[fdo-internals] FDO and projections
Haris Kurtagic haris at sl-king.com
Thu Sep 13 17:07:56 EDT 2007
I was thinking about having set of fdo functions for proj4 which could
be used trough FDO by external application's or by provider's.
For example I would like to have Fdo2Fdo with capability of data
projection as well I can see that some providers could use it as well
(but that is up to providers and that wouldn't change anything).
I think that FDO API for projection capabilities (using proj4) would be
great addition.
I am guessing that because we have that already in MapGuide it shouldn't
be too much work ?
Thank you,
Haris
-----Original Message-----
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Orest
Halustchak
Sent: Thursday, September 13, 2007 10:47 PM
To: FDO Internals Mail List
Subject: [fdo-internals] FDO and projections
Hi Haris,
I took the liberty of changing the subject text so that we can separate
this discussion - I just noticed that Greg called for a vote on RFC 11.
So, are thinking along the lines of fdo providers supporting projection
of spatial data on input/output through the fdo api, or are you thinking
of having a separate set of fdo utility functions that applications can
use separately to project data?
Thanks,
Orest.
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Haris
Kurtagic
Sent: Thursday, September 13, 2007 4:27 PM
Subject: RE: [fdo-internals] Updated RFC 11 - Area and Length functions
Hi Orest,
When you sad: " We will post these functions as fdo common utilities
so that other provider writers can use them as well if they choose.", I
was thinking that we will get in FDO way written functions for proj4
calculations.
What I mean, if we want to use proj4 in other provider it would be great
that we don't need to learn proj4.
Having FDO functions, which use's FDO geometry spatial context..., and
perfoming proj4 calls is something which would be very good.
Yes, I am not talking just about RFC 11.
Haris
Halustchak
Sent: Thursday, September 13, 2007 10:11 PM
Hi Haris,
The purpose of this isn't to introduce projection support via proj4 into
the fdo api. That would be a separate discussion outside of this rfc.
Are you asking about an api wrapper around utility functions to compute
length and area that you could use? I think that would make sense as
utility functions.
Orest.
Kurtagic
Sent: Thursday, September 13, 2007 4:05 PM
Is there going to be an FDO API (wrapper) for easier proj4 usage ?
Haris
Halustchak
Sent: Thursday, September 13, 2007 7:56 PM
Subject: [fdo-internals] Updated RFC 11 - Area and Length functions
Based on the feedback to RFC 11, the RFC has been updated.
http://trac.osgeo.org/fdo/wiki/FDORfc11
>From the discussion, we kept the 2D requirement but made it clearer
that
Z is skipped in the calculation. We could add separate 3d functions at a
future date.
The main change is for geodetic data. The RFC now calls for a ground
distance or area in metres or square-metres to be returned using a
calculation based on "general accepted formulae". For providers that do
not have a native coordinate system library, our intention is to reuse
code from proj4 for the length calculation and also to adapt it for an
area calculation. We will post these functions as fdo common utilities
Thanks,
Orest.
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
