[fdo-internals] Standardising FDO Schema's
Haris Kurtagic haris at sl-king.com
Fri Aug 29 16:07:46 EDT 2008
I fully agree with Orest and Robert.
I also understand that ~ signs in class names are not pretty.
Also, even bigger problem is that is some cases after class is created with ApplySchema schema  in next DescribeSchema call it will not return exact same Schema.Class name. Class name or schema name or both can be different.
I have decided for KML provider to have configuration XML file in which user can set which Schema.Class name which will be returned for particullar file or url. Suggestions ideas ?
Haris
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Mateusz Loskot
Sent: Friday, August 29, 2008 9:47 PM
To: FDO Internals Mail List
Subject: Re: [fdo-internals] Standardising FDO Schema's
Robert Fortin wrote:
> As Orest said, FDO represents the data in different layer Datastore,
> Schema and Class. That's the rule.  That's the standard.
Robert,
Yes, it's clear to me.
But still the question is if a name should reflect that
layering or not. Users may be confused trying to rely on schema names in
more detailed way than just uniquely identifying a feature schema in
connected datastore.
Anyway, IMO the discussion in this thread is useful :-)
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
