKAGE_BUGREPORT=\"http://fdo.osgeo.org\" -DPACKAGE=\"fdoogr\"
> > -DVERSION=\"3.3.0\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1
> > -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1
> > -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1
> > -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -I. -I.
> > -I../../Fdo/Unmanaged/Inc -I/build1/slate/Thirdparty/gdal/ogr
> > -I/build1/slate/Thirdparty/gdal/ogr/ogrsf_frmts
> > -I/build1/slate/Thirdparty/gdal/port -I../../Thirdparty/gdal/ogr
> > -I../../Thirdparty/gdal/ogr/ogrsf_frmts -I../../Thirdparty/gdal/port
> > -MMD -MT -D__USE_GNU -DLINUX -DLINUX_IA32 -MT OgrFdoUtil.lo -MD -MP
> MF
> > .deps/OgrFdoUtil.Tpo -c OgrFdoUtil.cpp  -fPIC -DPIC -o
> > .libs/OgrFdoUtil.o
> > In file included from
> /build1/slate/Thirdparty/gdal/ogr/ogr_core.h:126,
> >                  from
> > /build1/slate/Thirdparty/gdal/ogr/ogr_geometry.h:233,
> >                  from
> > /build1/slate/Thirdparty/gdal/ogr/ogr_feature.h:147,
> >                  from
> > /build1/slate/Thirdparty/gdal/ogr/ogrsf_frmts/ogrsf_frmts.h:97,
> >                  from stdafx.h:56,
> >                  from OgrFdoUtil.cpp:19:
> > /build1/slate/Thirdparty/gdal/port/cpl_port.h:189:22: direct.h: No
> such
> > file or directory
> > make: *** [OgrFdoUtil.lo] Error 1
> Boone
> > Sent: Wednesday, October 24, 2007 3:35 PM
> > buildprocess(LINUX)
> > Importance: High
> > I just want to clarify that the neither the PostGIS nor the OGR
Linux
> > binaries have been tested/validated. This will have to be done
before
> > they can be released as part of the FDO 3.3.0 beta.
> > I will need other members of the community to assist with this task.
> > Greg
> > [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jason
> Birch
> > Sent: Wednesday, October 24, 2007 12:47 PM
> > buildprocess(LINUX)
> > Awesome...
> >   _____
> > From: Greg Boone
> > Subject: [fdo-internals] S013-GB3: Build: Add PostGIS to build
> > process(LINUX)
> > Title:            Build: Add PostGIS to build process (Linux)
> > fdo-internals mailing list
> > fdo-internals at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/fdo-internals
> Mateusz Loskot
> http://mateusz.loskot.net
More information about the fdo-internals mailing list
