[fdo-internals] RE: FDO 3.4.0 RC2 - Linux build patches
Traian Stanev traian.stanev at autodesk.com
Fri Mar 13 15:22:18 EDT 2009
It can still go into the trunk, right? Just not the 3.4 branch.
Traian
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: Friday, March 13, 2009 2:10 PM
To: FDO Internals Mail List; Helio Chissini de Castro
Subject: RE: [fdo-internals] RE: FDO 3.4.0 RC2 - Linux build patches
I don’t think we will be able to handle the changes in:
	fdo-3.3.1-constify-chars.patch
These changes constitute an interface change and would make applications running with previous builds/release candidates of 3.4.0 binary incompatible with the final release.
Greg
Sent: Friday, March 13, 2009 1:26 PM
To: Helio Chissini de Castro; FDO Internals Mail List
I think we could accommodate these changes. They are build related and should not affect functionality.
Greg
From: Helio Chissini de Castro [mailto:helio at kde.org]
Sent: Friday, March 13, 2009 1:11 PM
To: FDO Internals Mail List; Greg Boone
Subject: Re: [fdo-internals] RE: FDO 3.4.0 RC2 - Linux build patches
On Tuesday 10 of March 2009 15:16:59 Greg Boone wrote:
> In co-ordination with the release of FDO 3.4.0 RC2...  I have branched
> the
> 3.4 release at
Attached the following patches to allow clean build linux on core FDO, all still valid on 3.4.0, explained:
fdo-3.3.1-genericrdbms-unixodbc.patch:
- Required if you compile with -Wl,--no-undefined -Wl,--as-needed in ldflags, otherwise have link failure
fdo-3.4.0-xalan-1.10-transcode.patch:
- Required to enable usage with xalan-c versions equal or higher than 1.10
fdo-3.4.0-missing-cstd-includes.patch:
- Required to avoid compilation break
fdo-3.4.0-sqlite-internal-wformat.patch:
- Required if you compile with -Wformat flags that avoid use printf/sprintf with proper syntax and enable possible buffer underruns
fdo-3.4.0-xerces-greater-than-2.8.patch:
- Requires to enable usage with xercer >= 2.8
fdo-3.3.1-constify-chars.patch:
- Used to make message parameters constified, reducing verbosity of compilation and saving unnecessary code allocation.
Hope i'm not too late to this be included in release
[]'s
KDE Developer
Brasil/South America Primary Contact
More information about the fdo-internals mailing list
