[fdo-internals] Common Xerces for MapGuide and Fdo
Jason Birch jason at jasonbirch.com
Thu Jul 1 16:42:16 EDT 2010
I'm personally in favour of this. We can state supported/minimum
versions somewhere on the wiki (in release notes?) but using system
libraries is better for our users and for the project. It ensures that
we work to become part of the open source community, coexisting with
other library installations, contributing patches upstream, etc.
On 2010-07-01, Trevor Wekel <trevor_wekel at otxsystems.com> wrote:
> Hi list,
> As part of the MapGuide Oem library upgrades for the next release, we will
> be moving to Xerces 3.1.0 (or maybe 3.1.1) to match Fdo.  The work is being
> done by Rohit, our Google Summer of Code Student.  For MapGuide, we are
> intending to remove Xerces from our source tree and use previously installed
> "-dev" packages on Linux and official Xerces "SDKs" on Windows.  Since
> Xerces 3.1.0 is not available on CentOS 5, we will be building and
> distributing the RPMs ourselves.
> In an effort to share the same physical library on both Linux and Windows,
> we were wondering if it would make sense to follow the same process for Fdo,
> ie. pull Xerces out of the tree and build against an "installed" version of
> Xerces for both Linux and Windows?  As a side note, building against
> installed "/usr" libs on Linux would bring us one step closer to Debian /
> Ubuntu packaging compliance.
> Is this approach reasonable?
> Regards,
> Trevor
More information about the fdo-internals mailing list
