[fdo-internals] SQLite select ordering not working
Traian Stanev traian.stanev at autodesk.com
Sat Jul 17 12:40:03 EDT 2010
Ordering works fine if you use the extended select way of setting it. We'll fix the bug, that's why I said "temporary" workaround. It's just an oversight from when I implemented it, I was probably confused by there being two ways to set ordering in the IExtendedSelect interface.
Traian
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
Sent: Saturday, July 17, 2010 3:25 AM
To: FDO Internals Mail List
Subject: Re: [fdo-internals] SQLite select ordering not working
In MapGuide ordering doesn't work either for SQLite, I think I have
been told so.
Could be that it works in autocad map but if it is true that worries
me even more because it sounds like inconsistency in use of fdo in our
most important client :).
I was planning to use what I think is correct logic:
if provider doesn't support selectordering  then use extendedselect if
supported by provider.
But as it is now, that will be correct for SDF (selectordering=false)
but not for SQLite (selectordering=true) provider.
For our use case I will fix provider rather then to hard code casting
for sqlite provider.
Thanks,
Haris
On Sat, Jul 17, 2010 at 2:47 AM, Traian Stanev
<traian.stanev at autodesk.com> wrote:
> Actually I see what you mean, yes, there is a bug for regular ISelect, in case you use SetOrderingOption(ordering), rather than SetOrderingOption(name, ordering), with the former having a blank implementation -- a temporary workaround would be to cast the command to extended select and use SetOrderingOption(name, ordering). I guess everybody has been using the extended select for ordering so far, so we didn't notice the problem with regular select.
> Traian
> From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
> Sent: Friday, July 16, 2010 8:34 PM
> Subject: RE: [fdo-internals] SQLite select ordering not working
> Hi Haris,
> SltExtendedSelect already implements GetOrderingOption and SetOrderingOption. Can you show a code snippet that triggers the problem?
> Traian
> Sent: Friday, July 16, 2010 5:55 PM
> Subject: [fdo-internals] SQLite select ordering not working
> Hi,
> I haven't tried myself but heard from colleagues that SQLite ordering
> is not working for FdoSelect command.
> I looked at SQLite code and  there is SltExtendedSelect which
> surpassingly implement both FdoSelect and FdoExtendedSelect.
> I believe bug comes from function (SltCommands.h line 116)
>       //Regular select -- not scrollable
>        virtual FdoIFeatureReader*          Execute()
>            std::vector<NameOrderingPair> ordering;
>            if (m_orderingProps)
>                for (int i=0; i<m_orderingProps->GetCount(); i++)
>                    FdoPtr<FdoIdentifier> id = m_orderingProps->GetItem(i);
>                    ordering.push_back(NameOrderingPair(id.p,
> m_orderingOptions[id->GetName()]));
>            return m_connection->Select(m_className, m_filter,
> m_properties, false, ordering);
> which is using m_orderingOptions. Those properties are only set trough
> FdoExtendedSelect interface not for FdoSelect.
> So if I am right then fix is to change line to:
> ordering.push_back(NameOrderingPair(id.p, GetOrderingOption());
> and also to implement GetOrderingOption() and SetOrderingOption() functions.
> This bug would not happened if select and extendedselect would be
> implemented in their own separate implementations.
> In general I would consider problematic that extended select
> implementation is returned for select interface too.
> Haris
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
