[fdo-internals] RE: FDO 3.4.0 RC2 - Linux build patches
Greg Boone greg.boone at autodesk.com
Fri Mar 13 13:25:56 EDT 2009
I think we could accommodate these changes. They are build related and should not affect functionality.
Greg
-----Original Message-----
From: Helio Chissini de Castro [mailto:helio at kde.org]
Sent: Friday, March 13, 2009 1:11 PM
To: FDO Internals Mail List; Greg Boone
Subject: Re: [fdo-internals] RE: FDO 3.4.0 RC2 - Linux build patches
On Tuesday 10 of March 2009 15:16:59 Greg Boone wrote:
> In co-ordination with the release of FDO 3.4.0 RC2...  I have branched the
> 3.4 release at
Attached the following patches to allow clean build linux on core FDO, all
still valid on 3.4.0, explained:
fdo-3.3.1-genericrdbms-unixodbc.patch:
- Required if you compile with -Wl,--no-undefined -Wl,--as-needed in ldflags,
otherwise have link failure
fdo-3.4.0-xalan-1.10-transcode.patch:
- Required to enable usage with xalan-c versions equal or higher than 1.10
fdo-3.4.0-missing-cstd-includes.patch:
- Required to avoid compilation break
fdo-3.4.0-sqlite-internal-wformat.patch:
- Required if you compile with -Wformat flags that avoid use printf/sprintf
with proper syntax and enable possible buffer underruns
fdo-3.4.0-xerces-greater-than-2.8.patch:
- Requires to enable usage with xercer >= 2.8
fdo-3.3.1-constify-chars.patch:
- Used to make message parameters constified, reducing verbosity of compilation
and saving unnecessary code allocation.
Hope i'm not too late to this be included in release
[]'s
KDE Developer
Brasil/South America Primary Contact
More information about the fdo-internals mailing list
