[fdo-internals] Request review of RFC 28 - AddStart/EndExpressionFunctions
Maksim Sestic max at geoinova.com
Tue Nov 4 03:07:53 EST 2008
Why don't you introduce optional parameter for vertice index being
inspected, i.e. PointX(n) - if there's no parameter then value of 0 is
assumed (used with Point geometries). In that way one can evaluate
linestring and polygon single vertice coordinate.
I think there's something else missing - I'm trying to draw directions for
one-way roads, as in Google Earth/Map. Although each road network's
linestring is directed (as in directed graph) and has direction flag
attached (uni/bi-directional), I still don't have enough data to actually
rotate an arrow - depicting road direction. How about introducing AngleXY()
and AngleXY(n) functions returning line segment angle in plane? Is there any
other solution to this, except for storing pre-calculated vectors? Maybe
adding some additional stylization rule for this?
Regards,
Maksim Sestic
  _____
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
Sent: Monday, November 03, 2008 23:40
To: FDO Internals Mail List
Subject: RE: [fdo-internals] Request review of RFC 28 -
Yeah, may be just provide PointX()/PointY()/PointZ() functions which take a
geometry as argument and throw an error for anything but points?
Traian
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Dan Stoica
Sent: Monday, November 03, 2008 5:24 PM
Subject: RE: [fdo-internals] Request review of RFC 28 - Add
What has the Start point so special except for the point features? For
example, the START=END for simple polygons.
Maybe this ECO should address only points?
Dan.
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: Monday, November 03, 2008 2:53 PM
Yes, Lines and Polygons do offer some difficulties. Also, the multi-geometry
objects are also a little weird. I am open to suggestions on how to handle
these types.
Greg
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Thursday, October 23, 2008 12:34 PM
That makes sense to me; I just wasn't sure what you would use the equivalent
function for lines/polygons for.
Jason
The use case: presents the ordinates of a point geometry as attribute in a
data table.  This feature will help us achieve that.
You could also think it can be used to display the coordinate as labels as
part of the symbology of a feature.
Or you could use the StartZ to show the elevation of a point or apply a
theme on it.
All these can't be done easily directly using the geometry attribute.
__________ Information from ESET NOD32 Antivirus, version of virus signature
database 3580 (20081103) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20081104/640b6c46/attachment-0001.html
More information about the fdo-internals mailing list
