[fdo-internals] Parsing WKT geoemtry with measure/dimensionality
Paul Ramsey pramsey at cleverelephant.ca
Sat Mar 1 16:57:59 EST 2008
Hm, I'd feel more comfortable if there were some examples there... I
have grown quite fond of the ISO representations in my old age...
explicit and clear:
POINT (0 0)
POINT M (0 0 0)
POINT Z (0 0 0)
POINT ZM (0 0 0 0)
On Feb 26, 2008, at 6:57 AM, Gavin Cramer wrote:
> Microsoft's SQL Server 2008 documents itself as supporting WKT
> augmented with Z and M:
>   http://msdn2.microsoft.com/en-us/library/bb933823(SQL.100).aspx
> It does appear to have done it with the same syntactic extensions
> for ordinate dimensionality as OGC does.
> Gavin
> -----Original Message-----
> From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org
> ] On Behalf Of Orest Halustchak
> Sent: Tuesday, February 26, 2008 8:21 AM
> To: FDO Internals Mail List
> Subject: RE: [fdo-internals] Parsing WKT geoemtry with measure/
> dimensionality
> Hi,
> Frank is correct that the FGF format was defined prior to the OGC
> working on the updated spec for wkb and wkt to support Z and M. I
> agree that FDO should be enhanced to support the new OGC spec. I'll
> add an entry to the FDO Futures wiki page for it and hopefully at
> some point someone will put together an RFC for it.
> What other systems do we know about that have added support for the
> updated Simple Features Spec?
> Thanks,
> Orest.
> ] On Behalf Of Frank Warmerdam (External)
> Sent: Monday, February 25, 2008 4:27 PM
> Subject: Re: [fdo-internals] Parsing WKT geoemtry with measure/
> dimensionality
> Simon Pelicon wrote:
>> Hi!
>> I have a problem parsing WKT geometry with M or Z dimension.
>> For example in WKT documentation specification, point with M is
>> defined
>> as in the example below:
>> Point M (10 10 40)
>> But parsing this to geometry in FDO returns this error:
>> m_cause = 0x01693a30 {m_message=0x01693a80
>> "(.\Src\Geometry\Parse\ParseFgft.cpp: 88) String is not a valid FGF
>> string. "
>> Fdo documentation says that: The Autodesk extension to WKT,
>> referred to
>> as FGF Text, is a superset of WKT
>> (that is, you can enter WKT as valid FGF Text strings).
>> Dimensionality
>> is optional. It can be XY, XYM, XYZ, or XYZM.
>> I am confused about dimensionality specification now.
>> WKT specification puts only M or ZM ,but FDO requires XY in front
>> of M
>> or ZM.
> Simon,
> I think the problem is that you are looking at the "new" Simple
> Features
> geometry specification, while FDO's FGF parser was written to the old
> one.  The new specification was only released within the last year I
> think.
> It certainly would be desirable (in my mind) for the FDO geometry
> parser
> to support both variations to the extent possible.
> BTW, the old simple features geometry specification did not include
> Z or M dimensions though there were some common approaches to
> supporting
> them in use in the wild.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
Paul Ramsey
+1 250 885 0632
More information about the fdo-internals mailing list
