[fdo-internals] Parsing WKT geoemtry with measure/dimensionality
    Simon Pelicon
    simon at sl-king.com
    Mon Feb 25 16:14:53 EST 2008
Hi!
I have a problem parsing WKT geometry with M or Z dimension.
For example in WKT documentation specification, point with M is defined
as in the example below:
Point M (10 10 40)
But parsing this to geometry in FDO returns this error:
m_cause = 0x01693a30 {m_message=0x01693a80
"(.\Src\Geometry\Parse\ParseFgft.cpp: 88) String is not a valid FGF
string. "
Fdo documentation says that: The Autodesk extension to WKT, referred to
as FGF Text, is a superset of WKT
 (that is, you can enter WKT as valid FGF Text strings). Dimensionality
is optional. It can be XY, XYM, XYZ, or XYZM.
I am confused about dimensionality specification now.
WKT specification puts only M or ZM ,but FDO requires XY in front of M
or ZM.
What have I overlooked?
Thanks!
Simon
More information about the fdo-internals
