[fdo-internals] RE: FDO Function SpatialExtents
Traian Stanev traian.stanev at autodesk.com
Mon Nov 17 17:54:22 EST 2008
Yes, just return the bounding box of all the geometries. Map does not need exact BBOX, just an extent it can zoom to in order to show something once you add the layer.
Traian
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
Sent: Monday, November 17, 2008 6:16 PM
To: FDO Internals Mail List
Subject: RE: [fdo-internals] RE: FDO Function SpatialExtents
Yes, SDO_AGGR_MBR could be slow.
In Oracle there is index METADATA table with SDO_ROOT_MBR ( perhaps that is what Orest was saying ? ) but that is not correct MBR of geometries.
I understood that SelectExtents is supposed to :
return exact MBR of geometries
works for SQL queries, works for subsets of data
It looks to me that Map is using SpatialExtents it to get not necessary exact extent of layer (class) not geometries.
So my question is, is SpatialExtents supposed to return MBR of geometries ?
I think for class extent we should have another command.
Haris
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Robert Fortin
Sent: Monday, November 17, 2008 11:24 PM
Subject: [fdo-internals] RE: FDO Function SpatialExtents
Map will use the SelectExtents function (if is exists) in order to compute the extent of the data set before it starts populating the cache.
The slower the SelectExtents  function is the slower Map rendering will be.  SDO_AGGR_MBR is probably not efficient enough for that purpose.
RF
Sent: Monday, November 17, 2008 5:36 PM
Subject: [fdo-internals] FDO Function SpatialExtents
I have implemented support for SelectAggregates in King.Oracle.
I am testing SpatialExtent function and I need help in understanding how clients, MAP 3D , is using it. I am not sure if I understand how is it supposed to be used.
I have implemented function using Oracle SDO_AGGR_MBR. That is rather slow process .
What I noticed is that MAP 3D 2009 is calling FDO command SelectAggregates with SpatialExtents function.
That makes rendering of layers very slow in MAP 3D.
I know I am asking about non-open source client like MAP 3D but from what I see makes me wonder if I understand SpatialExtents function correctly.
Thank you,
Haris
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20081117/f438909a/attachment.html
More information about the fdo-internals mailing list
