[fdo-internals] FDO RFC 16 - FDO Provider for SQLite
Traian Stanev traian.stanev at autodesk.com
Sat Mar 29 15:24:52 EDT 2008
Hi again,
I updated the RFC with some implementation plan notes for the provider. It's starting to read like an SEC 10-K filing, what with all those disclaimers about what will not be implemented, heh.
Traian
> -----Original Message-----
> From: Traian Stanev
> Sent: Monday, March 24, 2008 5:19 PM
> To: FDO Internals Mail List
> Subject: RE: [fdo-internals] FDO RFC 16 - FDO Provider for SQLite
> Hi Greg,
> I posted a file listing the capabilities of the provider at:
> http://trac.osgeo.org/fdo/attachment/wiki/FDORfc16/SdxCapabilities.h
> I'll write an implementation in a few days (after the schema is decided
> on, there seems to be some uncertainty there).
> Traian
> > From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-
> > bounces at lists.osgeo.org] On Behalf Of Greg Boone
> > Sent: Monday, March 24, 2008 1:14 PM
> > I was wondering if the RFC can be updated with an implementation plan
> > and list of expected capabilities as demonstrated in
> > http://trac.osgeo.org/fdo/wiki/FDORfc12
> > Greg
> > bounces at lists.osgeo.org] On Behalf Of Jason Birch
> > Sent: Monday, March 24, 2008 2:35 AM
> > To: FDO Internals Mail List; FDO Internals Mail List
> > Frank,
> > Obviously (?) we're not shooting for SFSQL certification for this
> > format, and I'm definitely not a stickler for standards, but I would
> > feel better matching the current OGC spec than older the PostGIS
> > schema.  Especially given that we are potentially setting a template
> > for future spatial storage in non-spatial formats.
> > There are some problems that mean that we can't just adopt the spec
> > wholesale though.
> > First, the geometry_type field in SFSQL1.2 is very close to TYPE in
> > PostGIS, but it uses integer-based lookup.  This looks awfully
> Oracle-
> > ish; not surprising given the editor I guess.  It does support curve
> > strings and more (pp 39-41), just as the new WKB spec does.
> > Second, storage_type in SFSQL1.2 is very close to what we want to
> > accomplish with geometry_format, but again is integer-based, and only
> > flags whether the geometry is normalised (ick - does anyone actually
> do
> > this?) or WKB (pp 28-29).  We would have to extend this to support
> WKT
> > and FGF.
> > As far as self-descriptive values go, I agree with you.  Being a
> > database geek, I'd personally prefer to see the use of integer codes
> > and an FK table of all of the values and their english equivalents
> > (which your code would ignore), but since we'd have to mangle the
> > specification anyway I guess that I'm not opposed to using varchar in
> > these places...
> > Of course, I'm not building it, so take this as specifications
> wankery
> > if you want.  I should also admit to being almost as annoyed at
> seeing
> > "type" as a field name as I am when I get an Access database with
> > "date" as a field name, so the rest of my comments are probably a bit
> > bent. ;)
> > Jason
> > ________________________________
> > From: Frank Warmerdam
> > Subject: Re: [fdo-internals] FDO RFC 16 - FDO Provider for SQLite
> > The "type" field is based on what I saw in PostGIS.  I'm not sure if
> it
> > is
> > described in the SF spec or not.  But, without a fairly specific
> reason
> > to
> > be different, I'd prefer to match what PostGIS does so it is easy for
> > folks
> > who already work with it to understand what is being done in SQLite.
> > So,
> > based on that I'm not *keen* on changing the field name or the
> > contents.
> > There are various reasons I don't like using integer codes in the
> > field.
> > First, it is different than PostGIS.  Second, I don't know what sorts
> > of
> > values to use for odd things like FGF curves.  Third, I find the
> > strings
> > more self-descriptive than integer codes.
> > I didn't really understand why you preferred storage_type to
> > geometry_format.
> > The geometry_format is unique to the sqlite proposal as far as I
> know,
> > so
> > if there is a reason for storage_type instead, I'd be quite open to a
> > change.  Does this align better with some other format?
> > BTW, the naming, etc proposed for stuff in sqlite could just as
> easily
> > be applied to any other non-spatial RDBMS type environment.
> > fdo-internals mailing list
> > fdo-internals at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
