[fdo-internals] Linux PostGIS provider build failure
Jack Lee jack.lee at autodesk.com
Thu Oct 25 16:45:16 EDT 2007
Removing "Connection::" should fix your problem.
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of larry white
Sent: Thursday, October 25, 2007 4:44 PM
To: FDO Internals Mail List
Subject: Re: [fdo-internals] Linux PostGIS provider build failure
oops, I should have included the line prior to the error message.
g++ -DPACKAGE_NAME=\"FDOPOSTGIS\" -DPACKAGE_TARNAME=\"fdopostgis\"
-DPACKAGE_VERSION=\"3.3.0\" "-DPACKAGE_STRING=\"FDOPOSTGIS 3.3.0\""
-DPACKAGE_BUGREPORT=\"http://fdo.osgeo.org\" -DPACKAGE=\"fdopostgis\"
-DVERSION=\"3.3.0\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1
-DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1
-DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1
-DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -I. -I. -I../
-I../../Inc -I../Message/Inc/ -I../../../../Fdo/Unmanaged/Inc
-I../../../../Utilities/Common/Inc
-I../../../../Thirdparty/pgsql/include -O2 -MMD -MT -D__USE_GNU -DLINUX
-DLINUX_IA32 -MT ApplySchemaCommand.lo -MD -MP -MF
.deps/ApplySchemaCommand.Tpo -c ApplySchemaCommand.cpp  -fPIC -DPIC -o
.libs/ApplySchemaCommand.o
-- larry
larry white wrote:
> Here is some info on an initial attempt to build the linux PostGIS
> provider.
> Build environment
> Fedora Core 6
> gcc 4.1.1
> (same environment I've used for previous builds of FDO and MapGuide OS)
> fdocore compiled without any problems and FDO unit tests ran successfully.
> However, there was an error during the PostGIS provider build.
> Here's the error:
> Connection.h:273: error: extra qualification
> 'fdo::postgis::Connection::' on member 'GetPgCurrentSchema'
> make[2]: *** [ApplySchemaCommand.lo] Error 1
> make[2]: Leaving directory
> `/home/mgDev/fdo-3-3.0/trunk/Providers/PostGIS/Src/Provider'
> -- larry
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
