[fdo-internals] Problem compiling provider for Autodesk Map 2010
Bruno Scott bscott at geomapgis.com
Fri Apr 17 10:39:32 EDT 2009
oops, i got you wrong
not adding the fdo in the path for running Map 2010
but for compiling...
I will double check and recompile...
View this message in context: http://n2.nabble.com/Problem-compiling-provider-for-Autodesk-Map-2010-tp2650844p2651085.html
Sent from the FDO Internals mailing list archive at Nabble.com.
More information about the fdo-internals mailing list
