[fdo-internals] RE: FDO 3.4.0 RC2 - Linux build patches
Helio Chissini de Castro helio at kde.org
Fri Mar 13 13:11:26 EDT 2009
On Tuesday 10 of March 2009 15:16:59 Greg Boone wrote:
> In co-ordination with the release of FDO 3.4.0 RC2...  I have branched the
> 3.4 release at
Attached the following patches to allow clean build linux on core FDO, all
still valid on 3.4.0, explained:
fdo-3.3.1-genericrdbms-unixodbc.patch:
- Required if you compile with -Wl,--no-undefined -Wl,--as-needed in ldflags,
otherwise have link failure
fdo-3.4.0-xalan-1.10-transcode.patch:
- Required to enable usage with xalan-c versions equal or higher than 1.10
fdo-3.4.0-missing-cstd-includes.patch:
- Required to avoid compilation break
fdo-3.4.0-sqlite-internal-wformat.patch:
- Required if you compile with -Wformat flags that avoid use printf/sprintf
with proper syntax and enable possible buffer underruns
fdo-3.4.0-xerces-greater-than-2.8.patch:
- Requires to enable usage with xercer >= 2.8
fdo-3.3.1-constify-chars.patch:
- Used to make message parameters constified, reducing verbosity of compilation
and saving unnecessary code allocation.
Hope i'm not too late to this be included in release
[]'s
KDE Developer
Brasil/South America Primary Contact
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/fdo-internals/attachments/20090313/f3b71e12/fdo-3.3.1-constify-chars-0001.bin
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/fdo-internals/attachments/20090313/f3b71e12/fdo-3.3.1-genericrdbms-unixodbc-0001.bin
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/fdo-internals/attachments/20090313/f3b71e12/fdo-3.4.0-sqlite-internal-wformat-0001.bin
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/fdo-internals/attachments/20090313/f3b71e12/fdo-3.4.0-xerces-greater-than-2.8-0001.bin
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/fdo-internals/attachments/20090313/f3b71e12/fdo-3.4.0-xalan-1.10-transcode-0001.bin
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/fdo-internals/attachments/20090313/f3b71e12/fdo-3.4.0-missing-cstd-includes-0001.bin
More information about the fdo-internals mailing list
