[fdo-internals] OGR provider and intersection
Traian Stanev traian.stanev at autodesk.com
Mon May 12 09:13:32 EDT 2008
It's not the provider, it's the GDAL dll. You can drop in a GDAL dll that is compiled with GEOS and it should then work. Another alternative is to make it use the FdoSpatialUtility implementation of Intersects, which presumably is always available when FDO is there.
Traian
> -----Original Message-----
> From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-
> bounces at lists.osgeo.org] On Behalf Of Kenneth Skovhede, GEOGRAF A/S
> Sent: Monday, May 12, 2008 6:21 AM
> To: FDO Internals Mail List
> Subject: [fdo-internals] OGR provider and intersection
> I have used the 3.3.1 release of the SDK (from April).
> It seems the OGR provider is back to using Envelope intersection tests,
> when "INTERSECTS" is used.
> Is the provider compiled without GEOS support?
> If so, are there plans to change the build procedure to include GEOS
> support?
> Regards, Kenneth Skovhede, GEOGRAF A/S
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
