[fdo-internals] Vote Passed: Give Bruno Scott committer status
Mateusz Loskot mateusz at loskot.net
Fri May 2 12:31:14 EDT 2008
Jason Birch wrote:
> This motion passes with unanimous support.
Great! Bruno, welcome to the team :-)
> If there are any expectations around this privilege other than what is
> in the contributor's agreement, please speak up now.  Perhaps we need an
> orientation list for new committers.  Is there one already?
> I'd imagine some things would be:
>  - ticket should be created for each defect or change in functionality
>  - commits should reference the ticket they are being submitted against
>  - changes in API require an RFC
>  - if you want to commit outside of your normal area of responsibility,
> coordinate these changes on the mailing list
> Anything else?
Not a requirement but just a suggestion:
- try to follow coding conventions used in a component being updated
(FDO core, a provider X, etc.) to avoid messed code.
Greetings
Mateusz Loskot
http://mateusz.loskot.net
More information about the fdo-internals mailing list
