[fdo-internals] Remove Generated Files
Greg Boone greg.boone at autodesk.com
Mon Oct 29 16:50:44 EDT 2007
Actually, I would state that it is no more work (at least initially)
since we recommend users call build_linux.sh, which calls
      aclocal
      libtoolize --force
      automake --add-missing --copy
      autoconf
     ./configure
This generates the makefiles. Once this is done, the user is free to
call 'make' and 'make install' directly.
Greg
-----Original Message-----
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Mateusz
Loskot
Sent: Monday, October 29, 2007 4:47 PM
To: FDO Internals Mail List
Subject: Re: [fdo-internals] Remove Generated Files
Jason Birch wrote:
> It would be nice if the trunk could remain as accessible as possible
to
> non-developers.  I don't know what kind of effort there is using
> autotools, but just wanted to get a word in.
In many projects, especially in GNU world, ./configure is forbidden in
CVS/SVN as a dynamic content.
So, there is a special script provided that generates it for you.
For example, in GDAL ./configure lives in the repository,
but there is also autogen.sh script which can be used to generate
configure. Let's assume there is no ./configure in FDO repo, then
if you want to build SVN version, you have to run:
./autogen
./configure
make
make install
So, it's just one step more.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
