[fdo-internals] Linux PostGIS provider build failure
larry white larz at neomatix.ca
Thu Oct 25 17:19:26 EDT 2007
That's good news :)
Thanks for the update.
-- larry
Greg Boone wrote:
> The compilation of the Unit Tests is still a TODO item.
> Greg
> -----Original Message-----
> From: fdo-internals-bounces at lists.osgeo.org
> [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of larry white
> Sent: Thursday, October 25, 2007 5:08 PM
> To: FDO Internals Mail List
> Subject: Re: [fdo-internals] Linux PostGIS provider build failure
> Thanks, that did the trick.
> By the way, I wasn't really looking at it as just 'my problem'. I wanted
> to report back to the code maintainers, so that they are aware of the
> problem.
> Also, the UnitTest executable doesn't appear to be part of the build
> process. Not sure if this is an oversight or is intentional. I find the
> unit tests the easy way to check the build, as opposed to trying to use
> the provider in MapGuide OS because this adds additional levels of
> complexity where things can go wrong.
> output from configure
> config.status: creating Makefile
> config.status: creating Inc/Makefile
> config.status: creating Src/Makefile
> config.status: creating Src/Message/Makefile
> config.status: creating Src/Overrides/Makefile
> config.status: creating Src/Provider/Makefile
> config.status: creating Doc/Makefile
> As you can see there is no Makefile for Src/UnitTest.
> -- larry
> Jack Lee wrote:
>> Hi,
>> Removing "Connection::" should fix your problem.
>> Sent: Thursday, October 25, 2007 4:44 PM
>> oops, I should have included the line prior to the error message.
>> g++ -DPACKAGE_NAME=\"FDOPOSTGIS\" -DPACKAGE_TARNAME=\"fdopostgis\"
>> -DPACKAGE_VERSION=\"3.3.0\" "-DPACKAGE_STRING=\"FDOPOSTGIS 3.3.0\""
>> -DPACKAGE_BUGREPORT=\"http://fdo.osgeo.org\" -DPACKAGE=\"fdopostgis\"
>> -DVERSION=\"3.3.0\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1
>> -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1
>> -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1
>> -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -I. -I. -I../
>> -I../../Inc -I../Message/Inc/ -I../../../../Fdo/Unmanaged/Inc
>> -I../../../../Utilities/Common/Inc
>> -I../../../../Thirdparty/pgsql/include -O2 -MMD -MT -D__USE_GNU
> -DLINUX
>> -DLINUX_IA32 -MT ApplySchemaCommand.lo -MD -MP -MF
>> .deps/ApplySchemaCommand.Tpo -c ApplySchemaCommand.cpp  -fPIC -DPIC -o
>> .libs/ApplySchemaCommand.o
>> -- larry
>> larry white wrote:
>>> Here is some info on an initial attempt to build the linux PostGIS
>>> provider.
>>> Build environment
>>> Fedora Core 6
>>> gcc 4.1.1
>>> (same environment I've used for previous builds of FDO and MapGuide
> OS)
>>> fdocore compiled without any problems and FDO unit tests ran
> successfully.
>>> However, there was an error during the PostGIS provider build.
>>> Here's the error:
>>> Connection.h:273: error: extra qualification
>>> 'fdo::postgis::Connection::' on member 'GetPgCurrentSchema'
>>> make[2]: *** [ApplySchemaCommand.lo] Error 1
>>> make[2]: Leaving directory
>>> `/home/mgDev/fdo-3-3.0/trunk/Providers/PostGIS/Src/Provider'
>>> -- larry
>>> fdo-internals mailing list
>>> fdo-internals at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
