[fdo-internals] PostGIS ticket 106 question
Brent Robinson brent.robinson at autodesk.com
Wed Feb 20 12:46:54 EST 2008
Yes, these would be defects. The unit tests for the Sdf, Autodesk Oracle, MySQL, and Autodesk SqlServer providers exercise this case but maybe there is some situation where the delete of a class with data is still succeeding.
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Bruno Scott
Sent: Wednesday, February 20, 2008 12:19 PM
To: fdo-internals at lists.osgeo.org
Subject: RE: [fdo-internals] PostGIS ticket 106 question
So this meens that all these providers have a defect?
  Sdf
  Shp
  Autodesk Oracle
  King Oracle
  MySQL
  Autodesk SqlServer
Because they allow dropping table with data in it.
Bruno
Robert Fortin wrote:
> Oups!  Error...
> Correction: So as soon as there is data you ***can't*** delete the
> table...
> [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Robert Fortin
> Sent: Wednesday, February 20, 2008 11:42 AM
> To: FDO Internals Mail List
> At first I thought that it was up to the provider to decide in what
> circumstance a class (table) could be deleted.
> Well, not really...
> The documentation is not always clear and detailed but in this case the
> FDO spec for ApplySchema is pretty clear (extract from
> http://fdo.osgeo.org/files/fdo/docs/FDO_API/index.htm FdoIApplySchema
> Class Reference)
> If schema changes include deletion of classes or the schema itself, then
> those classes (or the schema, if it is marked as deleted) must not contain
> any instance data. If they do, an exception will be thrown.
> So as soon as there is data you can delete the table.  You must empty the
> table before you can delete it.
> RF
> [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Mateusz Loskot
> Sent: Wednesday, February 20, 2008 11:22 AM
> Subject: Re: [fdo-internals] PostGIS ticket 106 question
> Bruno Scott wrote:
>> As we are about to fix that one
>>     http://trac.osgeo.org/fdo/ticket/106
>> Just want to check with you guys because there is a debate on that one
>> http://www.nabble.com/Defects-in-PostGIS-provider-to12280094s18162.html#a12295194
>> For my point of view, as PostGIS allow dropping table with the SQL "Drop
>> table" it's safe to do so.
> Bruno,
> It should be safe at least in current version of PostGIS provider,
> I mean where a feature class mapping to physical table is simple
> one-to-one relation, but if in future there is more complex mapping
> available then simple DROP TABLE may break data consistency.
> Cheers
> Mateusz Loskot
> http://mateusz.loskot.net
> fdo-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
View this message in context: http://www.nabble.com/PostGIS-ticket-106-question-tp15591249s18162p15593982.html
Sent from the fdo-internals mailing list archive at Nabble.com.
More information about the fdo-internals mailing list
