[fdo-internals] FDO documentation questions
Dan Stoica dan.stoica at autodesk.com
Thu May 1 13:48:02 EDT 2008
"a speed difference " - What was the magnitude?
Thanks,
Dan.
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
Sent: Thursday, May 01, 2008 1:24 PM
To: FDO Internals Mail List
Subject: RE: [fdo-internals] FDO documentation questions
King.Oracle is supporting batch insert. I remember testing it in Fdo2Fdo when it makes a speed difference when copying data.
I will look into Fdo2Fdo code and give you and example.
Haris
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Donald Cameron
Sent: Thursday, May 01, 2008 3:59 PM
To: 'fdo-internals at lists.osgeo.org'
Subject: [fdo-internals] FDO documentation questions
I am working on the FDO documentation: The Essential FDO, The FDO Developers Guide, and the FDO API Reference.
I was going to write some sample code that does batch inserts using the OSGeo.FDO.Commands.BatchParameterValueCollection property of the OSGeo.FDO.Commands.Feature.IInsert command but I was told that no providers support batch insertion.
I currently believe that the SupportsParameters() method of OSGeo.FDO.Connections.Capabilities.ICommandCapabilities says whether a provider supports batch inserts.
According to a program I wrote, three providers support parameters: ArcSDE, KingOracle, and PostGIS.
So my question is this: Do they actually support batch insertion?
If so, I would be very grateful for some sample code showing how to use BatchParameterValueCollection to do batch insertion.
Regards,
Don
Don Cameron
Autodesk Inc.
Developer Publications Specialist
Ottawa, Ontario, Canada
613.233.3758
No virus found in this incoming message.
Checked by AVG.
Version: 7.5.524 / Virus Database: 269.23.7/1408 - Release Date: 4/30/2008 6:10 PM
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20080501/5c5d24f5/attachment-0001.html
More information about the fdo-internals mailing list
