[fdo-internals] Vote: FDO RFC 16 - FDO Provider for SQLite
Traian Stanev traian.stanev at autodesk.com
Tue Apr 1 12:42:41 EDT 2008
If you think FDO does not need another format, why do you suggest supporting that format in SDF?
Traian
> -----Original Message-----
> From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-
> bounces at lists.osgeo.org] On Behalf Of Badreddine Karoui
> Sent: Tuesday, April 01, 2008 12:39 PM
> To: FDO Internals Mail List
> Subject: RE: [fdo-internals] Vote: FDO RFC 16 - FDO Provider for SQLite
> Up until now, the SDF file format is the defacto FDO file format. I
> have 2 questions: 1) does Fdo need an another file format? And 2) if
> Fdo needs an other file format, then what this format brings new that
> the upgraded SDF will not?
> Badreddine
> bounces at lists.osgeo.org] On Behalf Of Traian Stanev
> Sent: Tuesday, April 01, 2008 12:29 PM
> SDF would end up implementing its own row encoder/decoder for SQLite.
> Why not use the one that SQLite itself has?
> SDF would end up using its own query engine. Why not use the one that
> SQLite itself has (SQL)?
> SDF has a persisted R-Tree.
> Those are design decisions that are different from I have in mind.
> Besides, I don't see what the argument is all about. We can have both
> the SDF provider and my provider support the same format.
> Traian
> > Sent: Tuesday, April 01, 2008 12:20 PM
> SQLite
> > Only the existing binary encoder/decoder is maintained for backward
> > compatibity. A new binary encoder/decoder will be created to write
> > SQLite compliant data. I wouldn't call that 2 providers in one DLL.
> > The SDF provider is at best 3 years old and can hardly be called
> > "legacy". I'm sure any performance used in the new code can apply to
> > the SDF provider, wouldn't?
> > Badreddine
> > Sent: Tuesday, April 01, 2008 12:09 PM
> SQLite
> > It would be like having two providers in one DLL. There would be two
> > code paths for everything, and I don't think all that much code would
> > be shared between the two, apart from query execution.
> > The SQLite provider (which I have already written), is right now
> > significantly faster than SDF in use cases that MapGuide cares about,
> > even with the virtual machine in the way. For BBOX spatial query on
> > several data sets I tried, it is at least 10 times faster than SDF. I
> > think that if the SDF codebase is used as a starting point, this
> would
> > not have been the case, due to all the legacy code that is in SDF.
> > Traian
> > > Sent: Tuesday, April 01, 2008 11:56 AM
> > SQLite
> > > Regardless of the terminology; these two providers persist their
> data
> > > to an SQLite file. The idea would be to upgrade the SDF provider to
> > > write SQLite complaint data blocks that can be consumed by other
> > SQLite
> > > tools/applications. At the same time the SDF provider maintains its
> > > backward compatibility to its current format. We get a seemless
> > > transition to the new format and stability since the bulk of the
> SDF
> > > provider code will be re-used. Also, since the SDF will continue to
> > > bypass the SQLite virtual machine, the performance will not be
> > degraded
> > > at least not by much.
> > > Badreddine
> > > Sent: Tuesday, April 01, 2008 11:44 AM
> > SQLite
> > > The RFC does not propose "enhancements". It proposes a new format.
> > > Traian
> internals-
> > > > bounces at lists.osgeo.org] On Behalf Of Greg Boone
> > > > Sent: Tuesday, April 01, 2008 11:32 AM
> > > SQLite
> > > > Maybe this question comes a bit too late, but why can't the
> > > > enhancements proposed in the RFC be made in the existing SDF
> > provider
> > > > as opposed to building a whole new provider?
> > > > Greg
> internals-
> > > > bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
> > > > Sent: Monday, March 31, 2008 5:29 PM
> > > SQLite
> > > > +1
> > > > Haris
> > > > [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jason
> > > Birch
> > > > Sent: Monday, March 31, 2008 7:51 PM
> > > > Subject: [fdo-internals] Vote: FDO RFC 16 - FDO Provider for
> SQLite
> > > > Given the modifications to the RFC to address questions raised on
> > > this
> > > > list, and a lack of further discussion I hereby move to approve
> FDO
> > > RFC
> > > > 16 - FDO Provider for SQLite.
> > > > https://trac.osgeo.org/fdo/wiki/FDORfc16
> > > > +1 from me
> > > > Jason
> > > > From: Traian Stanev
> > > > Subject: RE: [fdo-internals] FDO RFC 16 - FDO Provider for SQLite
> > > > I think it has enough stuff in it to vote on.
> > > > _______________________________________________
> > > > fdo-internals mailing list
> > > > fdo-internals at lists.osgeo.org
> > > > http://lists.osgeo.org/mailman/listinfo/fdo-internals
> > > > No virus found in this incoming message.
> > > > Checked by AVG.
> > > > Version: 7.5.519 / Virus Database: 269.22.1/1350 - Release Date:
> > > > 3/30/2008 12:32 PM
More information about the fdo-internals mailing list
