[fdo-internals] CheckoutSVN
Jason Birch Jason.Birch at nanaimo.ca
Mon Oct 29 15:56:22 EDT 2007
Oh,
I was using it because of the massive size of www, but you're right it
would be a lot simpler now just to checkout trunk.
Jason
-----Original Message-----
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: Monday, October 29, 2007 12:54
To: FDO Internals Mail List
Subject: RE: [fdo-internals] CheckoutSVN
Correction....
"Initially checkoutsvn was simply intended to a be used as a convenience
script to handle the multiple FDO SVN locations"
Greg
Sent: Monday, October 29, 2007 3:52 PM
I have no problem with this. Make the modifications as required.
NOTE: Initially checkoutsvn was simply intended to a be used as a
convenience script to handle the multiple gfo svn locations. Now that we
have only a single svn location it usefulness is less apparent.
Greg
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Monday, October 29, 2007 3:45 PM
Subject: [fdo-internals] CheckoutSVN
Hi all,
It looks like the checkoutsvn.bat file (at least) is hardcoded to use
SSL.
Do you think it would be a good idea to default this to non-ssl, or at
least provide the option?  SSL adds a fair amount of overhead that isn't
necessary for non-developers.  I'm guessing that even for a developer's
initial checkout it's probably lower-cost to do the initial checkout
under non-SSL, and then do an "svn sw"?
Jason
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
