[fdo-internals] FDO Open Source 3.3.2 RC2
Traian Stanev traian.stanev at autodesk.com
Fri Nov 28 12:05:57 EST 2008
Hi Frank,
I can verify the Ubuntu x64 FDO build in a few days as an extra data point. However, I have the latest Ubuntu (8.10) so who knows what other problems I'll hit -- generally when I compile on Ubuntu I do it against the system packages (I delete things from /Thirdparty to avoid all the Thirdparty problems).
Traian
> -----Original Message-----
> From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-
> bounces at lists.osgeo.org] On Behalf Of Frank Warmerdam (External)
> Sent: Friday, November 28, 2008 11:59 AM
> To: FDO Internals Mail List
> Subject: Re: [fdo-internals] FDO Open Source 3.3.2 RC2
> Helio Chissini de Castro wrote:
> > On Quinta 27 Novembro 2008, Greg Boone wrote:
> >> Hi Frank,
> >> Can you make the required changes and submit the fixes? I don't have
> a 64
> >> bit Linux environment available for testing at the moment.
> > I have plenty at lab.
> > Need a testcase only.
> > The second bug is obvious in case of linux x86_64
> Helio / Greg,
> I have included a fix in the ticket (#423), and I am willing to apply
> it in
> trunk if no one sees a problem with it.  I'd prefer to be able to test
> it
> in a running system if I could.
> > The first one is easy to solve with cmake than auto*tools ( i solved
> long time
> > ago in cmake build )
> I'm afraid I don't understand your point.  The problem is related to
> the
> boost build system which does not use autotools as far as I recall (it
> uses
> jam).  The build is launched from Thirdparty.sh but this is not
> particular
> to automake, etc.  Can you suggest a chance in Thirdparty.sh that will
> make
> this work?  If so, please note it in the ticket, and I'll test it out
> and
> commit.
> It almost sounds like you are suggesting replacing the boost build
> system
> with cmake.  Surely we aren't contemplating replacing the internal
> build
> system for all the third party packages!
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
