[fdo-internals] Please review new RFC 22 - Enhance expression engine CONCAT function
Orest Halustchak orest.halustchak at autodesk.com
Wed Jul 15 08:55:48 EDT 2009
Hi Jackie,
The change to FdoFunctionDefinition allows the last parameter to repeat a variable number of times.
Thanks,
Orest.
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Tuesday, July 14, 2009 11:57 PM
To: fdo-internals at lists.osgeo.org
Subject: Re: [fdo-internals] Please review new RFC 22 - Enhance expression engine CONCAT function
Going to slightly deviate from the discussion here:
Do you foresee new expression functions in the future that would look like
this:
MyVariableArgumentFunction(arg1, arg2, ...)
where there are actual defined arguments, followed by a variable argument
list?
It would seem that the proposed FdoFunctionDefinition wouldn't handle such a
scenario should it arise in the future.
- Jackie
Orest Halustchak wrote:
> Hi,
> The CONCAT function in the FDO expression language is difficult to use in
> many cases because it supports only two parameters. If you need to
> concatenate a set of more than two strings, you have to use nested calls
> which is not convenient and error prone.
> RFC 22, drafted by Dan Stoica, proposes to support a variable set of
> parameters for this function to make it easier to use.
> http://trac.osgeo.org/fdo/wiki/FDORfc22
> Have a look at the RFC and provide your comments.
> Thanks,
> Orest.
> fdo-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
View this message in context: http://n2.nabble.com/Please-review-new-RFC-22---Enhance-expression-engine-CONCAT-function-tp3258502p3260997.html
Sent from the FDO Internals mailing list archive at Nabble.com.
More information about the fdo-internals mailing list
