[fdo-internals] TIcket 471: ArcSDE Long Text Fields.. testing patch
Chris Erickson chris at cartopac.com
Mon Mar 9 13:47:04 EDT 2009
I've completed a round of testing with the attached (updated) version of the patch:
SDE / SQL Server (9.2, 2008)
SQL String Type:		Registered As Versioned (ArcCatalog):	Read/Updated/Inserted Correctly:
text							x							x
ntext							x							x
varchar(4000) 					x							x
varchar(max) 					/(Unsupported)				(Data Corruption)
nvarchar(4000) 					x							x
nvarchar(max) 					/(Unsupported) 				(Data Corruption)
Apparently the ArcSDE SDK doesn't work well with varchar(max)/nvarchar(max) fields...
I've also tested against ArcSDE 9.2/Oracle 10g (unknown field type) and can update records, but inserting I'm getting a "Illegal Variable Name/Number" error from Oracle.
Originally, this was thought to be a side-effect of having a field name of 'Text' and this being a reserved word, so I re-created with a  field name of "MEMO_FIELD", and it still fails (insert only...)
I don't have a clue on the cause of this right now.
chris erickson
developer
970.493.9500 x 191
970.482.1485 (fax)
Name: Issue471 - LargeTextFields.patch
Type: application/octet-stream
Desc: Issue471 - LargeTextFields.patch
Url : http://lists.osgeo.org/pipermail/fdo-internals/attachments/20090309/1bb78c1b/Issue471-LargeTextFields-0001.obj
More information about the fdo-internals mailing list
