[fdo-internals] IInsert.BatchParameterValues problems
Traian Stanev traian.stanev at autodesk.com
Wed Mar 5 10:45:02 EST 2008
Hi Maksim,
I am interested in the problem you were orinigally having with the insert command. Is this what were you doing:
For (all features)
1. Create a new Insert command
2. Set the property values
3. Execute Insert
4. Close resulting feature reader
Traian
> -----Original Message-----
> From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-
> bounces at lists.osgeo.org] On Behalf Of Maksim Sestic
> Sent: Wednesday, March 05, 2008 6:16 AM
> To: fdo-internals at lists.osgeo.org
> Subject: RE: [fdo-internals] IInsert.BatchParameterValues problems
> Hi Orest,
> If I understood well - in case provider does support parameters,
> managed
> IInsert will get instantied with BatchParameterValues propery
> containing
> empty BatchParameterValuesCollection collection. Otherwise - the
> property is
> Nothing (Null)... Something's strange here, the collection should exist
> in
> first place neverthless of provider's capabilities (it should throw an
> error
> afterwards, on IInsert.Execute).
> Is this an error in managed wrapper or a feature? :-)
> Regards,
> Maksim Sestic
> Orest Halustchak wrote:
> > Hi Maksim,
> > Did you check if the provider that you're using supports this
> capability?
> > Check FdoICommandCapabilities::SupportsParameters.
> > Note that some providers may do buffering internally so that even if
> you
> > call IInsert.Execute many times, internally those inserts are
> buffered and
> > use array inserts to the underlying server.
> > Thanks,
> > Orest.
> > [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Maksim
> Sestic
> > Sent: Tuesday, March 04, 2008 5:25 AM
> > Subject: [fdo-internals] IInsert.BatchParameterValues problems
> > It's FDO 3.2.0 in question. I'm asking this because managed
> > IInsert.BatchParameterValues cannot get instantiated via newing, and
> it's
> > Nothing (Null) by default when IInsert is created. Since
> > IInsert.BatchParameterValues is read-only property, there's no way to
> add
> > a
> > new instance of it and populate the collection with
> > ParameterValueCollections for each row.
> > Regards,
> > Maksim Sestic
> > Maksim Sestic wrote:
> > Hi all,
> > Is there any example of how to use managed
> > collection to insert many features in a batch? I'm currently using
> > IInsert.PropertyValues.Add(...) with consecutive IInsert.Execute to
> fill
> > the
> > datastore row-by-row, but this fails when there're thousands of rows.
> > Regards,
> > Maksim Sestic
> > View this message in context:
> > http://www.nabble.com/IInsert.BatchParameterValues-problems-
> tp15824346s18162p15824346.html
> > Sent from the fdo-internals mailing list archive at Nabble.com.
> > http://lists.osgeo.org/mailman/listinfo/fdo-internals
> tp15824346s18162p15847951.html
More information about the fdo-internals mailing list
