[fdo-internals] IInsert.BatchParameterValues problems
Greg Boone greg.boone at autodesk.com
Wed Mar 5 11:48:45 EST 2008
Which provider(s)? SDF?
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Maksim Sestic
Sent: Wednesday, March 05, 2008 10:27 AM
To: fdo-internals at lists.osgeo.org
Subject: RE: [fdo-internals] IInsert.BatchParameterValues problems
Hi Greg,
I'm currently maintaining a code that does consecutive
IInsert.PropertyValues.Add(...) followed by IInsert.Execute to fill the
database row-by-row. I don't have working example of BatchParameterValues.
So, once managed IInsert object gets instantiated, it's properties (of
interest) reflect the following:
- PropertyValues As PropertyValueCollection (ReadOnly) - an empty collection
- ParameterValues As ParameterValueCollection (ReadOnly) - Nothing/Null (!)
- BatchParameterValues As BatchParameterValueCollection (ReadOnly) -
Nothing/Null (!)
If I understood Orest correctly, if provider supported parameters in first
place - both ParameterValues and BatchParameterValues properties should
reflect empty collections after IInsert was instantiated (?)... But these
collections should be available (already instantiated) neverthless, since
IInsert.Execute would throw an error if parameters capability wasn't
supported by provider. Or I simply misunderstood Orest and this is a bug in
managed wrapper :-)
Regards,
Maksim Sestic
gregboone wrote:
> So you have managed code available that illustrates?
> Sent: Wednesday, March 05, 2008 6:16 AM
> Hi Orest,
> If I understood well - in case provider does support parameters, managed
> IInsert will get instantied with BatchParameterValues propery containing
> empty BatchParameterValuesCollection collection. Otherwise - the property
> is
> Nothing (Null)... Something's strange here, the collection should exist in
> first place neverthless of provider's capabilities (it should throw an
> error
> afterwards, on IInsert.Execute).
> Is this an error in managed wrapper or a feature? :-)
> Regards,
> Maksim Sestic
View this message in context: http://www.nabble.com/IInsert.BatchParameterValues-problems-tp15824346s18162p15852596.html
Sent from the fdo-internals mailing list archive at Nabble.com.
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
