[fdo-internals] PostGIS and Spatial context question
Bruno Scott bscott at geomapgis.com
Fri Apr 11 09:42:52 EDT 2008
Hi guys,
this is what i get with 32631, its supposed to be some king of utm wgs84
zone 31n
In map
http://www.nabble.com/file/p16627804/postgis_32631_map.jpg
and in mapguide
http://www.nabble.com/file/p16627804/postgis_32631_mg.jpg
JasonBirch wrote:
> I don't know how it is now, but it used to be that some of the WKT codes
> that Proj.4 emitted did not map properly into CSMap.  There was quite a
> bit of work done on this for a previous MapGuide or maybe Studio
> release, but I'm not sure where the changes were made.  I wonder if this
> CS wasn't addressed?
> http://spatialreference.org/ref/epsg/27582/
> Can you try using a more common CS, like UTM?
> http://spatialreference.org/ref/epsg/32631/
> Jason
> -----Original Message-----
> From: Orest Halustchak
> Subject: RE: [fdo-internals] PostGIS and Spatial context question
> The spatial context should also have the coordinate system wkt string.
> This information is used to look up the corresponding coordinate system
> definition in the Mentor catalog.
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
View this message in context: http://www.nabble.com/PostGIS-and-Spatial-context-question-tp16581335s18162p16627804.html
Sent from the fdo-internals mailing list archive at Nabble.com.
More information about the fdo-internals mailing list
