[fdo-internals] RE: FDO Function SpatialExtents
Haris Kurtagic haris at sl-king.com
Mon Nov 17 18:21:09 EST 2008
Yes, I use that info in describe schema to get extents of spatial context.
But I believe that metadata is not MBR of geometries.
I wrote as reply to Robert that now I don’t know what SpatialExtents is supposed to return.
I assume in Autodesk provider there is special case of SpatialExtents for all geomtries in class.
Shouldn’t we have two function than.
SpatialExtents is supposed to return exact MBR of geometries in query ?
Haris
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Orest Halustchak
Sent: Monday, November 17, 2008 11:45 PM
To: 'fdo-internals at lists.osgeo.org'
Subject: Re: [fdo-internals] RE: FDO Function SpatialExtents
Oracle saves the root mbr in one of the metadata tables. I don't have access at the moment to check.
Orest.
Sent from my BlackBerry Wireless Handheld
To: FDO Internals Mail List
Sent: Mon Nov 17 14:54:09 2008
Subject: RE: [fdo-internals] RE: FDO Function SpatialExtents
Can you help me little more, how to get it from R-TREE ?
I know of SDO_TUNE.Extent_OF which is faster for some types of data.
BTW, so far I tested , Map calls it twice, once together with Count, second time only SpatialExtents.
Thanks,
Haris
Sent: Monday, November 17, 2008 11:22 PM
Subject: [fdo-internals] RE: FDO Function SpatialExtents
Hi Haris,
Map3D asks for the spatial extents first before fetching any of the geometry. The spatial extents will define the extents of the window. The spatial extents function needs to be very quick in this case. For Oracle, you could get it from the r-tree.
Thanks,
Orest.
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
Sent: Monday, November 17, 2008 5:36 PM
Subject: [fdo-internals] FDO Function SpatialExtents
I have implemented support for SelectAggregates in King.Oracle.
I am testing SpatialExtent function and I need help in understanding how clients, MAP 3D , is using it. I am not sure if I understand how is it supposed to be used.
I have implemented function using Oracle SDO_AGGR_MBR. That is rather slow process .
What I noticed is that MAP 3D 2009 is calling FDO command SelectAggregates with SpatialExtents function.
That makes rendering of layers very slow in MAP 3D.
I know I am asking about non-open source client like MAP 3D but from what I see makes me wonder if I understand SpatialExtents function correctly.
Thank you,
Haris
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20081118/b8275867/attachment-0001.html
More information about the fdo-internals mailing list
