[fdo-internals] Motion: vote RFC 39 - Spatial operator combinations support
Traian Stanev traian.stanev at autodesk.com
Tue Jul 28 21:19:17 EDT 2009
I'm talking about the same enumeration. Just add more values to the existing one, while keeping the old ones in there.
enum FdoSpatialOperations
    FdoSpatialOperations_Contains,
    FdoSpatialOperations_Crosses,
    FdoSpatialOperations_Disjoint,
    FdoSpatialOperations_Equals,
    FdoSpatialOperations_Intersects,
    FdoSpatialOperations_Overlaps,
    FdoSpatialOperations_Touches,
    FdoSpatialOperations_Within,
    FdoSpatialOperations_CoveredBy,
    FdoSpatialOperations_Inside,
    FdoSpatialOperations_EnvelopeIntersects,
    FdoSpatialOperations_Relate = 0x100,
    FdoSpatialOperations_RelateContains   = 0x200,
    FdoSpatialOperations_RelateCrosses    = 0x400,
    FdoSpatialOperations_RelateDisjoint   = 0x800,
    FdoSpatialOperations_RelateEquals     = 0x1000,
   etc....
Anyway, this was just a suggestion in case people want to keep full backward binary compatibility of the existing enumeration. I already voted +1 for the RFC, and I still support it as is.
Traian
________________________________________
From: fdo-internals-bounces at lists.osgeo.org [fdo-internals-bounces at lists.osgeo.org] On Behalf Of Dan Stoica [dan.stoica at autodesk.com]
Sent: Tuesday, July 28, 2009 9:03 PM
To: FDO Internals Mail List
Subject: RE: [fdo-internals] Motion: vote RFC 39 - Spatial operator     combinations    support
Interesting idea, but I didn't want to create a new enumeration since people are already used with the existing one and it would look quite redundant. Reminded me of http://en.wikipedia.org/wiki/Occam's_razor...
Cheers,
Dan.
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
Sent: Tuesday, July 28, 2009 7:28 PM
If we want to be *really* backwards compatible, we could reserve the old values to have the same meanings as now, and allocate the new enumeration values starting at 0x100, 0x200 and so on in the same enumeration.
This way it is unambiguous -- if the value is 255 or less, it is one of the existing spatial operations. If it is more than that, then it is a new bitmasked spatial operation.
Traian
Sent: Tuesday, July 28, 2009 5:48 PM
As Traian said, “people will have to recompile their programs anyway”
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: Tuesday, July 28, 2009 5:41 PM
What about applications other than MapGuide?
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Dan Stoica
Sent: Tuesday, July 28, 2009 5:24 PM
Thanks, Traian, you saved me an email ☺
Dan.
Sent: Tuesday, July 28, 2009 5:20 PM
To: 'FDO Internals Mail List'
Well, I checked the MG codebase, and there is already such conversion function between the Mapguide and the FDO enumeration (see s_FdoSpatialOperation map), so it should not be a problem for MapGuide either.
Traian
Sent: Tuesday, July 28, 2009 5:04 PM
I guess since FDO API compatibility is already broken for 3.5 versus 3.4, it’s ok to make the change, with the knowledge that people will have to recompile their programs anyway.
However, I remember that MapGuide has a mirror of this enumeration that it uses in its API and then casts to FDO enumerated values directly. So I assume that there will need to be at least a change in MapGuide to add a function that does the conversion now, since the values no longer match. Might be worth searching the MapGuide API code for MgFeatureSpatialOperations.
Traian
Sent: Tuesday, July 28, 2009 4:45 PM
What about API functional compatibility?
Sent: Tuesday, July 28, 2009 4:35 PM
The backward compatibility is already broken…
Thanks,
Dan.
Sent: Tuesday, July 28, 2009 4:15 PM
+1 Traian
I assume that renumbering the existing FdoSpatialOperations enumeration was considered OK in terms of backward compatibility?
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Orest Halustchak
Sent: Tuesday, July 28, 2009 4:03 PM
Subject: [fdo-internals] Motion: vote RFC 39 - Spatial operator combinations support
There haven’t been any more comments on FDO RFC 39 - Spatial operator combinations support.
http://trac.osgeo.org/fdo/wiki/FDORfc39
I would like to motion for a vote on this RFC.
+1 from me.
Thanks,
Orest.
More information about the fdo-internals mailing list
