[fdo-internals] About Utilities
Kenneth, GEOGRAF A/S ks at geograf.dk
Fri Feb 29 03:50:36 EST 2008
The SDF provider uses the SQLite internal headers.
This produces an output file that is somewhat like an SQLite file, but
useless to standard SQLite programs.
I belive the trick was to use the SQLite search tree and structues, but
add on Spatial info.
I don't know if it is possible to use a stock sqlite source, but I do
know that the current stock version of SQLite does not accept some of
the values added to the internal header structures.
Regards, Kenneth, GEOGRAF A/S
Helio Chissini de Castro skrev:
> Hi everyone
> I'm in the middle of cleanup build of FDO with cmake to use external
> libraries.
> My current status is that only Utilities/SchemaManager and
> Utilities/SQLiteInterface
> SchemaManager is not  building due some strange include order, and i would
> solve soon, but the issue now is about SQlite one
> Seens like that SQLiteManager code use internal headers of SqLite, instead of
> the standard ones, making it impossible to compile with a standard installed
> distribuition one.
> Is there something special that force you include a copy of sqlite source or
> we can replace with standard proper calls  ?
> []'s
More information about the fdo-internals mailing list
