[fdo-internals] Remove Generated Files
Traian Stanev traian.stanev at autodesk.com
Tue Oct 30 10:12:21 EDT 2007
Another (long term) solution is to use Cmake. For example, there is a
developer out there who has developed a MapGuide build system that uses
Cmake instead of autotools. I am not very familiar with either, I am
just throwing this out there as a data point.
Traian
> -----Original Message-----
> From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-
> bounces at lists.osgeo.org] On Behalf Of Greg Boone
> Sent: Tuesday, October 30, 2007 9:41 AM
> To: FDO Internals Mail List
> Subject: RE: [fdo-internals] Remove Generated Files
> Agreed.
> [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Mateusz
> Loskot
> Sent: Tuesday, October 30, 2007 6:41 AM
> Subject: Re: [fdo-internals] Remove Generated Files
> Frank Warmerdam wrote:
> > Mateusz Loskot wrote:
> >> Greg Boone wrote:
> >>> IMHO... I would seriously consider removing all generated files
> >>> and require the user call build_linux.sh, which is what the
> >>> documentation suggests now.
> >> I'm all for that. IMO this is a very good practice, especially if a
> >>  project does follow GNU configuration based on ./configure script,
> >>  Makefile.am files and autotools chain.
> >> In comparison, this is not true for GDAL, so it would be not easy
> >> to remove ./configure and brothers from the repo.
> > Greg,
> > I, on the other hand, think this is a bad idea.  If the environment
> > is at all sensitive to the version of automake and autoconf, forcing
> > developers working from SVN to rebuild all the derived files runs
the
> > significant risk of problems related to them having the wrong
> > versions of automake and autoconf.
> > I've been driven away from involvement in a number of projects by
> > this sort of a annoyances, and I think we would be making it harder
> > for people to be involved in FDO causually.
> Yes, I agree with Frank that there is such risk.
> What I don't understand is that current building configuration
> regenerates ./configure & friends always by default, so current
> solution
> does not avoid this kind of problems pointed by Frank.
> Second, even if we provide ./configure, users still *have* to generate
> Makefile.in and Makefile files, so appropriate tools & its versions
are
> required sill.
> What I want to say here is that not removing configure does not solve
> potential problems with autotools versions.
> Cheers
> Mateusz Loskot
> http://mateusz.loskot.net
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
