[fdo-internals] Patch: Issue 549 - UniqueIdentifier Fields not working in SQL Server Spatial
Greg Boone greg.boone at autodesk.com
Mon Oct 5 17:33:11 EDT 2009
Skipped content of type multipart/alternative-------------- next part --------------
//Copyright (C) 2004-2006  Autodesk, Inc.
//This library is free software; you can redistribute it and/or
//modify it under the terms of version 2.1 of the GNU Lesser
//General Public License as published by the Free Software Foundation.
//This library is distributed in the hope that it will be useful,
//but WITHOUT ANY WARRANTY; without even the implied warranty of
//MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
//Lesser General Public License for more details.
//You should have received a copy of the GNU Lesser General Public
//License along with this library; if not, write to the Free Software
//Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
//  Values are 32 bit values laid out as follows:
//   3 3 2 2 2 2 2 2 2 2 2 2 1 1 1 1 1 1 1 1 1 1
//   1 0 9 8 7 6 5 4 3 2 1 0 9 8 7 6 5 4 3 2 1 0 9 8 7 6 5 4 3 2 1 0
//  |Sev|C|R|     Facility          |               Code            |
//  where
//      Sev - is the severity code
//          00 - Success
//          01 - Informational
//          10 - Warning
//          11 - Error
//      C - is the Customer code flag
//      R - is a reserved bit
//      Facility - is the facility code
//      Code - is the facility's status code
// Define the facility codes
// Define the severity codes
// MessageId: FDO_1_INDEXOUTOFBOUNDS
// MessageText:
// Item index out of bounds.
#define FDO_1_INDEXOUTOFBOUNDS           0x00000001L
// MessageId: FDO_1_BADPARAMETER
// MessageText:
// Bad Parameter.
#define FDO_1_BADPARAMETER               0x00000002L
// MessageId: FDO_1_UNKNOWN_GEOMETRY_TYPE
// MessageText:
// '%1$ls': Unknown geometry type '%2$d' discovered.
#define FDO_1_UNKNOWN_GEOMETRY_TYPE      0x00000003L
// MessageId: FDO_1_INVALID_NUM_OF_COORDINATE_POSITIONS
// MessageText:
// '%1$ls': Invalid number of coordinate positions.
#define FDO_1_INVALID_NUM_OF_COORDINATE_POSITIONS 0x00000004L
// MessageId: FDO_1_UNKNOWN_GEOMETRY_COMPONENT_TYPE
// MessageText:
// '%1$ls': Unknown geometry component type '%2$d' discovered.
#define FDO_1_UNKNOWN_GEOMETRY_COMPONENT_TYPE 0x00000005L
// MessageId: FDO_1_OPEN_RING
// MessageText:
// '%1$ls': Identified an open ring when expecting a closed one.
#define FDO_1_OPEN_RING                  0x00000006L
// MessageId: FDO_1_RESOLUTION_TOO_FINE_FOR_EXTENT
// MessageText:
// '%1$ls': The resolution is too fine for the extents.
#define FDO_1_RESOLUTION_TOO_FINE_FOR_EXTENT 0x00000007L
// MessageId: FDO_1_RESOLUTION_TOO_LARGE_FOR_EXTENT
// MessageText:
// '%1$ls': The resolution is too large (> 0.1) for the extents.
#define FDO_1_RESOLUTION_TOO_LARGE_FOR_EXTENT 0x00000008L
// MessageId: FDO_1_COLLINEAR_POINTS
// MessageText:
// '%1$ls': The points are collinear.
#define FDO_1_COLLINEAR_POINTS           0x00000009L
// MessageId: FDO_1_MEMORY_DEALLOCATION_ERROR
// MessageText:
// '%1$ls': Failed to free memory for object '%2$ls'.
#define FDO_1_MEMORY_DEALLOCATION_ERROR  0x0000000AL
// MessageId: FDO_1_INVALID_INPUT_ON_CLASS_CREATION
// MessageText:
// Cannot create instance of class '%1$ls' due to invalid value for the input parameter(s) '%2$ls'.
#define FDO_1_INVALID_INPUT_ON_CLASS_CREATION 0x0000000BL
// MessageId: FDO_1_INVALID_INPUT_ON_CLASS_FUNCTION
// MessageText:
// '%1$ls': Cannot execute function due to invalid value for the input parameter(s) '%2$ls'.
#define FDO_1_INVALID_INPUT_ON_CLASS_FUNCTION 0x0000000CL
// MessageId: SCHEMA_1_BADATTRIBUTENAME
// MessageText:
// Bad schema attribute name.
#define SCHEMA_1_BADATTRIBUTENAME        0x000003E9L
// MessageId: SCHEMA_2_BASEPROPERTIESALREADYSET
// MessageText:
// Base properties already set.
#define SCHEMA_2_BASEPROPERTIESALREADYSET 0x000003EAL
// MessageId: SCHEMA_3_CLASSNOTADDED
// MessageText:
// Class has not already been added to the FeatureSchema.
#define SCHEMA_3_CLASSNOTADDED           0x000003EBL
// MessageId: SCHEMA_4_IDENTITYPROPERTYNOTPROPERTY
// MessageText:
// Identity Property must be member of Property collection.
#define SCHEMA_4_IDENTITYPROPERTYNOTPROPERTY 0x000003ECL
// MessageId: SCHEMA_5_INVALIDELEMENTNAME
// MessageText:
// Invalid element name.
#define SCHEMA_5_INVALIDELEMENTNAME      0x000003EDL
// MessageId: SCHEMA_6_NAMENOTINATTRIBUTEDICTIONARY
// MessageText:
// Name not in schema attribute dictionary.
#define SCHEMA_6_NAMENOTINATTRIBUTEDICTIONARY 0x000003EEL
// MessageId: SCHEMA_7_RELATIONENDNOTADDED
// MessageText:
// RelationEnd has not been added to a FeatureSchema.
#define SCHEMA_7_RELATIONENDNOTADDED     0x000003EFL
// MessageId: SCHEMA_8_ATTRIBUTEALREADYINDICTIONARY
// MessageText:
// Schema attribute already in dictionary.
#define SCHEMA_8_ATTRIBUTEALREADYINDICTIONARY 0x000003F0L
// MessageId: SCHEMA_9_ATTRIBUTENOTFOUND
// MessageText:
// Schema attribute not found.
#define SCHEMA_9_ATTRIBUTENOTFOUND       0x000003F1L
// MessageId: SCHEMA_10_OBJECTHASPARENT
// MessageText:
// Object already has parent.
#define SCHEMA_10_OBJECTHASPARENT        0x000003F2L
// MessageId: SCHEMA_11_OWNPARENT
// MessageText:
// Element cannot be its own parent/grandparent.
#define SCHEMA_11_OWNPARENT              0x000003F3L
// MessageId: SCHEMA_12_OWNBASECLASS
// MessageText:
// ClassDefinition cannot be its own base class.
#define SCHEMA_12_OWNBASECLASS           0x000003F4L
// MessageId: SCHEMA_13_IDENTITYPROPERTYONSUBCLASS
// MessageText:
// A Class with a Base Class cannot have an Identity Property.
#define SCHEMA_13_IDENTITYPROPERTYONSUBCLASS 0x000003F5L
// MessageId: SCHEMA_14_SUBCLASSWITHIDENTITYPROPERTIES
// MessageText:
// A Class with Identity Properties cannot have a Base Class.
#define SCHEMA_14_SUBCLASSWITHIDENTITYPROPERTIES 0x000003F6L
// MessageId: SCHEMA_15_NEGATIVELENGTHNOTALLOWED
// MessageText:
// A Data Property cannot have a negative length.
#define SCHEMA_15_NEGATIVELENGTHNOTALLOWED 0x000003F7L
// MessageId: SCHEMA_16_NEGATIVEPRECISIONNOTALLOWED
// MessageText:
// A Data Property cannot have a negative precision.
#define SCHEMA_16_NEGATIVEPRECISIONNOTALLOWED 0x000003F8L
// MessageId: SCHEMA_17_ASSOCIATIONMISSMATCHERROR
// MessageText:
// Association Property '%1$ls' has type or number missmatch between the identity properties and the reverse identity properties.
#define SCHEMA_17_ASSOCIATIONMISSMATCHERROR 0x000003F9L
// MessageId: SCHEMA_18_ASSOCIATIONIDENTITYERROR
// MessageText:
// Identity properties not part of the associated class.
#define SCHEMA_18_ASSOCIATIONIDENTITYERROR 0x000003FAL
// MessageId: SCHEMA_19_UNSUPPORTEDXSDELEMENT
// MessageText:
// Error reading schema '#1$ls' from XML, element '#2$ls' in #3$ls not supported by FDO.
#define SCHEMA_19_UNSUPPORTEDXSDELEMENT  0x000003FBL
// MessageId: SCHEMA_20_UNSUPPORTEDXSDATTRIBUTE
// MessageText:
// Error reading schema '#1$ls' from XML, attribute '#2$ls' in #3$ls not supported by FDO.
#define SCHEMA_20_UNSUPPORTEDXSDATTRIBUTE 0x000003FCL
// MessageId: SCHEMA_21_UNSUPPORTEDXSDATTRIBUTEVALUE
// MessageText:
// Error reading schema '#1$ls' from XML, #2$ls/@#3$ls value '#4$ls' not supported by FDO.
#define SCHEMA_21_UNSUPPORTEDXSDATTRIBUTEVALUE 0x000003FDL
// MessageId: SCHEMA_22_MISSINGOBJPROPCLASS
// MessageText:
// Error reading schema from XML, class %1$ls for object property %2$ls not found in current feature schema collection.
#define SCHEMA_22_MISSINGOBJPROPCLASS    0x000003FEL
// MessageId: SCHEMA_23_UNSUPPORTEDXSDGBLELEM
// MessageText:
// Error reading schema '#1$ls' from XML, global element #2$ls type must be '#3$ls' or '#4$ls'.
#define SCHEMA_23_UNSUPPORTEDXSDGBLELEM  0x000003FFL
// MessageId: SCHEMA_24_CLASSTYPECONFLICT
// MessageText:
// Cannot change class type of class '%1$ls'.
#define SCHEMA_24_CLASSTYPECONFLICT      0x00000400L
// MessageId: SCHEMA_25_PROPERTYTYPECONFLICT
// MessageText:
// Cannot change property type of property '%1$ls'.
#define SCHEMA_25_PROPERTYTYPECONFLICT   0x00000401L
// MessageId: SCHEMA_26_BASECLASSREF
// MessageText:
// Error resolving Feature Schema references; base class '%1$ls:%2$ls' for class '%3$ls' not found.
#define SCHEMA_26_BASECLASSREF           0x00000402L
// MessageId: SCHEMA_27_OBJPROPCLASSREF
// MessageText:
// Error reading Feature Schemas from XML; class '%1$ls:%2$ls' for object property '%3$ls' not found.
#define SCHEMA_27_OBJPROPCLASSREF        0x00000403L
// MessageId: SCHEMA_28_BASEIDPROPS
// MessageText:
// Error reading Feature Schemas from XML; identity properties for class '%1$ls' differ from those of base class '%2$ls'.
#define SCHEMA_28_BASEIDPROPS            0x00000404L
// MessageId: SCHEMA_29_IDPROPREF
// MessageText:
// Error reading Feature Schemas from XML; identity property '%1$ls' is not a property in class '%2$ls'.
#define SCHEMA_29_IDPROPREF              0x00000405L
// MessageId: SCHEMA_30_BASEIDPROPS
// MessageText:
// Error reading Feature Schemas from XML; object property '%1$ls' has no class; cannot resolve its identity property.
#define SCHEMA_30_BASEIDPROPS            0x00000406L
// MessageId: SCHEMA_31_OBJPROPIDPROPREF
// MessageText:
// Error reading Feature Schemas from XML; identity property '%1$ls' for object property '%2$ls' not found.
#define SCHEMA_31_OBJPROPIDPROPREF       0x00000407L
// MessageId: SCHEMA_32_GEOMPROPREF
// MessageText:
// Error resolving Feature Schemas references; geometry property '%1$ls' for feature class '%2$ls' not found.
#define SCHEMA_32_GEOMPROPREF            0x00000408L
// MessageId: SCHEMA_33_BADDATAPROPSTRING
// MessageText:
// Invalid property data type string %1$ls.
#define SCHEMA_33_BADDATAPROPSTRING      0x00000409L
// MessageId: SCHEMA_34_BADDATAPROPTYPE
// MessageText:
// Invalid property data type %1$d.
#define SCHEMA_34_BADDATAPROPTYPE        0x0000040AL
// MessageId: SCHEMA_35_NOCLASSTYPE
// MessageText:
// Cannot determine class type for class %1$ls.
#define SCHEMA_35_NOCLASSTYPE            0x0000040BL
// MessageId: SCHEMA_36_ABSTRACTCONFLICT
// MessageText:
// Error reading schema '#1$ls' from XML, abstract setting for  '#2$ls' differs from that of its global element '#3$ls.
#define SCHEMA_36_ABSTRACTCONFLICT       0x0000040CL
// MessageId: SCHEMA_37_REQUIREDNODEFEATURE
// MessageText:
// Start and end nodes of a network link feature can only be associated to a network node feature
#define SCHEMA_37_REQUIREDNODEFEATURE    0x0000040DL
// MessageId: SCHEMA_38_REQUIREDLAYERCLASS
// MessageText:
// The layer property can only be associated to a network layer class
#define SCHEMA_38_REQUIREDLAYERCLASS     0x0000040EL
// MessageId: SCHEMA_39_REQUIREDNETWORKFCLASS
// MessageText:
// The network property can only be associated to a network class
#define SCHEMA_39_REQUIREDNETWORKFCLASS  0x0000040FL
// MessageId: SCHEMA_40_REQUIREDNUMERICTYPE
// MessageText:
// The cost property type must be numeric.
#define SCHEMA_40_REQUIREDNUMERICTYPE    0x00000410L
// MessageId: SCHEMA_41_PARENTCHILDNOTSAMETYPE
// MessageText:
// The network feature parent is not the same type as the child.
#define SCHEMA_41_PARENTCHILDNOTSAMETYPE 0x00000411L
// MessageId: SCHEMA_42_PARENTCHILDNETWORKNOTSAME
// MessageText:
// The network feature parent network class is not the same as the child network class.
#define SCHEMA_42_PARENTCHILDNETWORKNOTSAME 0x00000412L
// MessageId: SCHEMA_43_COSTPROPERTYNOTFOUND
// MessageText:
// The network feature cost property is not a feature property.
#define SCHEMA_43_COSTPROPERTYNOTFOUND   0x00000413L
// MessageId: SCHEMA_44_LINKSTARTORENDNODENETWORKERROR
// MessageText:
// The start and end node network class must be the same as the link network class.
#define SCHEMA_44_LINKSTARTORENDNODENETWORKERROR 0x00000414L
// MessageId: SCHEMA_45_ASSOCPROPCLASSREF
// MessageText:
// Error reading Feature Schemas from XML; class '%1$ls:%2$ls' for association property '%3$ls' not found.
#define SCHEMA_45_ASSOCPROPCLASSREF      0x00000415L
// MessageId: SCHEMA_46_ASSOCPROPS
// MessageText:
// Error reading Feature Schemas from XML; association property '%1$ls' has no class; cannot resolve its identity property.
#define SCHEMA_46_ASSOCPROPS             0x00000416L
// MessageId: SCHEMA_47_ASSOCPROPIDPROPREF
// MessageText:
// Error reading Feature Schemas from XML; identity property '%1$ls' for association property '%2$ls' not found.
#define SCHEMA_47_ASSOCPROPIDPROPREF     0x00000417L
// MessageId: SCHEMA_48_ASSOCREVERSEPROPCLASSREF
// MessageText:
// Error reading Feature Schemas from XML; reverse association property '%1$ls' has no class; cannot resolve its identity property.
#define SCHEMA_48_ASSOCREVERSEPROPCLASSREF 0x00000418L
// MessageId: SCHEMA_49_ASSOCREVERSEPROPIDPROPREF
// MessageText:
// Error reading Feature Schemas from XML; identity property '%1$ls' for reverse association property '%2$ls' not found.
#define SCHEMA_49_ASSOCREVERSEPROPIDPROPREF 0x00000419L
// MessageId: SCHEMA_50_NETWORKLAYERPROPREF
// MessageText:
// Error reading Feature Schemas from XML; class '%1$ls:%2$ls' for network layer property '%3$ls' not found.
#define SCHEMA_50_NETWORKLAYERPROPREF    0x0000041AL
// MessageId: SCHEMA_51_CLASSNOSCHEMA
// MessageText:
// Element '%1$ls' references class (%2$ls) which does not belong to a feature schema.
#define SCHEMA_51_CLASSNOSCHEMA          0x0000041BL
// MessageId: SCHEMA_52_BADELEMENTNAME
// MessageText:
// Invalid Feature schema element name '%1$ls'; must not contain '%2$c'.
#define SCHEMA_52_BADELEMENTNAME         0x0000041CL
// MessageId: SCHEMA_53_BADASSOCREVERSEPROP
// MessageText:
// Cannot use auto-generated or system properties as reverse identity properties for association property '%1$ls'
#define SCHEMA_53_BADASSOCREVERSEPROP    0x0000041DL
// MessageId: SCHEMA_54_AUTOGENREADONLY
// MessageText:
// Cannot set autogenerated property '%1$ls' to be not read-only.
#define SCHEMA_54_AUTOGENREADONLY        0x0000041EL
// MessageId: SCHEMA_55_ASSOCIATEDCLASSREQUIRED
// MessageText:
// Association property '%1$ls' is missing the associated class
#define SCHEMA_55_ASSOCIATEDCLASSREQUIRED 0x0000041FL
// MessageId: SCHEMA_56_UNSUPPORTEDXSDGBLELEM
// MessageText:
// Error reading schema '#1$ls' from XML, global element #2$ls type must be '#3$ls' when error level is high.
#define SCHEMA_56_UNSUPPORTEDXSDGBLELEM  0x00000420L
// MessageId: SCHEMA_57_BADCOMPLEXTYPENAME
// MessageText:
// Error reading schema '#1$ls' from XML, complexType #2$ls name must end with 'Type' when error level is high.
#define SCHEMA_57_BADCOMPLEXTYPENAME     0x00000421L
// MessageId: SCHEMA_58_UNSUPPORTEDXSDGBLELEM
// MessageText:
// Error reading schema '#1$ls' from XML, global element #2$ls type is from a different schema: '#3$ls'.
#define SCHEMA_58_UNSUPPORTEDXSDGBLELEM  0x00000422L
// MessageId: SCHEMA_59_SCHEMAFROMPREFIX
// MessageText:
// Schema names can only be generated from xmlns prefixes when ErrorLevel is VeryLow.
#define SCHEMA_59_SCHEMAFROMPREFIX       0x00000423L
// MessageId: SCHEMA_60_MULTIELEMMAPPING
// MessageText:
// Multiple Schema Mappings found for element '%1$ls:%2$ls'.
#define SCHEMA_60_MULTIELEMMAPPING       0x00000424L
// MessageId: SCHEMA_61_MULTIELEMMAPPING
// MessageText:
// Multiple Schema Mappings found for element '%1$ls:%2$ls.%3$ls'.
#define SCHEMA_61_MULTIELEMMAPPING       0x00000425L
// MessageId: SCHEMA_62_NOCLASSMAPPING
// MessageText:
// Cannot add element '%1$ls', containing class mapping '%2$ls:%3$ls' not found.
#define SCHEMA_62_NOCLASSMAPPING         0x00000426L
// MessageId: SCHEMA_63_MULTICLASSMAPPING
// MessageText:
// Multiple Schema Mappings found for class '%1$ls:%2$ls'.
#define SCHEMA_63_MULTICLASSMAPPING      0x00000427L
// MessageId: SCHEMA_64_MULTINAMESPACES
// MessageText:
// Schema '%1$ls' has multiple targetNamespace values: '%2$ls', '%3$ls'.
#define SCHEMA_64_MULTINAMESPACES        0x00000428L
// MessageId: SCHEMA_65_UNICONSPROPREF
// MessageText:
// Error reading Feature Schemas from XML; unique constraint property '%1$ls' for feature class '%2$ls' not found.
#define SCHEMA_65_UNICONSPROPREF         0x00000429L
// MessageId: SCHEMA_66_SCHEMARENAME
// MessageText:
// Unsupported Schema modification; cannot rename feature schema '%1$ls' to '%2$ls'.
#define SCHEMA_66_SCHEMARENAME           0x0000042AL
// MessageId: SCHEMA_67_CLASSEXISTS
// MessageText:
// Cannot add class '%1$ls'; it already exists
#define SCHEMA_67_CLASSEXISTS            0x0000042BL
// MessageId: SCHEMA_68_BADCLASSTYPE
// MessageText:
// Cannot create class '%1$ls', unknown class type: %2$d
#define SCHEMA_68_BADCLASSTYPE           0x0000042CL
// MessageId: SCHEMA_69_CLASSNOTEXISTS
// MessageText:
// Cannot modify class '%1$ls'; it does not exist
#define SCHEMA_69_CLASSNOTEXISTS         0x0000042DL
// MessageId: SCHEMA_70_MODDESCRIPTION
// MessageText:
// Unsupported Schema modification; cannot modify description for element '%1$ls'.
#define SCHEMA_70_MODDESCRIPTION         0x0000042EL
// MessageId: SCHEMA_71_MODCLASSCONCRETE
// MessageText:
// Unsupported Schema modification; Cannot make abstract class '%1$ls' concrete
#define SCHEMA_71_MODCLASSCONCRETE       0x0000042FL
// MessageId: SCHEMA_72_MODCLASSABSTRACT
// MessageText:
// Unsupported Schema modification; Cannot make class '%1$ls' abstract
#define SCHEMA_72_MODCLASSABSTRACT       0x00000430L
// MessageId: SCHEMA_73_MODBASECLASS
// MessageText:
// Unsupported Schema modification; Cannot change base class for '%1$ls' from '%2$ls' to '%3$ls'
#define SCHEMA_73_MODBASECLASS           0x00000431L
// MessageId: SCHEMA_74_MODCLASSIDENTITY
// MessageText:
// Unsupported Schema modification; Cannot change identity properties for class '%1$ls' from (%2$ls) to (%3$ls)
#define SCHEMA_74_MODCLASSIDENTITY       0x00000432L
// MessageId: SCHEMA_75_PROPEXISTS
// MessageText:
// Cannot add property '%1$ls'; it already exists
#define SCHEMA_75_PROPEXISTS             0x00000433L
// MessageId: SCHEMA_76_BADPROPTYPE
// MessageText:
// Cannot create property '%1$ls', unknown property type: %2$d
#define SCHEMA_76_BADPROPTYPE            0x00000434L
// MessageId: SCHEMA_77_PROPNOTEXISTS
// MessageText:
// Cannot modify property '%1$ls'; it does not exist
#define SCHEMA_77_PROPNOTEXISTS          0x00000435L
// MessageId: SCHEMA_78_MODFEATGEOM
// MessageText:
// Unsupported Schema modification; Cannot modify GeometryProperty for feature class '%1$ls'
#define SCHEMA_78_MODFEATGEOM            0x00000436L
// MessageId: SCHEMA_79_MODNETLAYER
// MessageText:
// Unsupported Schema modification; Cannot modify layer class for network class '%1$ls'
#define SCHEMA_79_MODNETLAYER            0x00000437L
// MessageId: SCHEMA_80_MODNETCOST
// MessageText:
// Unsupported Schema modification; Cannot modify cost property for network feature class '%1$ls'
#define SCHEMA_80_MODNETCOST             0x00000438L
// MessageId: SCHEMA_81_MODFEATNET
// MessageText:
// Unsupported Schema modification; Cannot modify network class for network feature class '%1$ls'
#define SCHEMA_81_MODFEATNET             0x00000439L
// MessageId: SCHEMA_82_MODNETFEATREF
// MessageText:
// Unsupported Schema modification; Cannot modify referenced feature class for network feature class '%1$ls'
#define SCHEMA_82_MODNETFEATREF          0x0000043AL
// MessageId: SCHEMA_83_MODPARENTNETFEAT
// MessageText:
// Unsupported Schema modification; Cannot modify parent network feature class for network feature class '%1$ls'
#define SCHEMA_83_MODPARENTNETFEAT       0x0000043BL
// MessageId: SCHEMA_84_MODSTARTNODE
// MessageText:
// Unsupported Schema modification; Cannot modify start node for network link feature class '%1$ls'
#define SCHEMA_84_MODSTARTNODE           0x0000043CL
// MessageId: SCHEMA_85_MODENDNODE
// MessageText:
// Unsupported Schema modification; Cannot modify end node for network link feature class '%1$ls'
#define SCHEMA_85_MODENDNODE             0x0000043DL
// MessageId: SCHEMA_86_MODNODELAYER
// MessageText:
// Unsupported Schema modification; Cannot modify layer for network node feature class '%1$ls'
#define SCHEMA_86_MODNODELAYER           0x0000043EL
// MessageId: SCHEMA_87_MODDATATYPE
// MessageText:
// Unsupported Schema modification; Cannot change data type for property '%1$ls' from '%2$ls' to '%3$ls'
#define SCHEMA_87_MODDATATYPE            0x0000043FL
// MessageId: SCHEMA_88_MODDEFAULTVALUE
// MessageText:
// Unsupported Schema modification; Cannot change default value for data property '%1$ls' from '%2$ls' to '%3$ls'
#define SCHEMA_88_MODDEFAULTVALUE        0x00000440L
// MessageId: SCHEMA_89_MODDATALENGTH
// MessageText:
// Unsupported Schema modification; Cannot change length for data property '%1$ls' from '%2$d' to '%3$d'
#define SCHEMA_89_MODDATALENGTH          0x00000441L
// MessageId: SCHEMA_90_MODPROPNULLABLE
// MessageText:
// Unsupported Schema modification; Cannot change property '%1$ls' to be nullable
#define SCHEMA_90_MODPROPNULLABLE        0x00000442L
// MessageId: SCHEMA_91_MODPROPNNULLABLE
// MessageText:
// Unsupported Schema modification; Cannot change property '%1$ls' to be not nullable
#define SCHEMA_91_MODPROPNNULLABLE       0x00000443L
// MessageId: SCHEMA_92_MODDATAPRECISION
// MessageText:
// Unsupported Schema modification; Cannot change precision for data property '%1$ls' from '%2$d' to '%3$d'
#define SCHEMA_92_MODDATAPRECISION       0x00000444L
// MessageId: SCHEMA_93_MODDATASCALE
// MessageText:
// Unsupported Schema modification; Cannot change scale for data property '%1$ls' from '%2$d' to '%3$d'
#define SCHEMA_93_MODDATASCALE           0x00000445L
// MessageId: SCHEMA_94_MODDATAAUTOGEN
// MessageText:
// Unsupported Schema modification; Cannot change autogeneration setting for data property '%1$ls'
#define SCHEMA_94_MODDATAAUTOGEN         0x00000446L
// MessageId: SCHEMA_95_MODPROPRDONLY
// MessageText:
// Unsupported Schema modification; Cannot change property '%1$ls' to be read-only
#define SCHEMA_95_MODPROPRDONLY          0x00000447L
// MessageId: SCHEMA_96_MODPROPWRITABLE
// MessageText:
// Unsupported Schema modification; Cannot change property '%1$ls' to be writable
#define SCHEMA_96_MODPROPWRITABLE        0x00000448L
// MessageId: SCHEMA_97_BADCONSTRAINTTYPE
// MessageText:
// Cannot modify constraint for data property '%1$ls'; unknown constraint type: %2$d
#define SCHEMA_97_BADCONSTRAINTTYPE      0x00000449L
// MessageId: SCHEMA_98_MODDATACONSTRAINT
// MessageText:
// Unsupported Schema modification; Cannot change constraint for data property '%1$ls'
#define SCHEMA_98_MODDATACONSTRAINT      0x0000044AL
// MessageId: SCHEMA_99_MODGEOMTYPES
// MessageText:
// Unsupported Schema modification; Cannot change geometry types for geometric property '%1$ls'
#define SCHEMA_99_MODGEOMTYPES           0x0000044BL
// MessageId: SCHEMA_100_MODGEOMELEVATION
// MessageText:
// Unsupported Schema modification; Cannot add/remove elevation dimension to/from geometric property '%1$ls'
#define SCHEMA_100_MODGEOMELEVATION      0x0000044CL
// MessageId: SCHEMA_101_MODGEOMMEASURE
// MessageText:
// Unsupported Schema modification; Cannot add/remove measure dimension to/from geometric property '%1$ls'
#define SCHEMA_101_MODGEOMMEASURE        0x0000044DL
// MessageId: SCHEMA_102_MODPROPSC
// MessageText:
// Unsupported Schema modification; Cannot change spatial context for property '%1$ls' from '%2$ls' to '%3$ls'
#define SCHEMA_102_MODPROPSC             0x0000044EL
// MessageId: SCHEMA_103_MODASSOCCLASS
// MessageText:
// Unsupported Schema modification; Cannot change associated class for association property '%1$ls' from '%2$ls' to '%3$ls'
#define SCHEMA_103_MODASSOCCLASS         0x0000044FL
// MessageId: SCHEMA_104_MODASSOCREVNAME
// MessageText:
// Unsupported Schema modification; Cannot change reverse name for association property '%1$ls' from '%2$ls' to '%3$ls'
#define SCHEMA_104_MODASSOCREVNAME       0x00000450L
// MessageId: SCHEMA_105_MODASSOCDELRULE
// MessageText:
// Unsupported Schema modification; Cannot change delete rule for association property '%1$ls'
#define SCHEMA_105_MODASSOCDELRULE       0x00000451L
// MessageId: SCHEMA_106_MODASSOCCASCLOCK
// MessageText:
// Unsupported Schema modification; Cannot change cascade lock setting for association property '%1$ls'
#define SCHEMA_106_MODASSOCCASCLOCK      0x00000452L
// MessageId: SCHEMA_107_MODASSOCMULT
// MessageText:
// Unsupported Schema modification; Cannot change multiplicity for association property '%1$ls' from '%2$ls' to '%3$ls'
#define SCHEMA_107_MODASSOCMULT          0x00000453L
// MessageId: SCHEMA_108_MODASSOCREVMULT
// MessageText:
// Unsupported Schema modification; Cannot change reverse multiplicity for association property '%1$ls' from '%2$ls' to '%3$ls'
#define SCHEMA_108_MODASSOCREVMULT       0x00000454L
// MessageId: SCHEMA_109_MODASSOCID
// MessageText:
// Unsupported Schema modification; Cannot change identity properties for association property '%1$ls' from (%2$ls) to (%3$ls)
#define SCHEMA_109_MODASSOCID            0x00000455L
// MessageId: SCHEMA_110_MODREVASSOCID
// MessageText:
// Unsupported Schema modification; Cannot change reverse identity properties for association property '%1$ls' from (%2$ls) to (%3$ls)
#define SCHEMA_110_MODREVASSOCID         0x00000456L
// MessageId: SCHEMA_111_MODOBJCLASS
// MessageText:
// Unsupported Schema modification; Cannot change class for object property '%1$ls' from '%2$ls' to '%3$ls'
#define SCHEMA_111_MODOBJCLASS           0x00000457L
// MessageId: SCHEMA_112_MODOBJID
// MessageText:
// Unsupported Schema modification; Cannot change identity property for object property '%1$ls' from '%2$ls' to '%3$ls'
#define SCHEMA_112_MODOBJID              0x00000458L
// MessageId: SCHEMA_113_MODOBJTYPE
// MessageText:
// Unsupported Schema modification; Cannot change object type for object property '%1$ls'
#define SCHEMA_113_MODOBJTYPE            0x00000459L
// MessageId: SCHEMA_114_MODOBJORDERTYPE
// MessageText:
// Unsupported Schema modification; Cannot change order type for object property '%1$ls'
#define SCHEMA_114_MODOBJORDERTYPE       0x0000045AL
// MessageId: SCHEMA_115_MODRASTERMODEL
// MessageText:
// Unsupported Schema modification; Cannot change default data model for raster property '%1$ls'
#define SCHEMA_115_MODRASTERMODEL        0x0000045BL
// MessageId: SCHEMA_116_MODRASTERX
// MessageText:
// Unsupported Schema modification; Cannot change default image X size for raster property '%1$ls' from '%2$d' to '%3$d'
#define SCHEMA_116_MODRASTERX            0x0000045CL
// MessageId: SCHEMA_117_MODRASTERY
// MessageText:
// Unsupported Schema modification; Cannot change default image Y size for raster property '%1$ls' from '%2$d' to '%3$d'
#define SCHEMA_117_MODRASTERY            0x0000045DL
// MessageId: SCHEMA_118_SCHEMAEXISTS
// MessageText:
// Cannot add feature schema '%1$ls'; it already exists
#define SCHEMA_118_SCHEMAEXISTS          0x0000045EL
// MessageId: SCHEMA_119_SCHEMANOTEXISTS
// MessageText:
// Cannot modify feature schema '%1$ls'; it does not exist
#define SCHEMA_119_SCHEMANOTEXISTS       0x0000045FL
// MessageId: SCHEMA_120_ADDSCHEMA
// MessageText:
// Cannot add feature schema '%1$ls'; multiple schemas not supported
#define SCHEMA_120_ADDSCHEMA             0x00000460L
// MessageId: SCHEMA_121_DELSCHEMA
// MessageText:
// Unsupport Schema modification; Cannot delete feature schema '%1$ls'
#define SCHEMA_121_DELSCHEMA             0x00000461L
// MessageId: SCHEMA_122_ADDCLASS
// MessageText:
// Unsupport Schema modification; Cannot add class definition '%1$ls'
#define SCHEMA_122_ADDCLASS              0x00000462L
// MessageId: SCHEMA_123_DELCLASS
// MessageText:
// Unsupport Schema modification; Cannot delete class definition '%1$ls'
#define SCHEMA_123_DELCLASS              0x00000463L
// MessageId: SCHEMA_124_ADDPROP
// MessageText:
// Unsupport Schema modification; Cannot add property '%1$ls'
#define SCHEMA_124_ADDPROP               0x00000464L
// MessageId: SCHEMA_125_DELPROP
// MessageText:
// Unsupport Schema modification; Cannot delete property '%1$ls'
#define SCHEMA_125_DELPROP               0x00000465L
// MessageId: SCHEMA_126_DELBASECLASS
// MessageText:
// Cannot delete class '%1$ls'; it is the base class for '%2$ls'
#define SCHEMA_126_DELBASECLASS          0x00000466L
// MessageId: SCHEMA_127_DELOBJCLASS
// MessageText:
// Cannot delete class '%1$ls'; it is the class for object property '%2$ls'
#define SCHEMA_127_DELOBJCLASS           0x00000467L
// MessageId: SCHEMA_128_DELCLASSID
// MessageText:
// Cannot delete property '%1$ls'; it is an identity property for class '%2$ls'
#define SCHEMA_128_DELCLASSID            0x00000468L
// MessageId: SCHEMA_129_DELOBJID
// MessageText:
// Cannot delete property '%1$ls'; it is an identity property for object property '%2$ls'
#define SCHEMA_129_DELOBJID              0x00000469L
// MessageId: SCHEMA_130_DELASSOCCLASS
// MessageText:
// Cannot delete class '%1$ls'; it is the associated class for association property '%2$ls'
#define SCHEMA_130_DELASSOCCLASS         0x0000046AL
// MessageId: SCHEMA_131_DELASSOCID
// MessageText:
// Cannot delete property '%1$ls'; it is an identity property for association property '%2$ls'
#define SCHEMA_131_DELASSOCID            0x0000046BL
// MessageId: SCHEMA_132_DELASSOCREVID
// MessageText:
// Cannot delete property '%1$ls'; it is a reverse identity property for association property '%2$ls'
#define SCHEMA_132_DELASSOCREVID         0x0000046CL
// MessageId: SCHEMA_133_DELLAYERCLASS
// MessageText:
// Cannot delete class '%1$ls'; it is the network layer class for network class '%2$ls'
#define SCHEMA_133_DELLAYERCLASS         0x0000046DL
// MessageId: SCHEMA_134_DELNETCOST
// MessageText:
// Cannot delete property '%1$ls'; it is the cost property for network feature class '%2$ls'
#define SCHEMA_134_DELNETCOST            0x0000046EL
// MessageId: SCHEMA_135_DELFEATNET
// MessageText:
// Cannot delete property '%1$ls'; it is the network class property for network feature class '%2$ls'
#define SCHEMA_135_DELFEATNET            0x0000046FL
// MessageId: SCHEMA_136_DELREFFEAT
// MessageText:
// Cannot delete property '%1$ls'; it is the referenced feature property for network feature class '%2$ls'
#define SCHEMA_136_DELREFFEAT            0x00000470L
// MessageId: SCHEMA_137_DELNETPARENT
// MessageText:
// Cannot delete property '%1$ls'; it is the parent network feature property for network feature class '%2$ls'
#define SCHEMA_137_DELNETPARENT          0x00000471L
// MessageId: SCHEMA_138_DELSTARTNODE
// MessageText:
// Cannot delete property '%1$ls'; it is the start node property for network link feature class '%2$ls'
#define SCHEMA_138_DELSTARTNODE          0x00000472L
// MessageId: SCHEMA_139_DELENDNODE
// MessageText:
// Cannot delete property '%1$ls'; it is the end node property for network link feature class '%2$ls'
#define SCHEMA_139_DELENDNODE            0x00000473L
// MessageId: SCHEMA_140_DELNODELAYER
// MessageText:
// Cannot delete property '%1$ls'; it is the layer property for network node feature class '%2$ls'
#define SCHEMA_140_DELNODELAYER          0x00000474L
// MessageId: SCHEMA_141_BASETYPECONFLICT
// MessageText:
// Cannot set base class for '%1$ls' to '%2$ls'; they have different class types
#define SCHEMA_141_BASETYPECONFLICT      0x00000475L
// MessageId: SCHEMA_142_DELFEATGEOM
// MessageText:
// Cannot delete property '%1$ls'; it is the geometry property for feature class '%2$ls'
#define SCHEMA_142_DELFEATGEOM           0x00000476L
// MessageId: SCHEMA_143_DELCLASSOBJECTS
// MessageText:
// Cannot delete class definition '%1$ls'; it has objects
#define SCHEMA_143_DELCLASSOBJECTS       0x00000477L
// MessageId: SCHEMA_144_ADDPROPOBJECTS
// MessageText:
// Cannot add not-nullable property '%1$ls'; its class has objects
#define SCHEMA_144_ADDPROPOBJECTS        0x00000478L
// MessageId: SCHEMA_145_DELPROPOBJECTS
// MessageText:
// Cannot delete a property '%1$ls'; its class has objects
#define SCHEMA_145_DELPROPOBJECTS        0x00000479L
// MessageId: SCHEMA_146_DELSCHEMAOBJECTS
// MessageText:
// Cannot delete schema definition '%1$ls'; it has objects
#define SCHEMA_146_DELSCHEMAOBJECTS      0x0000047AL
// MessageId: SCHEMA_147_MODCONSTRAINT
// MessageText:
// Cannot modify constraint for property '%1$ls'; property has values and new constraint is more restrictive
#define SCHEMA_147_MODCONSTRAINT         0x0000047BL
// MessageId: SCHEMA_148_MODCONSTRAINTTYPE
// MessageText:
// Cannot modify constraint type for property '%1$ls'; property has values
#define SCHEMA_148_MODCONSTRAINTTYPE     0x0000047CL
// MessageId: SCHEMA_149_CONSTRAINTDATAVIOLATION
// MessageText:
// Cannot modify constraint for property '%1$ls'; existing data value '%2$ls' violates new constraint
#define SCHEMA_149_CONSTRAINTDATAVIOLATION 0x0000047DL
// MessageId: SCHEMA_150_DEFAULTVALUEVIOLATION
// MessageText:
// Data Property %1$ls default value '%2$ls' is not a valid %3$ls
#define SCHEMA_150_DEFAULTVALUEVIOLATION 0x0000047EL
// MessageId: SCHEMA_151_DEFAULTDATEVIOLATION
// MessageText:
// Data Property %1$ls default value '%2$ls' is not an FDO datetime; must be "TIMESTAMP 'YYYY-MM-DD HH24:MI:SS'", "DATE 'YYYY-MM-DD'" or "TIME 'HH24:MM:SS'"
#define SCHEMA_151_DEFAULTDATEVIOLATION  0x0000047FL
// MessageId: EXPRESSION_1_BLOBVALUENULL
// MessageText:
// BLOBValue is null.
#define EXPRESSION_1_BLOBVALUENULL       0x000007D1L
// MessageId: EXPRESSION_2_BOOLEANVALUENULL
// MessageText:
// BooleanValue is null.
#define EXPRESSION_2_BOOLEANVALUENULL    0x000007D2L
// MessageId: EXPRESSION_3_BYTEVALUENULL
// MessageText:
// ByteValue is null.
#define EXPRESSION_3_BYTEVALUENULL       0x000007D3L
// MessageId: EXPRESSION_4_CLOBVALUENULL
// MessageText:
// CLOBValue is null.
#define EXPRESSION_4_CLOBVALUENULL       0x000007D4L
// MessageId: EXPRESSION_5_DATETIMEVALUENULL
// MessageText:
// DateTimeValue is null.
#define EXPRESSION_5_DATETIMEVALUENULL   0x000007D5L
// MessageId: EXPRESSION_6_DECIMALVALUENULL
// MessageText:
// DecimalValue is null.
#define EXPRESSION_6_DECIMALVALUENULL    0x000007D6L
// MessageId: EXPRESSION_7_DOUBLEVALUENULL
// MessageText:
// DoubleValue is null.
#define EXPRESSION_7_DOUBLEVALUENULL     0x000007D7L
// MessageId: EXPRESSION_8_INCOMPLETEBINARYEXPRESSION
// MessageText:
// Incomplete binary expression.
#define EXPRESSION_8_INCOMPLETEBINARYEXPRESSION 0x000007D8L
// MessageId: EXPRESSION_9_INCOMPLETEFUNCTION
// MessageText:
// Incomplete function.
#define EXPRESSION_9_INCOMPLETEFUNCTION  0x000007D9L
// MessageId: EXPRESSION_10_INCOMPLETEPARAMETER
// MessageText:
// Incomplete parameter.
#define EXPRESSION_10_INCOMPLETEPARAMETER 0x000007DAL
// MessageId: EXPRESSION_11_INCOMPLETEUNARYEXPRESSION
// MessageText:
// Incomplete unary expression.
#define EXPRESSION_11_INCOMPLETEUNARYEXPRESSION 0x000007DBL
// MessageId: EXPRESSION_12_INT16VALUENULL
// MessageText:
// Int16Value is null.
#define EXPRESSION_12_INT16VALUENULL     0x000007DCL
// MessageId: EXPRESSION_13_INT32VALUENULL
// MessageText:
// Int32Value is null.
#define EXPRESSION_13_INT32VALUENULL     0x000007DDL
// MessageId: EXPRESSION_14_INT64VALUENULL
// MessageText:
// Int64Value is null.
#define EXPRESSION_14_INT64VALUENULL     0x000007DEL
// MessageId: EXPRESSION_15_INVALIDDATAVALUE
// MessageText:
// Invalid data type.
#define EXPRESSION_15_INVALIDDATAVALUE   0x000007DFL
// MessageId: EXPRESSION_16_NULLIDENTIFIER
// MessageText:
// Null identifier.
#define EXPRESSION_16_NULLIDENTIFIER     0x000007E0L
// MessageId: EXPRESSION_17_STRINGNOTEXPRESSION
// MessageText:
// String does not represent a valid expression.
#define EXPRESSION_17_STRINGNOTEXPRESSION 0x000007E1L
// MessageId: EXPRESSION_18_SINGLEVALUENULL
// MessageText:
// SingleValue is null.
#define EXPRESSION_18_SINGLEVALUENULL    0x000007E2L
// MessageId: EXPRESSION_19_STRINGVALUENULL
// MessageText:
// StringValue is null.
#define EXPRESSION_19_STRINGVALUENULL    0x000007E3L
// MessageId: EXPRESSION_20_STRINGNOTVALUEEXPRESSION
// MessageText:
// String does not represent a valid value expression.
#define EXPRESSION_20_STRINGNOTVALUEEXPRESSION 0x000007E4L
// MessageId: EXPRESSION_21_VALUETRUNCATED
// MessageText:
// Cannot convert value %1$s to %2$ls; it is outside the range [%3$s, %4$s]
#define EXPRESSION_21_VALUETRUNCATED     0x000007E5L
// MessageId: EXPRESSION_22_INCOMPATIBLEDATATYPES
// MessageText:
// Cannot convert value %1$s from %2$ls to %3$ls; incompatible data types
#define EXPRESSION_22_INCOMPATIBLEDATATYPES 0x000007E6L
// MessageId: EXPRESSION_23_VALUESHIFTED
// MessageText:
// Cannot convert value %1$s to %2$ls without loss of precision
#define EXPRESSION_23_VALUESHIFTED       0x000007E7L
// MessageId: EXPRESSION_24_BOOLEANTRUNCATED
// MessageText:
// Cannot convert value %1$s to boolean; it must be 0 or 1
#define EXPRESSION_24_BOOLEANTRUNCATED   0x000007E8L
// MessageId: FILTER_1_INCOMPLETEBINARYOPERATOR
// MessageText:
// Incomplete binary logical operator.
#define FILTER_1_INCOMPLETEBINARYOPERATOR 0x00000BB9L
// MessageId: FILTER_2_INCOMPLETECOMPARISONCONDITION
// MessageText:
// Incomplete comparison condition.
#define FILTER_2_INCOMPLETECOMPARISONCONDITION 0x00000BBAL
// MessageId: FILTER_3_INCOMPLETEDISTANCECONDITION
// MessageText:
// Incomplete distance condition.
#define FILTER_3_INCOMPLETEDISTANCECONDITION 0x00000BBBL
// MessageId: FILTER_4_INCOMPLETEINCONDITION
// MessageText:
// Incomplete in condition.
#define FILTER_4_INCOMPLETEINCONDITION   0x00000BBCL
// MessageId: FILTER_5_INCOMPLETENULLCONDITION
// MessageText:
// Incomplete null condition.
#define FILTER_5_INCOMPLETENULLCONDITION 0x00000BBDL
// MessageId: FILTER_6_INCOMPLETESPATIALCONDITION
// MessageText:
// Incomplete spatial condition.
#define FILTER_6_INCOMPLETESPATIALCONDITION 0x00000BBEL
// MessageId: FILTER_7_INCOMPLETEUNARYOPERATOR
// MessageText:
// Incomplete unary logical operator.
#define FILTER_7_INCOMPLETEUNARYOPERATOR 0x00000BBFL
// MessageId: FILTER_8_INVALIDFILTERSTRING
// MessageText:
// Invalid filter string.
#define FILTER_8_INVALIDFILTERSTRING     0x00000BC0L
// MessageId: FILTER_9_STRINGNOTFILTER
// MessageText:
// String does not represent a valid filter.
#define FILTER_9_STRINGNOTFILTER         0x00000BC1L
// MessageId: COMMANDS_1_INVALIDIDENTIFIERNAME
// MessageText:
// Invalid identifier name '%1$ls'.
#define COMMANDS_1_INVALIDIDENTIFIERNAME 0x00000FA1L
// MessageId: COMMANDS_2_INVALIDPARAMETERVALUENAME
// MessageText:
// Invalid parameter value name '%1$ls'.
#define COMMANDS_2_INVALIDPARAMETERVALUENAME 0x00000FA2L
// MessageId: COMMANDS_3_INVALIDPROPERTYVALUENAME
// MessageText:
// Invalid property value name '%1$ls'.
#define COMMANDS_3_INVALIDPROPERTYVALUENAME 0x00000FA3L
// MessageId: COMMANDS_4_INVALIDPROVIDERNAME
// MessageText:
// Schema Override set for schema '%1$ls' has invalid provider name '%2$ls'; must be of the form: Company.Provider.Version.
#define COMMANDS_4_INVALIDPROVIDERNAME   0x00000FA4L
// MessageId: COMMANDS_5_OVERRIDEPROVIDERMISMATCH
// MessageText:
// Registered provider '%1$ls' is registered with library for provider '%2$ls'.
#define COMMANDS_5_OVERRIDEPROVIDERMISMATCH 0x00000FA5L
// MessageId: COMMANDS_6_MISSINGPROVIDERNAME
// MessageText:
// Schema Override set for schema '%1$ls' has no provider name.
#define COMMANDS_6_MISSINGPROVIDERNAME   0x00000FA6L
// MessageId: COMMANDS_7_OBJECTHASPARENT
// MessageText:
// Schema Override '%1$ls' already has parent.
#define COMMANDS_7_OBJECTHASPARENT       0x00000FA7L
// MessageId: COMMANDS_8_BADMAPPINGSUBELEMENT
// MessageText:
// Element '%1$ls' not allowed inside %2$ls Schema Mapping element %3$ls[@name='%4$ls'].
#define COMMANDS_8_BADMAPPINGSUBELEMENT  0x00000FA8L
// MessageId: COMMANDS_9_MULTIMAPPINGSUBELEMENT
// MessageText:
// Multiple instances of Element '%1$ls' not allowed inside %2$ls Schema Mapping element %3$ls[@name='%4$ls'].
#define COMMANDS_9_MULTIMAPPINGSUBELEMENT 0x00000FA9L
// MessageId: COMMANDS_10_CHOICESUBELEMENT
// MessageText:
// Only one of '%1$ls' allowed inside %2$ls Schema Mapping element %3$ls[@name='%4$ls'].
#define COMMANDS_10_CHOICESUBELEMENT     0x00000FAAL
// MessageId: COMMANDS_11_OWNPARENT
// MessageText:
// Element '%1$ls' cannot be its own parent/grandparent.
#define COMMANDS_11_OWNPARENT            0x00000FABL
// MessageId: COMMANDS_12_DUPLICATESUBELEMENT
// MessageText:
// Only one of '%1$ls[@name=%2$ls]' allowed inside %3$ls Schema Mapping element %4$ls[@name='%5$ls'].
#define COMMANDS_12_DUPLICATESUBELEMENT  0x00000FACL
// MessageId: PARSE_1_INVALIDDIGIT
// MessageText:
// Invalid digit in number.
#define PARSE_1_INVALIDDIGIT             0x00001389L
// MessageId: PARSE_2_INVALIDDATETIME
// MessageText:
// Invalid DateTime value.
#define PARSE_2_INVALIDDATETIME          0x0000138AL
// MessageId: PARSE_3_DATETIMEOUTOFRANGE
// MessageText:
// DateTime value out of range.
#define PARSE_3_DATETIMEOUTOFRANGE       0x0000138BL
// MessageId: PARSE_4_STRINGINCORRECTLYFORMATTED
// MessageText:
// String incorrectly formatted.
#define PARSE_4_STRINGINCORRECTLYFORMATTED 0x0000138CL
// MessageId: PARSE_5_STRINGTOOLONG
// MessageText:
// String too long.
#define PARSE_5_STRINGTOOLONG            0x0000138DL
// MessageId: PARSE_6_MISSINGQUOTE_d
// MessageText:
// Unmatched quote following quotation mark at column %1$d.
#define PARSE_6_MISSINGQUOTE_d           0x0000138EL
// MessageId: PARSE_7_INVALIDHEXDIGIT
// MessageText:
// Invalid hex digit.
#define PARSE_7_INVALIDHEXDIGIT          0x0000138FL
// MessageId: PARSE_8_INVALIDBITDIGIT
// MessageText:
// Invalid bit digit.
#define PARSE_8_INVALIDBITDIGIT          0x00001390L
// MessageId: PARSE_9_WRONGTOKEN
// MessageText:
// Wrong token.
#define PARSE_9_WRONGTOKEN               0x00001391L
// MessageId: SC_1_XMLNONAME
// MessageText:
// Current spatial context has no name; cannot write to XML.
#define SC_1_XMLNONAME                   0x00001771L
// MessageId: SC_2_NOSTATETRANSITION
// MessageText:
// Error in SCReadHandler state transition table, no transition after element '%1$ls'.
#define SC_2_NOSTATETRANSITION           0x00001772L
// MessageId: SC_3_XMLNOEXTENTS
// MessageText:
// Current spatial context '%1$ls' has no extents; cannot write to XML.
#define SC_3_XMLNOEXTENTS                0x00001773L
// MessageId: SC_4_XMLNOREAD
// MessageText:
// %1$ls failed: no spatial context has been read from XML.
#define SC_4_XMLNOREAD                   0x00001774L
// MessageId: SC_5_MISSINGATTRIBUTE
// MessageText:
// Error reading spatial context %1$ls from XML, required attribute %2$ls/@%3$ls is missing.
#define SC_5_MISSINGATTRIBUTE            0x00001775L
// MessageId: SC_6_BADATTRIBUTE
// MessageText:
// Error reading spatial context %1$ls from XML, invalid attribute %2$ls/@%3$ls value '%4$ls'.
#define SC_6_BADATTRIBUTE                0x00001776L
// MessageId: SC_7_NAMEIDDIFF
// MessageText:
// Error reading spatial context %1$ls from XML, gml:id '%2$ls' differs from srsName.
#define SC_7_NAMEIDDIFF                  0x00001777L
// MessageId: SC_8_BADELEMENT
// MessageText:
// Error reading spatial context %1$ls from XML, invalid %2$ls value '%3$ls'.
#define SC_8_BADELEMENT                  0x00001778L
// MessageId: SC_9_BADSUBELEMENT
// MessageText:
// Error reading spatial context %1$ls from XML, unexpected first element %2$ls inside '%3$ls'.
#define SC_9_BADSUBELEMENT               0x00001779L
// MessageId: SC_10_BADNEXTELEMENT
// MessageText:
// Error reading spatial context %1$ls from XML, unexpected element %2$ls after '%3$ls'.
#define SC_10_BADNEXTELEMENT             0x0000177AL
// MessageId: SC_11_MISSINGNEXTELEMENT
// MessageText:
// Error reading spatial context %1$ls from XML, expected element %2$ls after '%3$ls'.
#define SC_11_MISSINGNEXTELEMENT         0x0000177BL
// MessageId: SC_12_EMPTYELEMENT
// MessageText:
// Error reading spatial context %1$ls from XML, element %2$ls has no sub-elements.
#define SC_12_EMPTYELEMENT               0x0000177CL
// MessageId: SC_13_NAMEIDDIFF
// MessageText:
// Error reading spatial context %1$ls from XML, gml:baseCRS/fdo:WKTCRS/gml:id '%2$ls' differs from gml:baseCRS/fdo:WKTCRS/srsName.
#define SC_13_NAMEIDDIFF                 0x0000EA6DL
// MessageId: SC_14_EMPTYBASECRS
// MessageText:
// Error reading spatial context %1$ls from XML, gml:baseCRS subelement must have an xlink:href attribute or fdo:WKTCRS subelement.
#define SC_14_EMPTYBASECRS               0x0000177EL
// MessageId: SC_15_NEEDCALLREADNEXT
// MessageText:
// Error reading from feature reader, need to call ReadNext before getting property.
#define SC_15_NEEDCALLREADNEXT           0x0000177FL
// MessageId: SC_16_INDEXOUTOFBOUND
// MessageText:
// Error reading from feature reader, reach end in the feature collection.
#define SC_16_INDEXOUTOFBOUND            0x00001780L
// MessageId: CLNT_1_NULLINPUTPOINTER
// MessageText:
// NULL Input Pointer
#define CLNT_1_NULLINPUTPOINTER          0x00001B59L
// MessageId: CLNT_2_EMPTYINPUTPARAMETER
// MessageText:
// Empty Input Parameter
#define CLNT_2_EMPTYINPUTPARAMETER       0x00001B5AL
// MessageId: CLNT_3_NULLPOINTER
// MessageText:
// NULL Pointer
#define CLNT_3_NULLPOINTER               0x00001B5BL
// MessageId: CLNT_4_PROVIDERNOTREGISTERED
// MessageText:
// FDO Provider Not Registered
#define CLNT_4_PROVIDERNOTREGISTERED     0x00001B5CL
// MessageId: CLNT_5_OUTOFMEMORY
// MessageText:
// Out Of Memory
#define CLNT_5_OUTOFMEMORY               0x00001B5DL
// MessageId: CLNT_6_INVALIDINPUTPARAMETER
// MessageText:
// Invalid Input Parameter
#define CLNT_6_INVALIDINPUTPARAMETER     0x00001B5EL
// MessageId: CLNT_7_FAILURE
// MessageText:
// Action Failed
#define CLNT_7_FAILURE                   0x00001B5FL
// MessageId: CLNT_8_UNABLE_TO_LOAD_LIBRARY
// MessageText:
// Unable to load the FDO Provider: %1$s
#define CLNT_8_UNABLE_TO_LOAD_LIBRARY    0x00001B60L
// MessageId: CLNT_9_INVALID_PROVIDER_ENTRY_POINT
// MessageText:
// FDO Provider entry point function 'CreateConnection' was not found.
#define CLNT_9_INVALID_PROVIDER_ENTRY_POINT 0x00001B61L
// MessageId: CLNT_10_NULL_CONNECTION_FROM_PROVIDER
// MessageText:
// FDO Provider entry point function 'CreateConnection' returned NULL.
#define CLNT_10_NULL_CONNECTION_FROM_PROVIDER 0x00001B62L
// MessageId: CLNT_11_PARSER_ERROR
// MessageText:
// Parser Error
#define CLNT_11_PARSER_ERROR             0x00001B63L
// MessageId: CLNT_12_FILE_NOT_EXISTS
// MessageText:
// File '%1$ls' does not exist
#define CLNT_12_FILE_NOT_EXISTS          0x00001B64L
// MessageId: CLNT_13_UNKNOWN_MESSAGE
// MessageText:
// Unknown message id: %1$d
#define CLNT_13_UNKNOWN_MESSAGE          0x00001B65L
// MessageId: CLNT_14_XML_ERROR
// MessageText:
// Error in registry file '%1$ls', line %2$d: %3$s
#define CLNT_14_XML_ERROR                0x00001B66L
// MessageId: CLNT_15_XML_WRITE_ERROR
// MessageText:
// Error writing to registry file '%1$ls', %2$s
#define CLNT_15_XML_WRITE_ERROR          0x00001B67L
// MessageId: FUNCTION_CEIL
// MessageText:
// Determines the smallest integer greater than or equal to the expression value
#define FUNCTION_CEIL                    0x00001F41L
// MessageId: FUNCTION_FLOOR
// MessageText:
// Returns the largest integer equal to or less than the expression value
#define FUNCTION_FLOOR                   0x00001F42L
// MessageId: FUNCTION_AVG
// MessageText:
// Determines the average value of an expression
#define FUNCTION_AVG                     0x00001F43L
// MessageId: FUNCTION_COUNT
// MessageText:
// Determines the number of objects in the query
#define FUNCTION_COUNT                   0x00001F44L
// MessageId: FUNCTION_MAX
// MessageText:
// Determines the maximum value of an expression
#define FUNCTION_MAX                     0x00001F45L
// MessageId: FUNCTION_MIN
// MessageText:
// Returns the minimum value of an expression
#define FUNCTION_MIN                     0x00001F46L
// MessageId: FUNCTION_SUM
// MessageText:
// Returns the sum of values of an expression
#define FUNCTION_SUM                     0x00001F47L
// MessageId: FUNCTION_LOWER
// MessageText:
// Converts all uppercase letters in a string expression into lowercase letters
#define FUNCTION_LOWER                   0x00001F48L
// MessageId: FUNCTION_UPPER
// MessageText:
// Converts all lowercase letters in a string expression into uppercase letters
#define FUNCTION_UPPER                   0x00001F49L
// MessageId: FUNCTION_CONCAT
// MessageText:
// Returns the string concatenation of 2 expressions
#define FUNCTION_CONCAT                  0x00001F4AL
// MessageId: FUNCTION_DBL_ARG
// MessageText:
// Argument that represents a double
#define FUNCTION_DBL_ARG                 0x00001F4BL
// MessageId: FUNCTION_INT_ARG
// MessageText:
// Argument that represents an integer
#define FUNCTION_INT_ARG                 0x00001F4CL
// MessageId: FUNCTION_STR_ARG
// MessageText:
// Argument that represents a string
#define FUNCTION_STR_ARG                 0x00001F4DL
// MessageId: FUNCTION_SPATIALEXTENTS
// MessageText:
// Returns the spatial extents of values of a geometric expression
#define FUNCTION_SPATIALEXTENTS          0x00001F4EL
// MessageId: FUNCTION_GEOM_ARG
// MessageText:
// Argument that represents a geometry
#define FUNCTION_GEOM_ARG                0x00001F4FL
// MessageId: FUNCTION_BOOL_ARG
// MessageText:
// Argument that represents a boolean
#define FUNCTION_BOOL_ARG                0x00001F50L
// MessageId: FUNCTION_BYTE_ARG
// MessageText:
// Argument that represents a byte
#define FUNCTION_BYTE_ARG                0x00001F51L
// MessageId: FUNCTION_DT_ARG
// MessageText:
// Argument that represents a date-time value
#define FUNCTION_DT_ARG                  0x00001F52L
// MessageId: FUNCTION_DEC_ARG
// MessageText:
// Argument that represents a decimal
#define FUNCTION_DEC_ARG                 0x00001F53L
// MessageId: FUNCTION_INT16_ARG
// MessageText:
// Argument that represents a 16-bit integer
#define FUNCTION_INT16_ARG               0x00001F54L
// MessageId: FUNCTION_INT32_ARG
// MessageText:
// Argument that represents a 32-bit integer
#define FUNCTION_INT32_ARG               0x00001F55L
// MessageId: FUNCTION_INT64_ARG
// MessageText:
// Argument that represents a 64-bit integer
#define FUNCTION_INT64_ARG               0x00001F56L
// MessageId: FUNCTION_SINGLE_ARG
// MessageText:
// Argument that represents a single value
#define FUNCTION_SINGLE_ARG              0x00001F57L
// MessageId: FUNCTION_BLOB_ARG
// MessageText:
// Argument that represents a BLOB value
#define FUNCTION_BLOB_ARG                0x00001F58L
// MessageId: FUNCTION_CLOB_ARG
// MessageText:
// Argument that represents a CLOB value
#define FUNCTION_CLOB_ARG                0x00001F59L
// MessageId: FUNCTION_ASSOCIATION_ARG
// MessageText:
// Argument that represents an association
#define FUNCTION_ASSOCIATION_ARG         0x00001F5AL
// MessageId: FUNCTION_OBJECT_ARG
// MessageText:
// Argument that represents an object
#define FUNCTION_OBJECT_ARG              0x00001F5BL
// MessageId: FUNCTION_RASTER_ARG
// MessageText:
// Argument that represents a raster
#define FUNCTION_RASTER_ARG              0x00001F5CL
// MessageId: FUNCTION_GENERAL_ARG
// MessageText:
// Argument to be processed
#define FUNCTION_GENERAL_ARG             0x00001F5DL
// MessageId: FUNCTION_OPERATOR_ARG
// MessageText:
// Operation indicator (ALL or DISTINCT)
#define FUNCTION_OPERATOR_ARG            0x00001F5EL
// MessageId: FUNCTION_OPERATOR_ARG_LIT
// MessageText:
// Operation Indicator
#define FUNCTION_OPERATOR_ARG_LIT        0x00001F5FL
// MessageId: FUNCTION_BYTE_ARG_LIT
// MessageText:
// byte
#define FUNCTION_BYTE_ARG_LIT            0x00001F60L
// MessageId: FUNCTION_DATE_ARG_LIT
// MessageText:
// date/time
#define FUNCTION_DATE_ARG_LIT            0x00001F61L
// MessageId: FUNCTION_NUMBER_ARG_LIT
// MessageText:
// number
#define FUNCTION_NUMBER_ARG_LIT          0x00001F62L
// MessageId: FUNCTION_STRING_ARG_LIT
// MessageText:
// text property
#define FUNCTION_STRING_ARG_LIT          0x00001F63L
// MessageId: FUNCTION_PARAMETER_NUMBER_ERROR
// MessageText:
// Expression Engine: Invalid number of parameters for function '%1$ls'
#define FUNCTION_PARAMETER_NUMBER_ERROR  0x00001F64L
// MessageId: FUNCTION_PARAMETER_ERROR
// MessageText:
// Expression Engine: Invalid parameters for function '%1$ls'
#define FUNCTION_PARAMETER_ERROR         0x00001F65L
// MessageId: FUNCTION_PARAMETER_DATA_TYPE_ERROR
// MessageText:
// Expression Engine: Invalid parameter data type for function '%1$ls'
#define FUNCTION_PARAMETER_DATA_TYPE_ERROR 0x00001F66L
// MessageId: FUNCTION_RESULT_DATA_TYPE_ERROR
// MessageText:
// Expression Engine: Invalid data type for return value for function '%1$ls'
#define FUNCTION_RESULT_DATA_TYPE_ERROR  0x00001F67L
// MessageId: FUNCTION_OPERATOR_ERROR
// MessageText:
// Expression Engine: Invalid operator parameter value for function '%1$ls'
#define FUNCTION_OPERATOR_ERROR          0x00001F68L
// MessageId: FUNCTION_BOOL_ARG_LIT
// MessageText:
// boolean
#define FUNCTION_BOOL_ARG_LIT            0x00001F69L
// MessageId: FUNCTION_BLOB_ARG_LIT
// MessageText:
// blob
#define FUNCTION_BLOB_ARG_LIT            0x00001F6AL
// MessageId: FUNCTION_CLOB_ARG_LIT
// MessageText:
// clob
#define FUNCTION_CLOB_ARG_LIT            0x00001F6BL
// MessageId: FUNCTION_PARAMETER_DISTINCT_ERROR
// MessageText:
// Expression Engine: DISTINCT not allowed for BLOB/CLOB for function '%1$ls'
#define FUNCTION_PARAMETER_DISTINCT_ERROR 0x00001F6CL
// MessageId: FUNCTION_SIGN
// MessageText:
// Returns -1, 0, 1 depending on whether the value is < 0, == 0 or > 0
#define FUNCTION_SIGN                    0x00001F6DL
// MessageId: FUNCTION_CONCAT_STRING1_ARG
// MessageText:
// First string to concatenate
#define FUNCTION_CONCAT_STRING1_ARG      0x00001F6EL
// MessageId: FUNCTION_CONCAT_STRING2_ARG
// MessageText:
// Second string to concatenate
#define FUNCTION_CONCAT_STRING2_ARG      0x00001F6FL
// MessageId: FUNCTION_UPPER_STRING_ARG
// MessageText:
// String to be converted into uppercase
#define FUNCTION_UPPER_STRING_ARG        0x00001F70L
// MessageId: FUNCTION_LOWER_STRING_ARG
// MessageText:
// String to be converted into lowercase
#define FUNCTION_LOWER_STRING_ARG        0x00001F71L
// MessageId: FUNCTION_GEOM_ARG_LIT
// MessageText:
// geometry property
#define FUNCTION_GEOM_ARG_LIT            0x00001F72L
// MessageId: FUNCTION_ABS
// MessageText:
// Determines the absolute value of a numeric expression
#define FUNCTION_ABS                     0x00001F73L
// MessageId: FUNCTION_ACOS
// MessageText:
// Determines the arc cosine of a numeric expression
#define FUNCTION_ACOS                    0x00001F74L
// MessageId: FUNCTION_ASIN
// MessageText:
// Determines the arc sine of a numeric expression
#define FUNCTION_ASIN                    0x00001F75L
// MessageId: FUNCTION_ATAN
// MessageText:
// Determines the arc tangent of a numeric expression
#define FUNCTION_ATAN                    0x00001F76L
// MessageId: FUNCTION_COS
// MessageText:
// Determines the cosine of a numeric expression
#define FUNCTION_COS                     0x00001F77L
// MessageId: FUNCTION_EXP
// MessageText:
// Determines e raised to the power of a numeric expression value
#define FUNCTION_EXP                     0x00001F78L
// MessageId: FUNCTION_LN
// MessageText:
// Determines the natural logarithm of a numeric expression
#define FUNCTION_LN                      0x00001F79L
// MessageText:
// Determines the sine of a numeric expression
#define FUNCTION_SIN                     0x00001F7AL
// MessageId: FUNCTION_SQRT
// MessageText:
// Determines the square root of a numeric expression
#define FUNCTION_SQRT                    0x00001F7BL
// MessageId: FUNCTION_TAN
// MessageText:
// Determines the tangent of a numeric expression
#define FUNCTION_TAN                     0x00001F7CL
// MessageId: FUNCTION_ATAN2
// MessageText:
// Determines the arc tangent of two numeric expressions
#define FUNCTION_ATAN2                   0x00001F7DL
// MessageId: FUNCTION_LOG_BASE_ARG
// MessageText:
// Logarithm base value
#define FUNCTION_LOG_BASE_ARG            0x00001F7EL
// MessageId: FUNCTION_BASE_ARG_LIT
// MessageText:
// base
#define FUNCTION_BASE_ARG_LIT            0x00001F7FL
// MessageId: FUNCTION_DIV_BY_0_ERROR
// MessageText:
// Expression Engine: Attempt to divide by 0 ('%1$ls')
#define FUNCTION_DIV_BY_0_ERROR          0x00001F80L
// MessageId: FUNCTION_DIVISOR_ARG
// MessageText:
// The divisor
#define FUNCTION_DIVISOR_ARG             0x00001F81L
// MessageId: FUNCTION_DIV_ARG_LIT
// MessageText:
// divisor
#define FUNCTION_DIV_ARG_LIT             0x00001F82L
// MessageId: FUNCTION_MOD
// MessageText:
// Determines the remainder of the division of two numeric expressions
#define FUNCTION_MOD                     0x00001F83L
// MessageText:
// Determines the logarithm of two numeric expressions
#define FUNCTION_LOG                     0x00001F84L
// MessageId: FUNCTION_REMAINDER
// MessageText:
#define FUNCTION_REMAINDER               0x00001F85L
// MessageId: FUNCTION_POWER_ARG
// MessageText:
// Represents the power value a number should be raised to
#define FUNCTION_POWER_ARG               0x00001F86L
// MessageText:
// Raises a numeric expression to the power of another numeric expression
#define FUNCTION_POWER                   0x00001F87L
// MessageId: FUNCTION_DATA_VALUE_ERROR
// MessageText:
// Expression Engine: Invalid value for execution of function '%1$ls'
#define FUNCTION_DATA_VALUE_ERROR        0x00001F88L
// MessageId: FUNCTION_ROUND
// MessageText:
// Rounds a numeric expressions to the specified degree
#define FUNCTION_ROUND                   0x00001F89L
// MessageId: FUNCTION_UNEXPECTED_RESULT_ERROR
// MessageText:
// Expression Engine: Unexpected result for function '%1$ls'
#define FUNCTION_UNEXPECTED_RESULT_ERROR 0x00001F8AL
// MessageId: FUNCTION_ROUND_OPT_DECIMAL_ARG
// MessageText:
// Represents an optional number of decimals to round to
#define FUNCTION_ROUND_OPT_DECIMAL_ARG   0x00001F8BL
// MessageId: FUNCTION_OPT_DECIMAL_ARG_LIT
// MessageText:
// optional number of decimals
#define FUNCTION_OPT_DECIMAL_ARG_LIT     0x00001F8CL
// MessageId: FUNCTION_TRUNC
// MessageText:
// Truncates a numeric or date expression as specified
#define FUNCTION_TRUNC                   0x00001F8DL
// MessageId: FUNCTION_TRUNC_OPT_DECIMAL_ARG
// MessageText:
// Represents an optional number of decimals to truncate to
#define FUNCTION_TRUNC_OPT_DECIMAL_ARG   0x00001F8EL
// MessageId: FUNCTION_TRUNC_OPT_DATE_ARG
// MessageText:
// Represents an indicator to what the date to truncate to
#define FUNCTION_TRUNC_OPT_DATE_ARG      0x00001F8FL
// MessageId: FUNCTION_TRUNC_DATE_OP_ARG
// MessageText:
// Truncation indicator (YEAR, MONTH, DAY, HOUR, MINUTE)
#define FUNCTION_TRUNC_DATE_OP_ARG       0x00001F90L
// MessageId: FUNCTION_LENGTH_STRING_ARG
// MessageText:
// String for which to calculate the length
#define FUNCTION_LENGTH_STRING_ARG       0x00001F91L
// MessageText:
// Determines the length of a string expression
#define FUNCTION_LENGTH                  0x00001F92L
// MessageId: FUNCTION_LPAD_STRING_ARG
// MessageText:
// String to pad to the left
#define FUNCTION_LPAD_STRING_ARG         0x00001F93L
// MessageId: FUNCTION_PAD_LENGTH_ARG
// MessageText:
// The length the string should be padded to
#define FUNCTION_PAD_LENGTH_ARG          0x00001F94L
// MessageId: FUNCTION_PAD_STRING_ARG
// MessageText:
// The string to be used to pad
#define FUNCTION_PAD_STRING_ARG          0x00001F95L
// MessageId: FUNCTION_PAD_LENGTH_ARG_LIT
// MessageText:
// number of characters
#define FUNCTION_PAD_LENGTH_ARG_LIT      0x00001F96L
// MessageId: FUNCTION_PAD_STRING_ARG_LIT
// MessageText:
// pad string
#define FUNCTION_PAD_STRING_ARG_LIT      0x00001F97L
// MessageText:
// Pads a string expression as directed to the left
#define FUNCTION_LPAD                    0x00001F98L
// MessageId: FUNCTION_RPAD_STRING_ARG
// MessageText:
// String to pad to the right
#define FUNCTION_RPAD_STRING_ARG         0x00001F99L
// MessageText:
// Pads a string expression as directed to the right
#define FUNCTION_RPAD                    0x00001F9AL
// MessageId: FUNCTION_LTRIM_STRING_ARG
// MessageText:
// String to trim on the left
#define FUNCTION_LTRIM_STRING_ARG        0x00001F9BL
// MessageText:
// Trims a string expression on the left
#define FUNCTION_LTRIM                   0x00001F9CL
// MessageId: FUNCTION_RTRIM_STRING_ARG
// MessageText:
// String to trim on the right
#define FUNCTION_RTRIM_STRING_ARG        0x00001F9DL
// MessageText:
// Trims a string expression on the right
#define FUNCTION_RTRIM                   0x00001F9EL
// MessageId: FUNCTION_INSTR_STRING1_ARG
// MessageText:
// String to search in
#define FUNCTION_INSTR_STRING1_ARG       0x00001F9FL
// MessageId: FUNCTION_INSTR_STRING2_ARG
// MessageText:
// String to look for
#define FUNCTION_INSTR_STRING2_ARG       0x00001FA0L
// MessageId: FUNCTION_STRING_SEARCH_ARG_LIT
// MessageText:
// search text
#define FUNCTION_STRING_SEARCH_ARG_LIT   0x00001FA1L
// MessageText:
// Returns the position of a string within a base string
#define FUNCTION_INSTR                   0x00001FA2L
// MessageId: FUNCTION_SUBSTR_STRING_ARG
// MessageText:
// String from which to extract
#define FUNCTION_SUBSTR_STRING_ARG       0x00001FA3L
// MessageId: FUNCTION_SUBSTR_START_POS_ARG
// MessageText:
// Position from which to extract a substring
#define FUNCTION_SUBSTR_START_POS_ARG    0x00001FA4L
// MessageId: FUNCTION_SUBSTR_LENGTH_ARG
// MessageText:
// The length of the substring to extract
#define FUNCTION_SUBSTR_LENGTH_ARG       0x00001FA5L
// MessageId: FUNCTION_SUBSTR_START_POS_ARG_LIT
// MessageText:
// position to start
#define FUNCTION_SUBSTR_START_POS_ARG_LIT 0x00001FA6L
// MessageId: FUNCTION_SUBSTR_LENGTH_ARG_LIT
// MessageText:
// optional length of substring
#define FUNCTION_SUBSTR_LENGTH_ARG_LIT   0x00001FA7L
// MessageText:
// Returns a substring from a provided string as defined
#define FUNCTION_SUBSTR                  0x00001FA8L
// MessageId: FUNCTION_TRIM_STRING_ARG
// MessageText:
// String to trim
#define FUNCTION_TRIM_STRING_ARG         0x00001FA9L
// MessageId: FUNCTION_TRIM_OP_ARG
// MessageText:
// Trim indicator (BOTH, LEADING, TRAILING)
#define FUNCTION_TRIM_OP_ARG             0x00001FAAL
// MessageText:
#define FUNCTION_TRIM                    0x00001FABL
// MessageId: FUNCTION_SOUNDEX_STRING_ARG
// MessageText:
// String for which to identify phonetic representation
#define FUNCTION_SOUNDEX_STRING_ARG      0x00001FACL
// MessageText:
// Returns the phonetic representation of a string expression
#define FUNCTION_SOUNDEX                 0x00001FADL
// MessageId: FUNCTION_TRANSLATE_STRING1_ARG
// MessageText:
// String where character replacement is executed
#define FUNCTION_TRANSLATE_STRING1_ARG   0x00001FAEL
// MessageId: FUNCTION_TRANSLATE_STRING2_ARG
// MessageText:
// String identifying individual characters to be replaced
#define FUNCTION_TRANSLATE_STRING2_ARG   0x00001FAFL
// MessageId: FUNCTION_TRANSLATE_STRING3_ARG
// MessageText:
// String identifying individual replacement characters
#define FUNCTION_TRANSLATE_STRING3_ARG   0x00001FB0L
// MessageId: FUNCTION_TRANSLATE_FROM_ARG_LIT
// MessageText:
// from-characterset
#define FUNCTION_TRANSLATE_FROM_ARG_LIT  0x00001FB1L
// MessageId: FUNCTION_TRANSLATE_TO_ARG_LIT
// MessageText:
// to-characterset
#define FUNCTION_TRANSLATE_TO_ARG_LIT    0x00001FB2L
// MessageText:
// Replaces a set of individual characters in a string with replacements
#define FUNCTION_TRANSLATE               0x00001FB3L
// MessageId: FUNCTION_MEDIAN
// MessageText:
// Represents an inverse distribution function with a continuous distribution model
#define FUNCTION_MEDIAN                  0x00001FB4L
// MessageId: FUNCTION_STDDEV
// MessageText:
// Returns the sample standard deviation of a numeric expression
#define FUNCTION_STDDEV                  0x00001FB5L
// MessageId: FUNCTION_ADDMONTHS_MONTH_ARG
// MessageText:
// Number of months to be added
#define FUNCTION_ADDMONTHS_MONTH_ARG     0x00001FB6L
// MessageText:
// Adds a specified number of months to a date
#define FUNCTION_ADDMONTHS               0x00001FB7L
// MessageId: FUNCTION_CURRENTDATE
// MessageText:
// Returns the current date
#define FUNCTION_CURRENTDATE             0x00001FB8L
// MessageId: FUNCTION_EXTRACT_OP_ARG
// MessageText:
// Indicates the portion of the date/time to be extracted
#define FUNCTION_EXTRACT_OP_ARG          0x00001FB9L
// MessageId: FUNCTION_EXTRACT_DATE_ARG
// MessageText:
// The date/time from which to extract a portion from
#define FUNCTION_EXTRACT_DATE_ARG        0x00001FBAL
// MessageId: FUNCTION_EXTRACT_OP_ARG_LIT
// MessageText:
// part of the date
#define FUNCTION_EXTRACT_OP_ARG_LIT      0x00001FBBL
// MessageId: FUNCTION_EXTRACT_DT_ARG_LIT
// MessageText:
// from date
#define FUNCTION_EXTRACT_DT_ARG_LIT      0x00001FBCL
// MessageText:
// Extracts a portion of a date/time
#define FUNCTION_EXTRACT                 0x00001FBDL
// MessageId: FUNCTION_DATE1_ARG_LIT
// MessageText:
// date1
#define FUNCTION_DATE1_ARG_LIT           0x00001FBEL
// MessageId: FUNCTION_DATE2_ARG_LIT
// MessageText:
// date2
#define FUNCTION_DATE2_ARG_LIT           0x00001FBFL
// MessageId: FUNCTION_MONTHSBETWEEN
// MessageText:
// Returns the number of months between two dates
#define FUNCTION_MONTHSBETWEEN           0x00001FC0L
// MessageId: FUNCTION_NULLVALUE
// MessageText:
// Returns the first argument if not NULL, the second otherwise
#define FUNCTION_NULLVALUE               0x00001FC1L
// MessageId: FUNCTION_GENERAL_FORMAT_ARG
// MessageText:
// Format specification
#define FUNCTION_GENERAL_FORMAT_ARG      0x00001FC2L
// MessageId: FUNCTION_FORMAT_ARG_LIT
// MessageText:
// optional format
#define FUNCTION_FORMAT_ARG_LIT          0x00001FC3L
// MessageId: FUNCTION_TODATE
// MessageText:
// Converts a string to a date
#define FUNCTION_TODATE                  0x00001FC4L
// MessageId: FUNCTION_TODOUBLE
// MessageText:
// Converts a string or number to a double
#define FUNCTION_TODOUBLE                0x00001FC5L
// MessageId: FUNCTION_TOFLOAT
// MessageText:
// Converts a string or number to a float
#define FUNCTION_TOFLOAT                 0x00001FC6L
// MessageId: FUNCTION_TOINT32
// MessageText:
// Converts a string or number to an int32
#define FUNCTION_TOINT32                 0x00001FC7L
// MessageId: FUNCTION_TOINT64
// MessageText:
// Converts a string or number to an int64
#define FUNCTION_TOINT64                 0x00001FC8L
// MessageId: FUNCTION_TOSTRING
// MessageText:
// Converts a number or date to a string
#define FUNCTION_TOSTRING                0x00001FC9L
// MessageId: MONTH_NAME_JANUARY
// MessageText:
// January
#define MONTH_NAME_JANUARY               0x00001FCAL
// MessageId: MONTH_NAME_FEBRUARY
// MessageText:
// February
#define MONTH_NAME_FEBRUARY              0x00001FCBL
// MessageId: MONTH_NAME_MARCH
// MessageText:
// March
#define MONTH_NAME_MARCH                 0x00001FCCL
// MessageId: MONTH_NAME_APRIL
// MessageText:
// April
#define MONTH_NAME_APRIL                 0x00001FCDL
// MessageId: MONTH_NAME_MAY
// MessageText:
// May
#define MONTH_NAME_MAY                   0x00001FCEL
// MessageId: MONTH_NAME_JUNE
// MessageText:
// June
#define MONTH_NAME_JUNE                  0x00001FCFL
// MessageId: MONTH_NAME_JULY
// MessageText:
// July
#define MONTH_NAME_JULY                  0x00001FD0L
// MessageId: MONTH_NAME_AUGUST
// MessageText:
// August
#define MONTH_NAME_AUGUST                0x00001FD1L
// MessageId: MONTH_NAME_SEPTEMBER
// MessageText:
// September
#define MONTH_NAME_SEPTEMBER             0x00001FD2L
// MessageId: MONTH_NAME_OCTOBER
// MessageText:
// October
#define MONTH_NAME_OCTOBER               0x00001FD3L
// MessageId: MONTH_NAME_NOVEMBER
// MessageText:
// November
#define MONTH_NAME_NOVEMBER              0x00001FD4L
// MessageId: MONTH_NAME_DECEMBER
// MessageText:
// December
#define MONTH_NAME_DECEMBER              0x00001FD5L
// MessageId: MONTH_ABB_JANUARY
// MessageText:
// Jan
#define MONTH_ABB_JANUARY                0x00001FD6L
// MessageId: MONTH_ABB_FEBRUARY
// MessageText:
// Feb
#define MONTH_ABB_FEBRUARY               0x00001FD7L
// MessageId: MONTH_ABB_MARCH
// MessageText:
// Mar
#define MONTH_ABB_MARCH                  0x00001FD8L
// MessageId: MONTH_ABB_APRIL
// MessageText:
// Apr
#define MONTH_ABB_APRIL                  0x00001FD9L
// MessageId: MONTH_ABB_MAY
// MessageText:
// May
#define MONTH_ABB_MAY                    0x00001FDAL
// MessageId: MONTH_ABB_JUNE
// MessageText:
// Jun
#define MONTH_ABB_JUNE                   0x00001FDBL
// MessageId: MONTH_ABB_JULY
// MessageText:
// Jul
#define MONTH_ABB_JULY                   0x00001FDCL
// MessageId: MONTH_ABB_AUGUST
// MessageText:
// Aug
#define MONTH_ABB_AUGUST                 0x00001FDDL
// MessageId: MONTH_ABB_SEPTEMBER
// MessageText:
// Sep
#define MONTH_ABB_SEPTEMBER              0x00001FDEL
// MessageId: MONTH_ABB_OCTOBER
// MessageText:
// Oct
#define MONTH_ABB_OCTOBER                0x00001FDFL
// MessageId: MONTH_ABB_NOVEMBER
// MessageText:
// Nov
#define MONTH_ABB_NOVEMBER               0x00001FE0L
// MessageId: MONTH_ABB_DECEMBER
// MessageText:
// Dec
#define MONTH_ABB_DECEMBER               0x00001FE1L
// MessageId: DAY_NAME_SUNDAY
// MessageText:
// Sunday
#define DAY_NAME_SUNDAY                  0x00001FE2L
// MessageId: DAY_NAME_MONDAY
// MessageText:
// Monday
#define DAY_NAME_MONDAY                  0x00001FE3L
// MessageId: DAY_NAME_TUESDAY
// MessageText:
// Tuesday
#define DAY_NAME_TUESDAY                 0x00001FE4L
// MessageId: DAY_NAME_WEDNESDAY
// MessageText:
// Wednesday
#define DAY_NAME_WEDNESDAY               0x00001FE5L
// MessageId: DAY_NAME_THURSDAY
// MessageText:
// Thursday
#define DAY_NAME_THURSDAY                0x00001FE6L
// MessageId: DAY_NAME_FRIDAY
// MessageText:
// Friday
#define DAY_NAME_FRIDAY                  0x00001FE7L
// MessageId: DAY_NAME_SATURDAY
// MessageText:
// Saturday
#define DAY_NAME_SATURDAY                0x00001FE8L
// MessageId: DAY_ABB_SUNDAY
// MessageText:
// Sun
#define DAY_ABB_SUNDAY                   0x00001FE9L
// MessageId: DAY_ABB_MONDAY
// MessageText:
// Mon
#define DAY_ABB_MONDAY                   0x00001FEAL
// MessageId: DAY_ABB_TUESDAY
// MessageText:
// Tue
#define DAY_ABB_TUESDAY                  0x00001FEBL
// MessageId: DAY_ABB_WEDNESDAY
// MessageText:
// Wed
#define DAY_ABB_WEDNESDAY                0x00001FECL
// MessageId: DAY_ABB_THURSDAY
// MessageText:
// Thu
#define DAY_ABB_THURSDAY                 0x00001FEDL
// MessageId: DAY_ABB_FRIDAY
// MessageText:
// Fri
#define DAY_ABB_FRIDAY                   0x00001FEEL
// MessageId: DAY_ABB_SATURDAY
// MessageText:
// Sat
#define DAY_ABB_SATURDAY                 0x00001FEFL
// MessageId: FUNCTION_AREA2D
// MessageText:
// Determines the area of a given geometry
#define FUNCTION_AREA2D                  0x00001FF0L
// MessageId: FUNCTION_LENGTH2D
// MessageText:
// Determines the length of a given geometry
#define FUNCTION_LENGTH2D                0x00001FF1L
// MessageId: FDO_1_BADALLOC
// MessageText:
// Memory allocation failed.
#define FDO_1_BADALLOC                   0x00002329L
// MessageId: FDO_2_BADPARAMETER
// MessageText:
// Bad parameter to method.
#define FDO_2_BADPARAMETER               0x0000232AL
// MessageId: FDO_3_NOTIMPLEMENTED
// MessageText:
// Method is not implemented.
#define FDO_3_NOTIMPLEMENTED             0x0000232BL
// MessageId: FDO_4_UNREADY
// MessageText:
// Data is not in a state to respond to the request.
#define FDO_4_UNREADY                    0x0000232CL
// MessageId: FDO_5_INDEXOUTOFBOUNDS
// MessageText:
// Item index out of bounds.
#define FDO_5_INDEXOUTOFBOUNDS           0x0000232DL
// MessageId: FDO_6_OBJECTNOTFOUND
// MessageText:
// Invalid delete; object not present.
#define FDO_6_OBJECTNOTFOUND             0x0000232EL
// MessageId: FDO_7_INVALIDFGF
// MessageText:
// String is not a valid FGF string.
#define FDO_7_INVALIDFGF                 0x0000232FL
// MessageId: FDO_8_INCORRECTSTRINGFORMAT
// MessageText:
// Parse string is incorrectly formatted.
#define FDO_8_INCORRECTSTRINGFORMAT      0x00002330L
// MessageId: FDO_9_INVALIDDIGIT
// MessageText:
#define FDO_9_INVALIDDIGIT               0x00002331L
// MessageId: FDO_10_UNSUPPORTEDGEOMETRYTYPE
// MessageText:
// Unsupported geometry type.
#define FDO_10_UNSUPPORTEDGEOMETRYTYPE   0x00002332L
// MessageId: FDO_11_INVALIDPOINT
// MessageText:
// Invalid point.
#define FDO_11_INVALIDPOINT              0x00002333L
// MessageId: FDO_12_SHAREDARRAY
// MessageText:
// Cannot resize a shared array.
#define FDO_12_SHAREDARRAY               0x00002334L
// MessageId: FDO_13_INVALIDRESIZE
// MessageText:
// Invalid array resize.
#define FDO_13_INVALIDRESIZE             0x00002335L
// MessageId: FDO_14_NULLSTRING
// MessageText:
// Null String.
#define FDO_14_NULLSTRING                0x00002336L
// MessageId: FDO_15_UNSUPPORTEDGEOMETRYDATA
// MessageText:
// Invalid Geometry.
#define FDO_15_UNSUPPORTEDGEOMETRYDATA   0x00002337L
// MessageId: FDO_17_UNSUPPORTEDDIMENSIONALITY
// MessageText:
// Invalid dimensionality.
#define FDO_17_UNSUPPORTEDDIMENSIONALITY 0x00002338L
// MessageId: FDO_18_DATAPROVIDERFAILURE
// MessageText:
// OCI failure.
#define FDO_18_DATAPROVIDERFAILURE       0x00002339L
// MessageId: FDO_18_FILEOPENFAILURE
// MessageText:
// Failed to open file '%1$ls' with access modes: '%2$ls'.
#define FDO_18_FILEOPENFAILURE           0x0000233AL
// MessageId: FDO_19_STREAMREADERROR
// MessageText:
// Cannot read %1$d bytes from unreadable stream.
#define FDO_19_STREAMREADERROR           0x0000233BL
// MessageId: FDO_20_STREAMWRITEERROR
// MessageText:
// Cannot write %1$d bytes to unwritable stream.
#define FDO_20_STREAMWRITEERROR          0x0000233CL
// MessageId: FDO_21_STREAMWRITEERROR
// MessageText:
// Cannot write %1$d bytes to writable stream, only %2$d bytes were written.
#define FDO_21_STREAMWRITEERROR          0x0000233DL
// MessageId: FDO_22_STREAMSEEKERROR
// MessageText:
// Cannot seek on non-seekable stream.
#define FDO_22_STREAMSEEKERROR           0x0000233EL
// MessageId: FDO_23_STREAMSEEKFAILURE
// MessageText:
// Seek on stream failed.
#define FDO_23_STREAMSEEKFAILURE         0x0000233FL
// MessageId: FDO_24_STREAMBADFP
// MessageText:
// Cannot create FdoIoFileStream, bad file pointer.
#define FDO_24_STREAMBADFP               0x00002340L
// MessageId: FDO_25_STREAMSIZEFAILURE
// MessageText:
// Setting length of stream to %1$d bytes failed.
#define FDO_25_STREAMSIZEFAILURE         0x00002341L
// MessageId: FDO_26_BUFFEROVERWRITEERROR
// MessageText:
// Cannot write %1$lld bytes to buffer with %2$lld bytes remaining.
#define FDO_26_BUFFEROVERWRITEERROR      0x00002342L
// MessageId: FDO_27_BUFFERLENGTHERROR
// MessageText:
// Cannot change length of fixed buffer stream.
#define FDO_27_BUFFERLENGTHERROR         0x00002343L
// MessageId: FDO_28_UTF8FAILURE
// MessageText:
// Unicode to UTF8 conversion failed for string '%1$ls'.
#define FDO_28_UTF8FAILURE               0x00002344L
// MessageId: FDO_29_UNICODEFAILURE
// MessageText:
// UTF8 to Unicode conversion failed for string '%1$s'.
#define FDO_29_UNICODEFAILURE            0x00002345L
// MessageId: FDO_30_BADPARAM
// MessageText:
// Bad %1$ls value '%2$ls' passed to %3$ls.
#define FDO_30_BADPARAM                  0x00002346L
// MessageId: FDO_31_ENDELEMENTERROR
// MessageText:
// FdoXmlWriter::EndElement: there is no current element to end.
#define FDO_31_ENDELEMENTERROR           0x00002347L
// MessageId: FDO_32_XMLATTRIBUTEERROR
// MessageText:
// Cannot add attribute %1$ls; tag for element %2$ls is no longer open.
#define FDO_32_XMLATTRIBUTEERROR         0x00002348L
// MessageId: FDO_33_XMLPARSEERROR
// MessageText:
// XML Document parse error at line %1$d column %2$d: %3$ls
#define FDO_33_XMLPARSEERROR             0x00002349L
// MessageId: FDO_34_MEMORYSTREAMOVERFLOW
// MessageText:
// %1$ls: Maximum length for a %2$ls exceeded, please increase buffer size (currently %3$d)
#define FDO_34_MEMORYSTREAMOVERFLOW      0x0000234AL
// MessageId: FDO_35_FILENOCONTEXT
// MessageText:
// Stream is not contextual (has no absolute position); %1$ls::%2$ls cannot be called
#define FDO_35_FILENOCONTEXT             0x0000234BL
// MessageId: FDO_36_STREAMINDEXALIGN
// MessageText:
// %1$ls::%2$ls cannot be called when file size exceeds %3$d bytes (current size: %4$d bytes)
#define FDO_36_STREAMINDEXALIGN          0x0000234CL
// MessageId: FDO_37_FILEFLUSH
// MessageText:
// %1$ls: failed to flush file
#define FDO_37_FILEFLUSH                 0x0000234DL
// MessageId: FDO_38_ITEMNOTFOUND
// MessageText:
// Item '%1$ls' not found in collection
#define FDO_38_ITEMNOTFOUND              0x0000234EL
// MessageId: FDO_39_STACKPOP
// MessageText:
// Stack is empty, cannot pop.
#define FDO_39_STACKPOP                  0x0000234FL
// MessageId: FDO_40_BADXMLELEMENT
// MessageText:
// Element '%1$ls' is not a valid XML 1.0 element name.
#define FDO_40_BADXMLELEMENT             0x00002350L
// MessageId: FDO_41_BADXMLATTRIBUTE
// MessageText:
// Attribute '%1$ls' is not a valid XML 1.0 attribute name.
#define FDO_41_BADXMLATTRIBUTE           0x00002351L
// MessageId: FDO_42_GENERICCHAR
// MessageText:
// %1$ls
#define FDO_42_GENERICCHAR               0x00002352L
// MessageId: FDO_43_XSLERROR
// MessageText:
// XSL Error at line %1$d column %2$d: %3$ls.
#define FDO_43_XSLERROR                  0x00002353L
// MessageId: FDO_44_BADDEFAULTROOT
// MessageText:
// Cannot change default root setting for FdoXmlWriter; root element has already been written.
#define FDO_44_BADDEFAULTROOT            0x00002354L
// MessageId: FDO_45_ITEMINCOLLECTION
// MessageText:
// Item %1$ls is already in this named collection.
#define FDO_45_ITEMINCOLLECTION          0x00002355L
// MessageId: FDO_46_REMAININGSTREAMSIZE
// MessageText:
// %1$ls: Cannot read remainder of stream, there are more than %$2d items remaining.
#define FDO_46_REMAININGSTREAMSIZE       0x00002356L
// MessageId: FDO_47_READARRAYSIZE
// MessageText:
// %1$ls: FdoArray is too small to read %2$d items from stream.
#define FDO_47_READARRAYSIZE             0x00002357L
// MessageId: FDO_48_NOCONTENTELEMENT
// MessageText:
// %1$ls called when there is no open element; content is '%2$ls'.
#define FDO_48_NOCONTENTELEMENT          0x00002358L
// MessageId: FDO_49_MULTIROOTELEMENT
// MessageText:
// %1$ls: cannot write second root element '%2$ls' to XML document.
#define FDO_49_MULTIROOTELEMENT          0x00002359L
// MessageId: FDO_50_XMLTRANSCODEFAILED
// MessageText:
// %1$ls: %2$ls failed.
#define FDO_50_XMLTRANSCODEFAILED        0x0000235AL
// MessageId: FDO_51_SETFILESIZE
// MessageText:
// Cannot change file size to %1$d Windows; maximum is %2$d
#define FDO_51_SETFILESIZE               0x0000235BL
// MessageId: FDO_52_BADSUBELEMENT
// MessageText:
// Error reading from XML, unexpected element %1$ls inside '%2$ls'.
#define FDO_52_BADSUBELEMENT             0x0000235CL
// MessageId: FDO_53_NESTEDXMLPARSEERROR
// MessageText:
// Nested call to FdoXmlReader::Parse() attempted.
#define FDO_53_NESTEDXMLPARSEERROR       0x0000235DL
// MessageId: FDO_54_XMLINPUTEOF
// MessageText:
// Cannot parse XML document whose stream is at end-of-file.
#define FDO_54_XMLINPUTEOF               0x0000235EL
// MessageId: FDO_55_XSLINPUTEOF
// MessageText:
// Cannot XSL Transform XML document whose stream is at end-of-file.
#define FDO_55_XSLINPUTEOF               0x0000235FL
// MessageId: FDO_56_XSLSTYLESHEETEOF
// MessageText:
// Cannot read XSL stylesheet whose stream is at end-of-file.
#define FDO_56_XSLSTYLESHEETEOF          0x00002360L
// MessageId: FDO_57_UNEXPECTEDERROR
// MessageText:
// Unexpected error encountered.
#define FDO_57_UNEXPECTEDERROR           0x00002361L
// MessageId: FDO_58_READERHASNODATA
// MessageText:
// End of reader data or ReadNext not called.
#define FDO_58_READERHASNODATA           0x00002362L
// MessageId: FDO_59_CANNOTFETCHNULLVALUE
// MessageText:
// Cannot fetch NULL value.
#define FDO_59_CANNOTFETCHNULLVALUE      0x00002363L
// MessageId: FDO_60_NULL_POINTER
// MessageText:
// Unexpected NULL pointer.
#define FDO_60_NULL_POINTER              0x00002364L
// MessageId: FDO_61_NULL_ARGUMENT
// MessageText:
// A required argument was set to NULL.
#define FDO_61_NULL_ARGUMENT             0x00002365L
// MessageId: FDO_62_PROPERTYVALUEFETCHTYPEMISMATCH
// MessageText:
// Fetching a property value did not match the property type.
#define FDO_62_PROPERTYVALUEFETCHTYPEMISMATCH 0x00002366L
// MessageId: FDO_63_CONNECTION_INVALID
// MessageText:
// Connection is invalid.
#define FDO_63_CONNECTION_INVALID        0x00002367L
// MessageId: FDO_64_CONNECTION_REQUIRED_PROPERTY_NULL
// MessageText:
// The required property '%1$ls' cannot be set to NULL.
#define FDO_64_CONNECTION_REQUIRED_PROPERTY_NULL 0x00002368L
// MessageId: FDO_65_CONNECTION_ENUM_PROPERTY_WRONG_VALUE
// MessageText:
// The given value '%1$ls' for enumerable property '%2$ls' is not in the enumeration value collection.
#define FDO_65_CONNECTION_ENUM_PROPERTY_WRONG_VALUE 0x00002369L
// MessageId: FDO_66_CONNECTION_PROPERTY_NOT_FOUND
// MessageText:
// The connection property '%1$ls' was not found.
#define FDO_66_CONNECTION_PROPERTY_NOT_FOUND 0x0000236AL
// MessageId: FDO_67_CONNECTION_TIMEOUT_NOT_SUPPORTED
// MessageText:
// Connection timeout is not supported.
#define FDO_67_CONNECTION_TIMEOUT_NOT_SUPPORTED 0x0000236BL
// MessageId: FDO_68_COMMAND_PARAMETERS_NOT_SUPPORTED
// MessageText:
// Command parameters are not supported.
#define FDO_68_COMMAND_PARAMETERS_NOT_SUPPORTED 0x0000236CL
// MessageId: FDO_69_PROPERTY_NOT_AVAILABLE
// MessageText:
// The requested property is not available.
#define FDO_69_PROPERTY_NOT_AVAILABLE    0x0000236DL
// MessageId: FDO_70_PROPERTY_TYPE_NOT_SUPPORTED
// MessageText:
// The property type '%1$ls' is not supported by this provider.
#define FDO_70_PROPERTY_TYPE_NOT_SUPPORTED 0x0000236EL
// MessageId: FDO_71_DATA_TYPE_NOT_SUPPORTED
// MessageText:
// The data type '%1$ls' is not supported by this provider.
#define FDO_71_DATA_TYPE_NOT_SUPPORTED   0x0000236FL
// MessageId: FDO_72_LOB_DATA_TYPE_NOT_SUPPORTED
// MessageText:
// The BLOB and CLOB data types are not supported by this provider.
#define FDO_72_LOB_DATA_TYPE_NOT_SUPPORTED 0x00002370L
// MessageId: FDO_73_PROPERTY_INDEXOUTOFBOUNDS
// MessageText:
// Property index '%1$d' is out of bounds.
#define FDO_73_PROPERTY_INDEXOUTOFBOUNDS 0x00002371L
// MessageId: FDO_74_PROPERTY_NAME_NOT_FOUND
// MessageText:
// The property '%1$ls' was not found.
#define FDO_74_PROPERTY_NAME_NOT_FOUND   0x00002372L
// MessageId: FDO_75_INVALID_NUM_ARGUMENTS
// MessageText:
// Invalid number of arguments to function '%1$ls'; expected %2$d argument(s), got %3$d instead.
#define FDO_75_INVALID_NUM_ARGUMENTS     0x00002373L
// MessageId: FDO_76_CLASS_NAME_NOT_FOUND
// MessageText:
// The class '%1$ls' was not found.
#define FDO_76_CLASS_NAME_NOT_FOUND      0x00002374L
// MessageId: FDO_77_ORDERBY_INVALID_TYPE
// MessageText:
// The data type '%1$ls' cannot be used with Order By.
#define FDO_77_ORDERBY_INVALID_TYPE      0x00002375L
// MessageId: FDO_78_AGGREGATE_IN_AGGREGATE_FUNCTION
// MessageText:
// Aggregate functions cannot contain aggregate functions as their arguments.
#define FDO_78_AGGREGATE_IN_AGGREGATE_FUNCTION 0x00002376L
// MessageId: FDO_79_AGGREGATE_INVALID_MIX
// MessageText:
// Invalid combination of aggregate functions and non-aggregate expressions.
#define FDO_79_AGGREGATE_INVALID_MIX     0x00002377L
// MessageId: FDO_80_INVALID_EXPRESSION
// MessageText:
// Invalid expression; expression types incompatible.
#define FDO_80_INVALID_EXPRESSION        0x00002378L
// MessageId: FDO_81_IDENTIFIER_NOT_FOUND
// MessageText:
// The identifier '%1$ls' was not recognized.
#define FDO_81_IDENTIFIER_NOT_FOUND      0x00002379L
// MessageId: FDO_82_UNSUPPORTED_LOGICAL_OPERATION
// MessageText:
// Unsupported FDO logical operation.
#define FDO_82_UNSUPPORTED_LOGICAL_OPERATION 0x0000237AL
// MessageId: FDO_83_UNSUPPORTED_COMPARISON_OPERATION
// MessageText:
// Unsupported FDO comparison operation.
#define FDO_83_UNSUPPORTED_COMPARISON_OPERATION 0x0000237BL
// MessageId: FDO_84_SPATIAL_CONDITION_NOT_LITERAL_GEOMETRY
// MessageText:
// Only literal geometric values are allowed in spatial conditions.
#define FDO_84_SPATIAL_CONDITION_NOT_LITERAL_GEOMETRY 0x0000237CL
// MessageId: FDO_85_DISTANCE_SPATIAL_CONDITION_NOT_SUPPORTED
// MessageText:
// The Distance spatial condition is not supported by this provider.
#define FDO_85_DISTANCE_SPATIAL_CONDITION_NOT_SUPPORTED 0x0000237DL
// MessageId: FDO_86_UNSUPPORTED_BINARY_OPERATION
// MessageText:
// Unsupported FDO binary operation.
#define FDO_86_UNSUPPORTED_BINARY_OPERATION 0x0000237EL
// MessageId: FDO_87_UNSUPPORTED_UNARY_OPERATION
// MessageText:
// Unsupported FDO unary operation.
#define FDO_87_UNSUPPORTED_UNARY_OPERATION 0x0000237FL
// MessageId: FDO_88_INVALID_FUNCTION_ARG_TYPE
// MessageText:
// Argument number %1$d to function '%2$ls' was of type '%3$ls', expected type '%4$ls'.
#define FDO_88_INVALID_FUNCTION_ARG_TYPE 0x00002380L
// MessageId: FDO_89_UNSUPPORTED_FUNCTION
// MessageText:
// The function '%1$ls' is not supported by this provider.
#define FDO_89_UNSUPPORTED_FUNCTION      0x00002381L
// MessageId: FDO_90_GEOMETRY_VALUES_IN_FILTER_UNSUPPORTED
// MessageText:
// Geometry values in filters are not supported by this provider.
#define FDO_90_GEOMETRY_VALUES_IN_FILTER_UNSUPPORTED 0x00002382L
// MessageId: FDO_91_FILE_NOT_FOUND
// MessageText:
// The file '%1$ls' was not found.
#define FDO_91_FILE_NOT_FOUND            0x00002383L
// MessageId: FDO_92_PATH_NOT_FOUND
// MessageText:
// The path to file '%1$ls' was not found.
#define FDO_92_PATH_NOT_FOUND            0x00002384L
// MessageId: FDO_93_TOO_MANY_OPEN_FILES
// MessageText:
// Already too many open files when opening file '%1$ls'.
#define FDO_93_TOO_MANY_OPEN_FILES       0x00002385L
// MessageId: FDO_94_ACCESS_DENIED
// MessageText:
// Access to file '%1$ls' was denied.
#define FDO_94_ACCESS_DENIED             0x00002386L
// MessageId: FDO_95_FILE_IO_ERROR
// MessageText:
// File '%1$ls' I/O error in context '%2$ls': %3$ls
#define FDO_95_FILE_IO_ERROR             0x00002387L
// MessageId: FDO_96_READ_ONLY
// MessageText:
// Location for file '%1$ls' is read-only.
#define FDO_96_READ_ONLY                 0x00002388L
// MessageId: FDO_97_CANNOT_SET_READONLY_PROPERTY
// MessageText:
// Property '%1$ls' cannot be set because it is read-only.
#define FDO_97_CANNOT_SET_READONLY_PROPERTY 0x00002389L
// MessageId: FDO_98_MISSING_DEFAULT_VALUE
// MessageText:
// Read-only property '%1$ls' requires a default value.
#define FDO_98_MISSING_DEFAULT_VALUE     0x0000238AL
// MessageId: FDO_99_CANNOT_DEFAULT_READONLY_PROPERTY
// MessageText:
// Read-only identity property '%1$ls' cannot have a default value.
#define FDO_99_CANNOT_DEFAULT_READONLY_PROPERTY 0x0000238BL
// MessageId: FDO_100_COMMAND_TIMEOUT_NOT_SUPPORTED
// MessageText:
// Command timeout is not supported.
#define FDO_100_COMMAND_TIMEOUT_NOT_SUPPORTED 0x0000238CL
// MessageId: FDO_101_TRANSACTIONS_NOT_SUPPORTED
// MessageText:
// Transactions are not supported.
#define FDO_101_TRANSACTIONS_NOT_SUPPORTED 0x0000238DL
// MessageId: FDO_102_COMMAND_NOT_SUPPORTED
// MessageText:
// The command '%1$ls' is not supported.
#define FDO_102_COMMAND_NOT_SUPPORTED    0x0000238EL
// MessageId: FDO_103_CONNECTION_ALREADY_OPEN
// MessageText:
// The connection is already open.
#define FDO_103_CONNECTION_ALREADY_OPEN  0x0000238FL
// MessageId: FDO_104_READER_PROPERTY_NOT_SELECTED
// MessageText:
// The property '%1$ls' is not in the reader's selected property set.
#define FDO_104_READER_PROPERTY_NOT_SELECTED 0x00002390L
// MessageId: FDO_105_UNSUPPORTED_SPATIAL_OPERATION
// MessageText:
// Unsupported FDO spatial operation.
#define FDO_105_UNSUPPORTED_SPATIAL_OPERATION 0x00002391L
// MessageId: FDO_106_LOB_NOT_SUPPORTED_IN_FILTER
// MessageText:
// LOB objects not supported in the FDO Filter.
#define FDO_106_LOB_NOT_SUPPORTED_IN_FILTER 0x00002392L
// MessageId: FDO_107_PARAEMETRS_NOT_SUPPORTED_IN_FILTER
// MessageText:
// Parameters not supported in the FDO Filter.
#define FDO_107_PARAEMETRS_NOT_SUPPORTED_IN_FILTER 0x00002393L
// MessageId: FDO_108_INVALID_FDO_IN_CONDITION
// MessageText:
// Invalid FDO In condition.
#define FDO_108_INVALID_FDO_IN_CONDITION 0x00002394L
// MessageId: FDO_109_INVALID_FDO_COMPARISON_CONDITION
// MessageText:
#define FDO_109_INVALID_FDO_COMPARISON_CONDITION 0x00002395L
// MessageId: FDO_110_PROPERTY_NOT_NULLABLE
// MessageText:
// The property '%1$ls' cannot be set to NULL.
#define FDO_110_PROPERTY_NOT_NULLABLE    0x00002396L
// MessageId: FDO_111_PROPERTY_RANGE_CONSTRAINT_VIOLATED
// MessageText:
// The property '%1$ls' range constraint (%2$ls) is violated by value %3$ls.
#define FDO_111_PROPERTY_RANGE_CONSTRAINT_VIOLATED 0x00002397L
// MessageId: FDO_112_PROPERTY_LIST_CONSTRAINT_VIOLATED
// MessageText:
// The property '%1$ls' list constraint (%2$ls) is violated by value %3$ls.
#define FDO_112_PROPERTY_LIST_CONSTRAINT_VIOLATED 0x00002398L
// MessageId: FDO_113_PROPERTY_UNKNOWN_CONSTRAINT_VIOLATED
// MessageText:
// The property '%1$ls' unknown constraint is violated by value %2$ls.
#define FDO_113_PROPERTY_UNKNOWN_CONSTRAINT_VIOLATED 0x00002399L
// MessageId: FDO_114_XSL_LOG_ERROR
// MessageText:
// ERROR
#define FDO_114_XSL_LOG_ERROR            0x0000239AL
// MessageId: FDO_115_XSL_LOG_WARNING
// MessageText:
// WARNING
#define FDO_115_XSL_LOG_WARNING          0x0000239BL
// MessageId: FDO_116_XSL_LOG_MESSAGE
// MessageText:
// MESSAGE
#define FDO_116_XSL_LOG_MESSAGE          0x0000239CL
// MessageId: FDO_117_XSL_LOG_ORIGINATOR_XMLPARSER
// MessageText:
// XML Parser
#define FDO_117_XSL_LOG_ORIGINATOR_XMLPARSER 0x0000239DL
// MessageId: FDO_118_XSL_LOG_ORIGINATOR_XSLPROCESSOR
// MessageText:
// XSL Processor
#define FDO_118_XSL_LOG_ORIGINATOR_XSLPROCESSOR 0x0000239EL
// MessageId: FDO_119_XSL_LOG_ORIGINATOR_XPATH
// MessageText:
// XPath
#define FDO_119_XSL_LOG_ORIGINATOR_XPATH 0x0000239FL
// MessageId: FDO_120_XSL_LOG_ORIGINATOR_UNKNOWN
// MessageText:
// Unknown originator
#define FDO_120_XSL_LOG_ORIGINATOR_UNKNOWN 0x000023A0L
// MessageId: FDO_121_XSL_ATSOURCENODE
// MessageText:
// At source node '%1$ls'
#define FDO_121_XSL_ATSOURCENODE         0x000023A1L
// MessageId: FDO_122_XSL_ATURI
// MessageText:
// at URI '%1$ls' (line %2$d, column %3$d)
#define FDO_122_XSL_ATURI                0x000023A2L
// MessageId: FDO_123_NOATTRIBUTEELEMENT
// MessageText:
// %1$ls called when there is no open element; cannot write attribute '%2$ls'.
#define FDO_123_NOATTRIBUTEELEMENT       0x000023A3L
// MessageId: FDO_124_BYTESAFTERCLOSE
// MessageText:
// %1$ls called after document closed; cannot write bytes.
#define FDO_124_BYTESAFTERCLOSE          0x000023A4L
// MessageId: FDO_125_SCHEMA_ALREADY_EXISTS
// MessageText:
// The schema '%1$ls' already exists.
#define FDO_125_SCHEMA_ALREADY_EXISTS    0x000023A5L
// MessageId: FDO_126_CLASS_ALREADY_EXISTS
// MessageText:
// The class '%1$ls' already exists.
#define FDO_126_CLASS_ALREADY_EXISTS     0x000023A6L
// MessageId: FDO_127_PROPERTY_ALREADY_EXISTS
// MessageText:
// The property '%1$ls' already exists.
#define FDO_127_PROPERTY_ALREADY_EXISTS  0x000023A7L
// MessageId: FDO_128_GEOMETRY_MAPPING_ERROR
// MessageText:
// The provided input is invalid for the current mapping process.
#define FDO_128_GEOMETRY_MAPPING_ERROR   0x000023A8L
// MessageId: FDO_129_PROPERTY_TYPE_NOT_SUPPORTED_BY_OPERATION
// MessageText:
// The property type '%1$ls' is not supported by this operation.
#define FDO_129_PROPERTY_TYPE_NOT_SUPPORTED_BY_OPERATION 0x000023A9L
// MessageId: FDO_130_DATA_TYPE_NOT_SUPPORTED_BY_OPERATION
// MessageText:
// The data type '%1$ls' is not supported by this operation.
#define FDO_130_DATA_TYPE_NOT_SUPPORTED_BY_OPERATION 0x000023AAL
// MessageId: FDO_131_UNSUPPORTED_GEOMETRY_TYPE
// MessageText:
// The '%1$ls' geometry type (or combination of types) is not supported.
#define FDO_131_UNSUPPORTED_GEOMETRY_TYPE 0x000023ABL
// MessageId: FDO_132_CONNECTION_BROKEN
// MessageText:
// Network connection is broken, or the server stopped responding.
#define FDO_132_CONNECTION_BROKEN        0x000023ACL
// MessageId: FDO_133_UNEXPECTEDERROR_PERFORMING
// MessageText:
// Unexpected error encountered while accessing the server.
#define FDO_133_UNEXPECTEDERROR_PERFORMING 0x000023ADL
// MessageId: FDO_134_SPATIAL_CONTEXT_ERROR_DEFAULT_EXISTS
// MessageText:
// '%1$ls': Default spatial context exists; Cannot create spatial context info.
#define FDO_134_SPATIAL_CONTEXT_ERROR_DEFAULT_EXISTS 0x000023AEL
// MessageId: FDO_135_SPATIAL_CONTEXT_ERROR_ID_MISSMATCH
// MessageText:
// '%1$ls': The spatial context ids don't match.
#define FDO_135_SPATIAL_CONTEXT_ERROR_ID_MISSMATCH 0x000023AFL
// MessageId: FDO_136_SPATIAL_CONTEXT_ERROR_UNKNOWN_EXTENT_TYPE
// MessageText:
// '%1$ls': Unknown extent type.
#define FDO_136_SPATIAL_CONTEXT_ERROR_UNKNOWN_EXTENT_TYPE 0x000023B0L
// MessageId: FDO_137_NAMED_COLLECTION_INDEX_NAME_ERROR
// MessageText:
// '%1$ls': Cannot find index in Named Collection for unspecified name (NULL).
#define FDO_137_NAMED_COLLECTION_INDEX_NAME_ERROR 0x000023B1L
// MessageId: FDO_138_MBC_ERROR_ROOT_CELL
// MessageText:
// '%1$ls': Invalid MBC format: missing root cell.
#define FDO_138_MBC_ERROR_ROOT_CELL      0x000023B2L
// MessageId: FDO_139_MBC_ERROR_ILLEGAL_CHAR
// MessageText:
// '%1$ls': Invalid MBC format: illegal character.
#define FDO_139_MBC_ERROR_ILLEGAL_CHAR   0x000023B3L
// MessageId: FDO_140_MBC_ERROR_SKIP
// MessageText:
// '%1$ls': MBC error: too many skip characters specified.
#define FDO_140_MBC_ERROR_SKIP           0x000023B4L
// MessageId: FDO_141_MBC_ERROR_MAX_DEPTH
// MessageText:
// '%1$ls': MBC error: depth exceeds maximum depth.
#define FDO_141_MBC_ERROR_MAX_DEPTH      0x000023B5L
// MessageId: FDO_142_MBC_ERROR_EXTENTS
// MessageText:
// '%1$ls': MBC error: extents outside spatial index extents.
#define FDO_142_MBC_ERROR_EXTENTS        0x000023B6L
// MessageId: FDO_143_URL_ERROR
// MessageText:
// The requested URL returned error: '%1$ls'.
#define FDO_143_URL_ERROR                0x000023B7L
// MessageId: FDO_144_URL_SERVICE_UNAVAILABLE
// MessageText:
// The HTTP service is unavailable.
#define FDO_144_URL_SERVICE_UNAVAILABLE  0x000023B8L
// MessageId: FDO_145_URL_BAD_REQUEST
// MessageText:
// The HTTP request could not be understood by the server due to malformed syntax.
#define FDO_145_URL_BAD_REQUEST          0x000023B9L
// MessageId: FDO_146_URL_NOT_AUTHORIZED
// MessageText:
// The HTTP request is missing user authentication or the user authorization has been refused by the server.
#define FDO_146_URL_NOT_AUTHORIZED       0x000023BAL
// MessageId: FDO_147_URL_ACCESS_DENIED
// MessageText:
// The HTTP request was denied (forbidden) by the server.
#define FDO_147_URL_ACCESS_DENIED        0x000023BBL
// MessageId: FDO_148_URI_NOT_FOUND
// MessageText:
// The HTTP request URI was not found by the server.
#define FDO_148_URI_NOT_FOUND            0x000023BCL
// MessageId: FDO_149_URL_REQUEST_NOT_ALLOWED
// MessageText:
// The method specified in the HTTP request is not allowed for the resource identified by the URI.
#define FDO_149_URL_REQUEST_NOT_ALLOWED  0x000023BDL
// MessageId: FDO_150_URL_REQUEST_NOT_ACCEPTABLE
// MessageText:
// The HTTP request generated an unaceptable response by the server.
#define FDO_150_URL_REQUEST_NOT_ACCEPTABLE 0x000023BEL
// MessageId: FDO_151_URL_PROXY_AUTHENTICATION_REQUIRED
// MessageText:
// The client is not authorized to access the HTTP Proxy Server.
#define FDO_151_URL_PROXY_AUTHENTICATION_REQUIRED 0x000023BFL
// MessageId: FDO_152_URL_REQUEST_TIMEOUT
// MessageText:
// HTTP server timeout. The client did not produce a request within the time that the server allowed.
#define FDO_152_URL_REQUEST_TIMEOUT      0x000023C0L
// MessageId: FDO_153_URL_NOT_AVAILABLE
// MessageText:
// The requested HTTP resource is no longer available at the server.
#define FDO_153_URL_NOT_AVAILABLE        0x000023C1L
// MessageId: FDO_154_URL_REQUEST_TOO_LONG
// MessageText:
// The HTTP server is refusing to service the request because the Request-URI is longer than the server is willing to interpret.
#define FDO_154_URL_REQUEST_TOO_LONG     0x000023C2L
// MessageId: FDO_155_URL_INTERNAL_SERVER_ERROR
// MessageText:
// The HTTP server encountered an unexpected internal condition which prevented it from fulfilling the request.
#define FDO_155_URL_INTERNAL_SERVER_ERROR 0x000023C3L
// MessageId: FDO_156_URL_REQUEST_NOT_IMPLEMENTED
// MessageText:
// The HTTP server does not support the functionality required to fulfill the request.
#define FDO_156_URL_REQUEST_NOT_IMPLEMENTED 0x000023C4L
// MessageId: FDO_157_URL_OVERLOADED
// MessageText:
// The HTTP server, while acting as a gateway or proxy, received an invalid response from the upstream server it accessed in attempting to fulfill the request.
#define FDO_157_URL_OVERLOADED           0x000023C5L
// MessageId: FDO_158_URL_SERVICE_UNAVAILABLE
// MessageText:
// The HTTP server is currently unable to handle the request due to a temporary overloading or maintenance of the server.
#define FDO_158_URL_SERVICE_UNAVAILABLE  0x000023C6L
// MessageId: FDO_159_URL_GATEWAY_TIMEOUT
// MessageText:
// The HTTP server, while acting as a gateway or proxy, did not receive a timely response from the upstream server specified by the URI.
#define FDO_159_URL_GATEWAY_TIMEOUT      0x000023C7L
// MessageId: FDO_160_HTTP_UNSUPPORTED_VERION
// MessageText:
// The server does not support, or refuses to support, the HTTP protocol version that was used in the request message.
#define FDO_160_HTTP_UNSUPPORTED_VERION  0x000023C8L
// MessageId: FDO_161_UNABLE_CONNECT_HOST
// MessageText:
// Unable to connect to the host.
#define FDO_161_UNABLE_CONNECT_HOST      0x000023C9L
// MessageId: FDO_162_CONNECT_HOST_TIMEOUT
// MessageText:
// The connection to the host has timed out.
#define FDO_162_CONNECT_HOST_TIMEOUT     0x000023CAL
// MessageId: FDO_163_UNABLE_RESOLVE_HOST
// MessageText:
// Unable to resolve the host. Host not found.
#define FDO_163_UNABLE_RESOLVE_HOST      0x000023CBL
// MessageId: FDO_164_UNSUPPORTED_HTTP_PROTOCOL
// MessageText:
// Unsupported HTTP Protocol.
#define FDO_164_UNSUPPORTED_HTTP_PROTOCOL 0x000023CCL
// MessageId: FDO_165_MALFORMED_URL
// MessageText:
// Malformed URL.
#define FDO_165_MALFORMED_URL            0x000023CDL
// MessageId: FDO_166_UNABLE_RESOLVE_PROXY
// MessageText:
// Couldn't resolve proxy name.
#define FDO_166_UNABLE_RESOLVE_PROXY     0x000023CEL
// MessageId: FDO_167_DOWNLOAD_PARTIAL_FILE
// MessageText:
// Downloaded a partial file.
#define FDO_167_DOWNLOAD_PARTIAL_FILE    0x000023CFL
// MessageId: FDO_168_FAILURE_OPEN_FILE
// MessageText:
// Could not open/read from file.
#define FDO_168_FAILURE_OPEN_FILE        0x000023D0L
// MessageId: FDO_169_FAILURE_POST
// MessageText:
// Failure to HTTP POST data.
#define FDO_169_FAILURE_POST             0x000023D1L
// MessageId: FDO_170_FAILURE_SSL_CONNECT
// MessageText:
// Server SSL connect error.
#define FDO_170_FAILURE_SSL_CONNECT      0x000023D2L
// MessageId: FDO_171_UNABLE_RESUME_DOWNLOAD
// MessageText:
// Could not resume data download.
#define FDO_171_UNABLE_RESUME_DOWNLOAD   0x000023D3L
// MessageId: FDO_172_ABORTED_BY_CALLBACK
// MessageText:
// The operation was aborted by an application callback.
#define FDO_172_ABORTED_BY_CALLBACK      0x000023D4L
// MessageId: FDO_173_ENDLESS_URL_REDIRECT
// MessageText:
// The number of URL redirects hit the maximum amount.
#define FDO_173_ENDLESS_URL_REDIRECT     0x000023D5L
// MessageId: FDO_174_SSL_PEER_CERTIFICATE
// MessageText:
// The SSL peer certificate was not ok.
#define FDO_174_SSL_PEER_CERTIFICATE     0x000023D6L
// MessageId: FDO_175_SERVER_RETURNED_NOTHING
// MessageText:
// The server returned no data.
#define FDO_175_SERVER_RETURNED_NOTHING  0x000023D7L
// MessageId: FDO_176_FAILURE_SENDING_NETWORK_DATA
// MessageText:
// Failure sending Network data.
#define FDO_176_FAILURE_SENDING_NETWORK_DATA 0x000023D8L
// MessageId: FDO_177_FAILURE_RECIEVING_NETWORK_DATA
// MessageText:
// Failure receiving Network data.
#define FDO_177_FAILURE_RECIEVING_NETWORK_DATA 0x000023D9L
// MessageId: FDO_178_SSL_CERTIFICATE_ERROR
// MessageText:
// Error using the the local SSL certificate.
#define FDO_178_SSL_CERTIFICATE_ERROR    0x000023DAL
// MessageId: FDO_179_SSL_CIPHER_ERROR
// MessageText:
// Couldn't use the specified SSL cipher.
#define FDO_179_SSL_CIPHER_ERROR         0x000023DBL
// MessageId: FDO_180_CACERT_CIPHER_ERROR
// MessageText:
// Server SSL certificate verification failed. Verify path and access rights.
#define FDO_180_CACERT_CIPHER_ERROR      0x000023DCL
// MessageId: FDO_181_LDAP_INVALID_URL
// MessageText:
// Invalid LDAP URL.
#define FDO_181_LDAP_INVALID_URL         0x000023DDL
// MessageId: FDO_182_AGGREGATE_IN_SELECT
// MessageText:
// Aggregate functions are not supported by the Select command; use the SelectAggregates command instead.
#define FDO_182_AGGREGATE_IN_SELECT      0x000023DEL
// MessageId: FDO_183_INVALID_FUNCTION_ARG
// MessageText:
// One or more arguments for function '%1$ls' did not match the expected argument types.
#define FDO_183_INVALID_FUNCTION_ARG     0x000023DFL
// MessageId: FDO_184_UNINITIALIZED_AGGREGATE
// MessageText:
// Aggregate function referenced by expression engine before being processed. If using function in Select command; use the SelectAggregates command instead.
#define FDO_184_UNINITIALIZED_AGGREGATE  0x000023E0L
// MessageId: FUNCTION_X
// MessageText:
// Determines the X ordinate of a given point geometry
#define FUNCTION_X                       0x000023E1L
// MessageId: FUNCTION_Y
// MessageText:
// Determines the Y ordinate of a given point geometry
#define FUNCTION_Y                       0x000023E2L
// MessageId: FUNCTION_Z
// MessageText:
// Determines the Z ordinate of a given point geometry
#define FUNCTION_Z                       0x000023E3L
// MessageText:
// Determines the M ordinate of a given point geometry
#define FUNCTION_M                       0x000023E4L
More information about the fdo-internals mailing list
