[fdo-internals] Please review new RFC 22 - Enhance expression engine CONCAT function
Orest Halustchak orest.halustchak at autodesk.com
Tue Jul 14 14:15:55 EDT 2009
The CONCAT function in the FDO expression language is difficult to use in many cases because it supports only two parameters. If you need to concatenate a set of more than two strings, you have to use nested calls which is not convenient and error prone.
RFC 22, drafted by Dan Stoica, proposes to support a variable set of parameters for this function to make it easier to use.
http://trac.osgeo.org/fdo/wiki/FDORfc22
Have a look at the RFC and provide your comments.
Thanks,
Orest.
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20090714/7bc1608f/attachment.html
More information about the fdo-internals mailing list
