[fdo-internals] FDO RFC 16 - FDO Provider for SQLite
Kenneth, GEOGRAF A/S ks at geograf.dk
Tue Mar 25 16:53:36 EDT 2008
I can't figure out how to extract/compute the BBOX from an SQLite BLOB,
without parsing the geometry.
I belive that it is faster to read the BBOX values rather than a
potentially large BLOB field.
I agree that it would use some space to add the columns, but adding the
columns would enable a fast filtering of unused features.
As for the 4 times index, one could merely add index for the x values,
and then use sequential filtering for the y values.
Is your internal spatial index algorithm absolutely without benefit from
added BBOX columns?
Regards, Kenneth, GEOGRAF A/S
Traian Stanev skrev:
> It's a waste of space to store BBOX. It would cost at least 32 bytes
> per feature, not counting the indexes.
> Also, you can easily compute the bounding box and add those 4 columns
> very quickly when you need them, given that SQLite is pretty fast to
> read from. Indexing on the 4 BBOX columns would make spatial queries
> have to compute the intersection of the results of 4 tree searches.
> SQLite is fast, but it's not **that** fast.
> Anyway, the nice thing about this format is that you can create the
> BBOX columns anyway, and use them. The FDO provider will not be using
> it though, for performance reasons.
> Traian
> *From:* fdo-internals-bounces at lists.osgeo.org
> [mailto:fdo-internals-bounces at lists.osgeo.org] *On Behalf Of *Kenneth,
> GEOGRAF A/S
> *Sent:* Tuesday, March 25, 2008 7:12 AM
> *To:* FDO Internals Mail List
> *Subject:* Re: [fdo-internals] FDO RFC 16 - FDO Provider for SQLite
> I just re-read the RFC.
> What are your reasons for not storing BBOX releated data in the data
> table?
> I would suggest adding four columns, like minx, maxx, miny, max
> (perhaps name them via. the geometry_columns table?).
> With that approach, and index on the pairs would move the BBOX query
> load/optimization into the DBMS.
> BBOX queries are simple, and does not require reading the actual
> column data.
> Your extended spatial index algorithm might read these values to
> produce the search tree.
> Another suggestion, would be to store the search tree in a blob column.
> That would enable a much faster load of data.
> To avoid the requirement that all data updaters know the algorithm, it
> might be legal to just clear the BLOB data on updates.
> I wrote a short paper on a similar mechanism some time ago, with a friend:
> http://www.hexad.dk/opensource/spatialdbms.pdf
> Hello,
> I just posted FDO RFC #16. Fresh off the virtual presses (printed on
> 100% recycled electrons, for you green-minded folks):
> http://trac.osgeo.org/fdo/wiki/FDORfc16
> Thanks,
> Traian
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org <mailto:fdo-internals at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20080325/b7faea4d/attachment.html
More information about the fdo-internals mailing list
