[fdo-internals] RE: FDO Function SpatialExtents
Haris Kurtagic haris at sl-king.com
Wed Nov 19 11:47:03 EST 2008
Thank you.
On my test data set Autodesk provider was returning SpatialExtents very
fast in case were SDO_AGGR_MBR would take few seconds to execute.
Few days ago I was looking at Oracle log and I saw queries runned by
Autodesk provider.
I was almost certain that Autodesk provider is not iterrating trough all
geometries. I guess I would have to spend more time on it :(
Haris
-----Original Message-----
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Dan Stoica
Sent: Wednesday, November 19, 2008 4:15 PM
To: FDO Internals Mail List
Subject: RE: [fdo-internals] RE: FDO Function SpatialExtents
> I think Autodesk.Oracle provider is calculating from SDO_ROOT_MBR data
only
No, for geodetic CS Autodesk.Oracle provider is doing a brute force
calculation using a select at OCI level.
Dan.
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Haris
Kurtagic
Sent: Tuesday, November 18, 2008 5:03 PM
SDO_TUNE.EXTENT_OF has few limitations like schema access and only works
for particullar number of dimensions
and still takes some time to calculate.
only (it is not exact extent in any case ).
I am hoping that formula will be shared here :)
Haris
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Tuesday, November 18, 2008 10:28 PM
What does
SELECT SDO_TUNE.EXTENT_OF('TABLENAME','GEOMCOLUMN') FROM DUAL
Give you for a geodetic table?
This post makes it look like retrieving the MBR of geodetic CS from the
index metadata table is non-trivial:
http://kr.forums.oracle.com/forums/thread.jspa?threadID=523315
Jason
Kurtagic
Sent: Tuesday, November 18, 2008 13:20
SDO_ROOT_MBR is not even close to layer extent for geodetic CS.
Any clue how Autodesk.Oracle provider is calculating index extent from
that SDO_ROOT_MBR  for geodetic CS?
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
